#15571 |
![]() Join Date: Sep 2010
Yea. Technically you have 10 days upon moving to ca u have to register your car in ca. So if u drive the same way everyday and the same coo sees your out of state plates, or u get pulled over and they see u have a ca drivers license and out of state plates their gonna give u shit. I've known a couple people that have done this and the only ones I've seen legitimately get away with it are military personnel
#15573 |
Bandwagon.
G dimensions is still around, maybe moved.
#15574 |
#15575 | |
Just keep it titled to you, but register it in your buddies name. Tell them it's his car, and you're borrowing it, because some shit happened, or he's in the military and overseas and he left it with you, or some bullshit. know your story, so you don't have to think about it, but don't be too eager to explain yourself, and seem obvious. If you have an in-state license, and the car's in your name, that could cause problems - but as long as registration is in someone else's name, what can they do? Say they don't like you? The facts will be on your side.... as long as you're a licensed driver, it's a registered car, you're set. Maybe even have your friend write a note explaining that to whoever it may concern, you're borrowing his car for the next.... 2 years, or whatever, I dunno. There's lots of people with multiple houses, who choose one as their residence and keep their vehicles registered there, but who only live there sometimes. There's people with NO house, who drive an RV registered to some random friends house or a pobox or something.... California has no more right to demand that THEY are the state you choose for that perminant address, than the other state. But don't listen to me, I'm in texas - my car pollutes more than all yours put together. |
#15576 |
![]() Join Date: May 2012
I've got a fairly major coolant leak that I am struggling to figure out. I did a leak test and it seems that the leak is under the oil filter but I can't find anything to change there. I already replaced all of the hoses under the intake manifold and the thermostat so I have no idea what to look for.
#15577 |
QUESTION
I'm trying to replace my water hoses on s14 ka manifold Was going to purchase them from dealer but two of them are discontinued Has anyone replaced these hoses and what's the best place to purchase them at i.e autozone? |
#15578 |
![]() Join Date: Sep 2011
![]() Feedback Score: 20 reviews
QUESTION!!!
so i just installed a rebuilt power steering rack and before when i would turn the tire would rub the inside of the frame now it reaches its end point too soon and theres a 5 inch gap from the wheel to the inner frame. anyone have this issuee?? i used to be able to make you turns like nothing now it seems like i cant
GO DUCKS!!!!!!!!! ![]() |
#15579 |
QUESTION: my Air fuel ratio sits a little higher when my fan turns on, sits above 15.5-16.3 when the fan is on but bounces down to 14.7-15.3 when its shuts off. Engine performance feels the same, but i wanted to make sure
thanks
#15580 | |
![]() Join Date: Feb 2012
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
Well where does rpm sit w/ fans on? |
#15581 | |||
Do they both run off the same switched/constant somewhere along the line?
cONtRol FReAkS |
#15582 |
hey everyone,
im completely new to this and only joined to ask one question because everywhere ive looked i could get a proper answer. im manually converting my 1995 zenki s14 sr20de this weekend and was just wondering about what to do with the electrics. like is there something i can just unplug and it will drive fine? or am i going to need a new ecu and loom? |
#15583 | |
in the process of replacing my heater core. i got the model that autozone carries which is the spectra 99222. i was comparing it to the one thats in my car and the autozone one does not have the latch/valve thing on the nipple thats circled in this picture...
![]() my one in my car car does have the latch/valve thing. will it be a problem if i install the one that i got from autozone w/o the thing that is circled?
#15584 |
Stupid question help! Long story short I have a crazy wheel wobble at 45mph, so bad that I have to slow down to the top.of 2nd to spot it. I had ksports and switched to PBM's and started then. Balanced wheel, new tie rods, coils in good shape. Its front passenger only btw. I have a very small amount of play so maybe w bearing, but the other sides like that with no issue. Would my suspension geometry ( now that I'm slammed) play a part in this? My toe rods and lca look fine too. Sorry for a massive post in a.small ? thread. Point me in the right direction or lemme know what the fuck it is. Thanks brohiems
#15585 | |
But honestly its probably because you changed all your shit, slammed it and haven't gotten it aligned. |
#15586 |
This, if you wired the power with something else, or didn't ground it properly (like a chassis ground instead of at the negative terminal of the battery) the voltage differential could be throwing your readings off when your fan kicks in. even if it's half a volt, that could be 1 or 2 afr points.
#15587 | |
#15588 | |
![]() Join Date: Jun 2011
Now you get to find out how much -camber you can take out without rubbing too. |
#15589 | |
![]() Join Date: Jul 2013
Sounds like you have no idea what you are doing. Take it to a shop and get them to fix whatever you screwed up. get a FSM before attempting to replace something yourself.
95 S14 se RB25DET 348whp ![]() |
#15590 | |
alignment needed! ![]()
#15593 | |
Bandwagon.
i used to used ATE super blue now im using motul rbf600 |
#15594 | |
what is the process to put this in a s14? my car has 260k miles and has a q45 front setup and a 07 altima rear setup.. still using rubber oe hoses. how would i go about putting such fluid in my s14
#15595 |
I use valvoline dot 3/4. Basically cheap shit. But I use stock rotors and "premium" brake pads from advance auto. I don't track my car enough to warrant good shit, and that is really preference.
#15596 |
You bleed the brakes, and since you are trying to flush the fluid I would invest in a suction cup pump thingy
#15597 | |
looking to bypass my heater core for a couple months, just checking to see if i got this right...
![]() do i connect those two hoses with a U-shape hose and ill be fine? sr20 btw.
#15598 |
Anyone know if the supermade rear bumper would work with navan lines on a zenki? I have navan skirts and waiting on my navan bumper (rep obvsss) I just don't know what rear bumper I want.. :d and that is not agressive as fuck
Why can't you complement a girl on her tits? ![]() |
#15599 |
Yes, make sure you completely drain it. Why would you do this in the dead of winter?
