05-02-2008, 03:47 AM | #1561 |
I need a quote for the oil drain plug + free spacers shipped to38133 plz! Paypal ready!
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
05-02-2008, 06:58 AM | #1562 |
quote for drift knob (MAX orange) and free spacers shipped to 68526. thanks.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
05-02-2008, 12:38 PM | #1565 | ||
I want you to want to rock
Listen to Bryce. Sure! lol, it appears that someone reads my sig Tracking e-mailed, Thanks
05-02-2008, 02:09 PM | #1567 | |
Check out these shots when we were track testing the Super angle knuckles.
05-02-2008, 11:32 PM | #1571 |
Trader Rating: (47)
Feedback Score: 47 reviews
s13 new bent toe rods
s13 traction rods s13 new bent tension rods s13 rucas shipped to 90006 and s13 new bent toe rods s13 traction rods s13 new bent tension rods s13 rucas +s13 coilovers?? 90006 thankkkss Last edited by I10cruiser; 05-03-2008 at 12:15 AM.. |
05-03-2008, 04:37 PM | #1575 |
I would like too know how they compare too. I have a set of Driving SPORTS Kirikaku Knuckles that are being shipped to me that are going too be paired with driftworks LCA's and wanna know how they match up.. THANKS!
05-03-2008, 06:48 PM | #1576 | ||
$220 shipped to you.
$1050 for coilovers shipped Quote:
GP sports (for a 100% new part) = $1000 + shipping from Japan + LCA mods 3up (for a cut and rewelded 100% used part)= $250 +shipping from Japan +LCA mods +bumpsteer mods Ours is actually more like the Good Road knuckle because we both sell parts with a service by adding a CNC machined piece to the OEM knuckle without cutting it. Good Road (OEM+welding+CNC part) = $550 +shipping from Japan +LCA mods Parts Shop MAX (OEM+welding+CNC parts) = $400 includes both shipping to USA and an adjustable lower arm stop with a fully boxed reinforcement. MAX is better than Good Road because its cheaper, 2x stronger and has more bumpsteer correction & all the LCA mods are included. The bottom line is that with the MAX Super angle knuckle package you get more for your money. The second generation of our super low ride height camber arm makes its debut and is in stock now at Parts Shop MAX USA!!! There is a small price increase of $20 over the first generation arm making this one $200/pair. The new MAX RUCA still features the same angled adjuster tube to clear the chassis but the similarities to gen. 1 end there. Its hard to believe we packed so many features into a low tech item but somehow we managed to make an arm that is quite a bit more complex when it comes to the new angles and radii. The production jigs/tooling for this item are suprisingly complex too. List of improvements: 1. Cleaner "stacked dime" style welds. 2. Tube wall thickness is increased by +1mm while the overall diameter is slightly smaller to prevent the need to reduce the end of the tube near the adjuster weld point. 3. The new RUCA now has a larger radius uniform continuous bend throughout the arm for increased strength and even stress distribution. The larger radius makes this gen II arm compatible with more brands of coilovers on all s-chassis cars. We had to make a 90 degree notch in the tube where it connects to the bracket to accomplish this. 4. The bracket length is increased to prevent the inside of the bracket from contacting the rear knuckle during suspension travel on extra low cars. 5. The length of the tube was increased to maintain more thread contact inside the adjuster for super low cars maintaining around 1 degree of negative camber. 6. There is an arched up sweep in the arm relative to the bracket and adjuster. This provides plenty of additional clearance between the arm and the axle boot which used to rub a little on extremely low cars with the gen 1 RUCA.
05-03-2008, 08:31 PM | #1577 |
PBM,.... you never cease to amaze me
those RUCAs look super clean, i take it the pictured ones are the s14 ones right? is there such thing for the s13? |
05-04-2008, 02:02 AM | #1579 | |
They are in stock now.
05-05-2008, 11:35 AM | #1584 |
Debating these and stances now.
hmmm Quote to 71115 for s13 coils, subframe collars, Tension rods and some of the tie rod spacers.
Hookers and blow. |
05-05-2008, 12:08 PM | #1585 | |||
$215 shipped or come to san diego for $200 picked up. Quote:
$1300
05-06-2008, 03:26 AM | #1587 |
how much for the coilovers shipped to 95687 ?
also what do i need to do to get my hands on that sick ass super angle kuckle kit ? Last edited by ocn; 05-06-2008 at 04:20 AM.. |
05-06-2008, 05:57 AM | #1588 |
[quote=DC Dan MAX USA;2016633
The gen 1 RUCA ($180) is discontinued. The gen 2 RUCA is $200 and you're getting it. [/quote] oh fo shoe then that's hella dope, i'm hella juiced to be rocking one of your newer products thanks dude |
