Old 11-06-2017, 07:52 PM   #1
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Originally Posted by Flicktitty View Post
And Duy, with the "White Rice" 2JZ-GTE S14 went 6.99 @200 MPH. then went 204MPH in a later pass, apparently, it still has more left in it.
Chris Delgado at Prospeed is who tuned my 2j s14. Amazing tuner, not surprised that car ran that fast
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 11-20-2017, 09:12 AM   #2
Tom N
Tom N is an unknown quantity at this point
Curious to hear how far anyone using the DSS "600hp" axels have managed to push them with out breaking?
Starting to break stock axels every couple passes now.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 11-20-2017, 09:15 AM   #3
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
I'm pretty curious about this too since at that power level the realistic weak points become the ring and pinion as well as the stub shafts.
The only value I see int hose 600HP axles is for street cars or drift cars that don't plan on dead hooking 600HP with a sticky tire.
[email protected]
hanzbrady is offline   Reply With Quote
Old 11-20-2017, 09:26 AM   #4
Sforteen
Sforteen is an unknown quantity at this point
why even use the DSS axles? small spline still..
Sforteen is offline   Reply With Quote
Old 11-20-2017, 09:30 AM   #5
hanzbrady
hanzbrady's Avatar
Like I said they make sense on higher HP cars that slip the tire vs hooking it like in a drag car.
Drift cars tend to rip CV joints apart and snap the actual axle so the DSS kit makes sense for that.
I just don't think it's fair to call them "600HP Axles" I'd say they should be called something more along the lines of drift or road race axles.
A 600HP kit for drag racing would at least need to come with better stub shafts imo.
[email protected]
Old 11-20-2017, 09:53 AM   #6
Tom N
The DSS axels are the easiest way to upgrade a part that’s currently breaking every couple passes.
Just trying to see if there are people actually getting away with using the 600hp ones as there’s a big cost difference between the 600 and 900hp ones.
This is a 600hp SR20 S14 that has a race weight of 2750 and uses a 26x10 ET Street bias ply tire.
Old 11-20-2017, 09:57 AM   #7
hanzbrady
hanzbrady's Avatar
The setup that seems to be the best compromise between price and benefit is the R230 differential with modified stub shafts and 350z axles or a R230 with the Q45 and 300ZX TT axle.
I've personally seen the latter make it until the 1200HP mark.
If it were me and we were ignoring the cost I'd do the IRS 8.8 in a heart beat because it solves every issue at once.
[email protected]
Old 11-20-2017, 10:01 AM   #8
Tom N
I've personally seen the latter make i until the 1200HP mark.
Finding the q45 with proper axels is the hard part. Has to be the later one as a 3.54 gear won't work. Looking for a more simple solution. Fabbing in a 8.8 isn't happening right now.
Old 11-20-2017, 09:59 AM   #9
Tom N
Also from what I'm told the difference between the 600 and 900hp Axel is the outer cv. The 600 has the Porsche cv on the inside only where the 900 has the Porsche cv on the inner and outer. The rest is the same.
It's the inner cup on stock axels that breaks every time on the driver side axels right now.
Old 11-20-2017, 01:28 PM   #10
greenpat01
greenpat01's Avatar
greenpat01 is an unknown quantity at this point
I would like to know this too , How much the 600hp dss axle on stock s13 r200 diff setup can hold ? 500whp s13 street driven and occasionally 1/4 mile ..
greenpat01 is offline   Reply With Quote
Old 11-25-2017, 02:00 PM   #11
juiced305diesel
juiced305diesel is an unknown quantity at this point
I have a s14 sr20det powered by a pte6262. It currently makes 680ish to the wheels. I have a tomei 2way and dss 600hp axles and i have yet bust them. The car is currently on a 285 nt555r drag radial.
"Being a SSR wheel nude model is NOT easy, I just make it look like it is!"
juiced305diesel is offline   Reply With Quote
Old 11-25-2017, 03:40 PM   #12
Tom N
What kind of 60 foot do you pull? What’s your cars race weight?
Old 11-26-2017, 11:06 AM   #13
juiced305diesel
I do not drag race. Car weighs 3080 with me in it full interior fully loaded model.
Old 11-30-2017, 09:14 AM   #14
RedSled
RedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-knownRedSled is making his/her stupidity well-known
What will be the most ideal diff ratio for 550hp and a 26x10 et drag slicks
RedSled is offline   Reply With Quote
Old 11-30-2017, 06:51 PM   #15
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
What trans?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 05-21-2018, 08:36 AM   #16
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Well, figured I'd post this up cause I was happy with it. Went to the drag strip for the first time in years...finally got my 11sec pass!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 11-30-2017, 08:19 PM   #17
RedSled
stock trans might upgrade to z32 but im working with the sr20 trans for now
Old 02-04-2018, 10:40 AM   #18
RedSled
What's up with this chat now ,has everyone stopped racing or something,this chat was so active with tons of knowledge and experiences and advice
Old 02-04-2018, 10:50 AM   #19
RedSled
Doubt I'll get a reply or answer ,if I'm lucky might just get one reply ,but anyways here it goes ,presently I'm getting a 1.5 60 feet ,with stock springs and stock shocks ,but it's a lil shaky on top so I'm going to replace the stock springs with lowering springs, can anyone give me their input or experience on this ,and what difference did you get cause I know a couple guys getting 1.4 and 1.5 60 feet with lowering springs ,just curious as to what brand you used and what pros and cons are there compared to the stock springs
Old 03-10-2018, 05:55 PM   #20
Stumped
Stumped is an unknown quantity at this point
I'm running the cheap megan lowering springs with kyb agx shocks. Front on full loose and rear full tight car goes 1.40 60 on motor with a 27x11.5x15 hoosier quick time pro. Hoping for low 1.30-high1.20s this year on the bottle.
Stumped is offline   Reply With Quote
Old 03-11-2018, 01:59 PM   #21
RedSled
thats really impressive ,im doing 1.55 hoping to drop in the next event ,what ratio diff are you running
Old 02-05-2018, 08:02 AM   #22
tuzzio
tuzzio's Avatar
Whos running 15x8 drag (specific) wheels in the rear and clearing z32 calipers? Got a buddy looking to do this and can't find anything without running a spacer.
Old 03-10-2018, 05:57 PM   #23
Stumped
I know a 15x10 with a 6.5 inch backspace clears. I'm sure a 15x8 with 5.5 would also.
Old 03-19-2018, 02:57 AM   #24
Stumped
That was on a 4.08 swapped into a q45 diff. I actually broke the pinion at the end of last season so I went back to the 3.69 q45 for this year.
Old 03-24-2018, 10:00 AM   #25
RedSled
Well redid my suspension and also the ratio and got my 60ft to drop to 1.47 ,still got more to go
Old 04-04-2018, 08:42 PM   #26
PowerDrifter
PowerDrifter is an unknown quantity at this point
would 225 mickey thompson street R fit a stock 4 lug se? Some say too big
http://www.mickeythompsontires.com/d...es/et-street-r
website says 6" rim minimum but im just worried if it can hold 400 hp
PowerDrifter is offline   Reply With Quote
Old 04-16-2018, 08:54 AM   #27
Sforteen
Im on a 3.69 now and a 28in tire.. hopefully it doesnt kill me to much..
I previously ran my best time (10.14 @ 141mph 1.57 60ft) on a 4.10 and 26in tires..
According to the gear calculator i can finish in 3rd gear instead of having to grab 4th..
Old 04-18-2018, 08:54 PM   #28
RedSled
but it'll be better to finish in fourth to get more mph which would result in a better et
Old 04-28-2018, 09:55 AM   #29
greenpat01
greenpat01's Avatar
Anyone try some oem 300zx n/a wheel on the back with slick ? on a s13
They are 16x7.5 + 45 .. I will probably rub my coil ?
Old 04-28-2018, 06:41 PM   #30
candyred_240sx
candyred_240sx is on a distinguished road
Ran a new personal best last night. sr22vet, n1 cams, gen 1 gtx3076r .78 @ 30 psi running 65% ethanol.
26 x 10.5 et streets, z32 trans.
Forgot the laptop but next thing to do is figure out why the mph is so low in the top end, still pretty happy with the time and the car wasn't fully turned up.
candyred_240sx is offline   Reply With Quote
