Old 04-30-2023, 09:12 PM   #1591
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
Originally Posted by BOROSUN View Post
http://www.youtube.com/watch?v=URBQA2EGi9c
intel had the biggest improvements on their latest drivers. what do you guys think of the arc 770 16gb
NGL i kinda want one. my 1060 6gb gets the job done but i wanna crank up the settings in WZ2.0 and destiny 2
ZenkiKid is offline   Reply With Quote
Old 05-01-2023, 07:21 AM   #1592
Future240
Future Moderator
Future240's Avatar
Build
7800x3d
artic 240mm aio
ROG X670e-A. It has pcs 5.0 ports. I only got it because microcenter had a 50% special for mobo's if you buy a cpu
G skill non rgb 32gb 6200mhz, currently at 5800hz testing stability.
EVGA psu 850 gold
two nvme drives, one hynix 2tb gen 4 drive, as boot drive, 2tb 970 evo as secondary
gpu is an Asrock 7900 xtx. It says it needs a 1000W psu but research says 850 is good. So far no issues
This pc is so much better than what I had.
Started playing atomic heart. Game went to ultra settings right away.
Originally Posted by ThatGuy
Old 05-02-2023, 05:17 PM   #1593
Future240
Future Moderator
Future240's Avatar
These bios updates been coming hot and fast. Asus has published four in the last week. The last two were published one day, and then the next day.
Old 05-02-2023, 08:47 PM   #1594
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
Dayum, Very nice. 🔥🔥
https://www.tomshardware.com/news/de...mps-25-degrees
This just in. Direct cpu cooler block. Drops the 7900x3d from 90c to 65c.
What are your temps averaging under idle , normal to high work loads?
BOROSUN is offline   Reply With Quote
Old 05-03-2023, 08:49 AM   #1595
Future240
Future Moderator
Future240's Avatar
Dayum, Very nice. ����
I've been so busy gaming I've not really looked lol. I need to do so, fans barely are audible most of the time. Chassis has two 140mm fans in the front drawing in air, aio is pushing air out and I have a noctua 120mm exhausting air out the back.
Old 05-03-2023, 09:15 AM   #1596
Future240
Future Moderator
Future240's Avatar
Just ran time spy again now that ram is stable at 6000mhz. got a 25,179. Temp monitoring shows highest cpu got as 69C, gpu was 61C. interesting though, the gpu has a bit of coil whine but when gaming cannot hear it over sound of game.
Hwmonitor shows idle cpu
package 45-50c
ccd 28-31c
cores all between 23-28c
idle gpu
hot spot 37c
global 32c
