#16292 |
I'm in the process of buying new wheels, and thus doing a 5 lug conversion. My plan for this is going with the ISIS Performance conversion hubs, however, my car is equipped with ABS breaks. I have no intention of drifting or racing or doing anything other than daily driving the car so I don't necessarily want to lock out the ABS breaks if I don't have to. My question then is will I be able to put new anti-skid sensors on the ISIS hubs or are they entirely incompatible? Are there other methods of working around this? And if it comes down to it and I need to eliminate the ABS what would be the best method?
#16293 |
Tried 3 different Clutch Slave Cylinders from Autozone/O Reily's for my 1995 Zenki and none of them fit right. I don't understand why they didn't fit no matter how hard I press them in they don't line up with the bolts to bolt them back on or just like a little bit too big.
#16294 |
![]() Join Date: Jan 2013
Is there any recommended way to get Solid Subframe Bushings removed, or should I just buy a new subframe?
The subframe I just dropped has some cheap solid bushings installed, and I plan on pressing in SPL bushings so I can adjust to correct the roll center. |
#16295 | ||
On fluids: Grey means WATER. Water means imminent failure. The lubricant must be either natural or synthetic, and if it is not mechanical locking, but VLSD, 4oz TRACTION ADDITIVE must be used(hence my reasons for using Redline Lubricants, tag bitches) Quote:
#16296 | |
I took a torch and heated up the collar last night to burn off the epoxy the PO used, but we are forced to slide a punch in the middle to try and knock them out. There isn't much surface area so I feel we won't get far. |
#16297 | |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Also, the gikens in s2000s were breaking ring gears iirc, not the diffs themselves. Either way, OSG is good stuff. |
#16298 | |
#16299 |
Anyone either know where I can get the hardware that would come with an isis sr20det intake manifold?
Just bought a motorset the the PO had a brake booster delete kit.. or even the thread pitches for everything? |
#16300 |
Hello
I am having problems with my sr20det. Its running lean at like 14.2 when idling and stays about the same when under throttle. then when I let off the throttle it goes super lean. then back to 14.2. The radiator is running hot on the top. and its a brand new one with new fluids. I was thinking it could be the CTS sensor but not sure why its running lean the car has about -20 vacuum when idling. Any help would be amazing ![]() Last edited by Natedog240; 03-19-2014 at 12:33 AM.. |
#16301 |
Hey, stupid question. I'm a bit color blind and need to change springs in my tial BOV as it's staying wide open at idle. Which color spring is this? "Unpainted" "Grey"???
#16302 |
![]() Join Date: Nov 2005
^Yessir it is.
#16304 | |
![]() Join Date: Aug 2008
![]() Feedback Score: 11 reviews
Turned out to be a boost leak. Upon further inspection I found damage and a small hole on the back of the intercooler (maybe a rock?) I patched it for now and it seems to be running normal. Strange, I've never seen a boost leak become apparent at only certain rpms. Learn something new everyday. ![]()
meh |
#16306 |
What's up guys. So my car has been idling weird lately like my buddys civic ha. Every now and then it will go up past 1.5k rpms and then drop back down a little below 1k rpms. But today something weird happened which im not sure would be related to it or not. I would turn on the car but almost immediately after it turned off. Happend twice on the third I gave it a little gas and and it stayed on. Hours later i tried again and when I turned it i felt as if when the rpms shot it it dropped down just as dast and turned off. I have a stock KA Kouki a stage 2 clutch and a 11lbs. flywheel. Any input would be appreciated. Thanks guys.
#16307 | |
meh |
#16308 | |
courtesyparts.com |
#16309 |
I'm trying to find a power source of 12V inside of engine room near the battery on S13. I got a pair of Canadian daytime running lights and I want to turn them on when the car starts and turn them off when ignition is off. Make sense? Well, I don't know electrical stuff well and all I know is from cigarette lighter inside of the car and I don't want to run wires all the way from there. I searched, but most people hooked them up to parking lights. Any help would be appreciated. Thanks.
courtesyparts.com |
#16310 | |
#16311 |
#16312 |
thanks.
do you know what would be causing it to run hot on the top of the radiator? and what would cuz it to get super lean when I let off the throttle it jumps it like 20.0? Last edited by Natedog240; 03-19-2014 at 12:15 PM.. |
#16313 |
#16314 | |
#16315 |
let off the throttle all the way? Could it be that the motor is no longer dumping fuel in and it's just air? Mine leans out a bit like that but I don't think it goes to 20
#16317 | |
You think it could be the TPS sensor? not getting a good connection or going bad. |
#16318 |
#16319 | ||||
![]() Join Date: Dec 2004
Trader Rating: (58)
With that said, it also may not be worth your time or sanity when you get get a used on from craigslist/classifieds Quote:
Check the fuse box? Quote:
All the radiators will be hot at the top, that's where coolant from the engine enters the radiator. Hows' teh bottom hose feel/ Warm/hard/hot? If it's cool, then your system may be working fine. What's your temp gauge say?
