03-19-2014, 12:52 PM | #16321 | |
oh okay. thanks
yeah my wideband maxes out at like 22.0. Its warm on the bottom just find it really weird that the new nice radiator is way hoter on top then the old one. So i was thinking something was broken. and I fail emission was way to high on NOX. Quote:
03-19-2014, 02:36 PM | #16322 |
Bandwagon.
When I turn on my car it bogs a bit then cranks and turns on. (low idle?)
sr20det blacktop s13 |
03-20-2014, 01:03 AM | #16325 | |
03-20-2014, 11:48 AM | #16327 | |
Bandwagon.
its in front of the sidemarker |
03-20-2014, 03:08 PM | #16329 |
Bandwagon.
not sure, find out and let us know.
03-20-2014, 03:18 PM | #16330 |
I got a question.. I did a dual cam swap but no spark whatsoever, tested voltage got 12v going to my coil and igniter connecters from the harness and also got 12v coming from actual coil wire to the dizzy but im not to sure what's the specs on the dizzy for each pin.. motor was running when we pulled it.. im thinking a bad igniter? any way to check? or maybe a fried ecu but I doubt it.. any help once again sorry im the new guy here this is my first 240 so please bare with me.. I appreciate it!
03-20-2014, 06:16 PM | #16331 |
I have a Personal wheel with a Momo (I think) wheel hub. I just installed it a few weeks ago, right before I had to leave (my car is in storage). I went back today and when I moved the car I heard the steering wheel was squeaking when I turned it left or right. I took it off and put the stock wheel on to see if it would make the noise, and it does not. What is my problem?
03-20-2014, 08:21 PM | #16332 |
I did a compression test on my redtop SR20DET motor. Here are the numbers
Cylinder 1 - 155 Cylinder 2 - 170 Cylinder 3 - 170 Cylinder 4 - 170 should I be concerned about the 155 to 170 gap between the cylinders? Thanks |
03-21-2014, 09:39 AM | #16333 | |
http://givemeshred.com/help-my-tire-...gh-my-harness/ |
03-21-2014, 06:33 PM | #16334 |
Does anyone know if 30MM z32 brakes fit under stock 15x6 wheels with a 17mm spacer? Don't feel like spending $300+ to find out I can't use them yet, lol.
03-21-2014, 07:14 PM | #16335 | |
03-21-2014, 09:50 PM | #16336 |
Will an oil cap advertised for an R32 GT-R fit an S14?
Edit: Looking like a no. http://www.rhdjapan.com/jun-oil-fill...ed-nissan.html Different part numbers for SR vs RB oil caps. Yet Nismo is showing the same cap will fit Skylines and Silvia's so I guess I'm still confused: http://www.nismo.co.jp/products/catalogue/#page=271 I've read the caps are either M32 x 3.5 or M33 x 3.5, not sure which ones which, or if they're the actually the same. Lots of misleading info. Last edited by dazed; 03-22-2014 at 01:18 AM.. |
03-22-2014, 07:11 AM | #16339 |
Originally Posted by dazed View Post
Will an oil cap advertised for an R32 GT-R fit an S14? Thanks for the morning laugh gents! One thing I have noticed is that almost all companies who make engines keep what we call 'small shit' pretty darn common. Radiator caps, coolant tank caps, oil caps, you know, small shit. Remember, it is this small shit, that when you go to start making a car yours,(some call it drift tax, others call it speed God tax, you know what it it), you end up spending a crapton of money on small shit
03-23-2014, 10:01 PM | #16340 |
what size tires should I be running? I used to run 215's on the rear when I was running my SR at stock power and it did pretty well. I'm now at 350 whp on the SR and I was still running the 215's. They were nice on the big parking lot because I could just light them up in either 2nd or 3rd gear.
Should I go with something larger now that I have the power to break them loose when I have to? Or stick with the 215's to make easy smoke? They seem to grip alright when I need them to. |
03-23-2014, 10:05 PM | #16341 | |
03-24-2014, 03:58 AM | #16342 |
It doesn't really matter at those hp levels. Your question is based entirely on what kind of driving you want to do. If you want to be able to break traction in 2nd and 3rd then stick with the 215's, if you want cheap tires stick with the 215's, if you're happy with the grip you have stick with 215's. You want it a little grippier buy a stickier set of tires.
But if you want better traction tire for tire, get wider tires. Those wider tires (compared with the same tire in 215 size) will out grip, out brake, and give better launches assuming you aren't running a stupid amount of camber. And I can't stress this enough, but a wider all season will not out grip a skinnier r comp. I'm talking tire for tire. Personally I think wider tires just make the car look way better. |
03-24-2014, 10:36 AM | #16344 |
Ok so I getting ready to do a hydro ebrake install, and I'm figuring out the lines now. I'm trying to model the install similar to this:
http://www.240sxforums.com/forums/s1...e-install.html but probably not with banjo bolt/fittings. anyway, my question is what are the stock s13 bmc fitting sizes? from what I've found, the size should be m10x1.0, but a local hydraulic store I went to brought that size out and it looked way to big. I've circled the fitting size i'm talking about in the attached picture. |
03-24-2014, 01:02 PM | #16346 | ||
^There are going to be a lot of different factors there such as bearing clearances, age of motor, weight of oil etc.
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
03-24-2014, 02:16 PM | #16347 |
Hello again guys so basically... Sad to say but... Fuck I got ZERO 240 friends. I don't know anyone to kick it with or talk to about cars or anything. I just get bothered by Civics all day around my area; there fucking EVERYWHERE, ha.
SO MY QUESTION IS, anyone want to become friends? Ha. I know it sounds kind of lame but I would like to have at least some sort of network of 240 friends. I'm from Orange County (Garden Grove area to be exact) and maybe some of you guys around the area would like to hold a meet or something? All I do is work and spend time with my girl (Just got my AA so I'm kind of chillen trying to pay bills and mod my Kouki as I go ha). PLEASE PM if any of you around the area are interested in such meet or just would be willing to (I know sounds kinda lame to say) be friends. Thanks -Rob |
03-24-2014, 02:51 PM | #16348 | ||
03-25-2014, 07:51 AM | #16349 |
