#1653 | |
![]() Join Date: Aug 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
#1654 |
#1656 |
my s13 has HUD but the windshield was replaced with one that doesnt have that black patch where the m.p.h. display shows up. anything I can do besides get a HUD windshield to get that projector screen replaced?
#1659 |
Try a square of reflective tint. I went by the dealership to see if I could order just the sticker but its only sold with the windshield and my parts guy just laughed when I asked the price.
#1660 |
#1662 | |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
yesss sirrrrrrrr
#1663 |
#1665 |
Okay, I've done some looking around and I want to make doubly sure of what I need before I go spending what little money I have unnecessarily. I got a whinning noise that follows after the turbo starts to spool up. I *really* don't believe it's the turbo. The turbo seems to be running fine. But I've noticed where my dash lights are dim when I start the car at night and brighten up as I start to drive. I had a mechanic tell me that he thinks it might be the bearing on the alternator going bad. If that is the case, I got an s13 sr20det redtop. I did my reading and everyone seems to say that you can use the one's off the ka24de motors, but you'd have to switch the sr20 pulley's onto it and then drill some for the mounting. Also, the plugs are supposed to be the same. Is this true and all that I'd need to do? Is it straight forward with swapping out the pulleys or is some modification required? Also, to dispell any bad info out there, is the ka24 alternator an 80 or a 90 amp? Does it make a difference? And is there a difference between the housing and amps in the ka24 alternators of the s13 and s14 respectively? Thanks in advance for any help.
#1666 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
anyone recomend any specific Reciculating BOV?
any thoughts on the below... http://www.frsport.com/Tial-Sport-Al...d_p_15347.html
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#1667 |
I just took my sr20det out and cleaned up, new turbo and mani and extras. So we started it up last week and having some high idle issues. it stays at about 2000rpm. So I have some rookie qts cause i never originally did the swap and we found some questionable things done so now im not sure what is right anymore.
So first im guessing I should check for vacuum leaks, and also we cant remember if the two little lines comming off the IACV were capped or left open cause there was no lines to them. ![]() thanks |
#1668 |
I am trying to remove my oil pressure sending unit on a redtop (right next to the oil filter). Does anyone know what size socket will fit that sensor? The largest socket I have currently is 19mm and it's just a little to small so my guess is it is 20-22mm. Going to buy some sockets today but just wanted to see if anyone could comment before I end up getting extra sockets.
#1669 |
![]() Join Date: Jan 2009
![]() Feedback Score: 11 reviews
can you put diffrent lips on the professior sp1's (im assuming yes.) and where would i buy them/ what is there bolt patter shit. same as bbs rs's?
RIGHTWHEELDRIVE.com
#1670 | |
#1673 |
long story short im in need of a new fender harness, im guessing thats what its called? it runs from fuse box to fuse box.
i have an auto converted to 5speed. will i still need an auto harness? also are fastback, coupe, vert harnesses the same? zenki and chuki? this is a 93 coupe btw. |
#1676 |
#1677 | |
not giving a fuck
you gotta worry about added or reduced wiring from the chuki to zenki... i say get some FSM's and trace the same wiring sections down, and compare...if you have ot settle for a different model then atleast you know what does what...plugs are what im pretty sure are difference in some locations...for example, cluster plug near ecu one is white for chuki i believe, and zenki is brown...or the other way around...but u get what im sayin...
#1678 | |
im talking about using a 93 vert harness on a 93 coupe. both auto. |
#1679 | |
not giving a fuck
might be...just get an FSM and track the wiring bro...
#1680 |
I am looking into the Blitz Nur Spec exhaust. My question is whats the difference between the Nur Spec and the Nur spec R? Or there the same? thanks
91 S13 Ka-t ![]() |
