#1681 |
Personally I would hold off on getting the diversion. It's not too hard to find good deals on ebay for a dynasty 200dx. you can find them for just over $2000 with relatively few amount of strikes and it is a hell of a lot more welder than the diversion 165. In the long run you'll probably be kicking yourself for not spending more on the dynasty up front. An added plus is that the dynasty is even smaller than the diversion so if you want something easily portable it only gets better.
#1682 | |
Nope, the only way I'll weld a cage to the strut towers is If I reinforce the whole thing. I do not trust strut towers at all. And the lopsided design and placement of the gastank makes this a pain in the ass. The down bars on this car hit a solid peice of floor with a frame rail behind it. I forget the angle but it's not bad at all. |
#1683 | |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
Also added some pieces of steel to the stock bushing housing, tapped them so I can add grease fittings. Also threw a weld on the bushing housing to keep them still. ![]() |
#1684 | |
#1685 | |
![]() Join Date: Jan 2005
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
The Syncrowave is very simular to the Dynasty in features, but in a transformer machine. The Dynasty is about $1300.00 more than Syncrowave, and if portability is not an issue then the Syncrowave may be right for you. |
#1686 |
![]() Join Date: Dec 2002
Jonnie is right. He brought his Dynasty 200 down to my shop one day. He had it all setup in about 5 minutes.
I was blown away with how much better it welds than my lincoln precision tig 185. I want to get one some day if I have the money.
#1689 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
You might have trouble bending tubing with that. The unit you posted is a Pipe bender, and pipe is measured in I.D. where as tubing (which is what you want to use) is measured in O.D. So, the dies for the pipe bender, do not exactly match the size of the tubing, and you will end up with kinked bends most of the time.
There are some tricks to avoiding this though, such as filling the tubing with sand first. You would be better off building a tubing bender like the one JDworkz made.
1997 240sx SE 1998 Frontier SE 1990 240sx Coupe - Sold 1992 Talon Tsi - Sold |
#1690 |
i've used that kind of bender for cages
it will definately bend the tubes but whether or not it kinks depends on wall thickness. for example: 1-5/8" x .120" didn't kink 1-5/8" x .095" kinked but you ALWAYS get dents on the outside edge of the bend, where the holder pin things hold it and it also doesn't have a degree wheel, so you always have to guess and check for the right angle i wouldn't recommend it for building a serious cage, but one for just lapping days would probably be okay. |
#1691 |
![]() Join Date: May 2006
Today Duffm4n called me up after installing a header on his old skool Corolla and having a nasty piping problem - the header didn't even come close to the cat flange - and needed a fix to get home. Naturally, I helped him out
![]() Problem was, the angles were totally off, the header was positioned too far away from the frame rail, and pointing inward, while the cat flange hugs the frame rail, and points outward lol. The Corolla on stands, ready to 'do work': ![]() Fast forward hours later - I had some extra flanges and 2.5" pipe so I made some pie cuts and started fitting them in there - this is what I ended up with, super fitment! ![]() ... well, not so super - I tacked it together (seeing only the driver's side) and realized I left some HUGE gaps on the inside - luckily I'm a mack at filling gaps w/wire feed (had to cut a filler piece for the huge gap though): ![]() Flash makes the welds look super nasty, some parts were perfect, most were 7/10ish Finished product, ground down for baller-ness: ![]() And it fits really well!! ... and all hardware is accessible: ![]() Then we grabbed Camilleon and got her to take her 510 and the 'rolla out together ![]() ![]()
#1693 |
![]() Join Date: Aug 2006
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
![]() things may come to those who wait, but only the things left by those who HUSTLE CLICK HERE FOR MY BLOG |
#1696 | |
![]() Join Date: Oct 2005
![]() Feedback Score: 7 reviews
![]() you could have hugged the A-pillars and tied into them too. this makes it look like a show cage unfortunately. ![]()
I build air pumps! |
#1697 |
^^^ If I was a pro fabricator, and someone brought me a car for a cage, and I told them "you should pull out the dash, so I can design it better, and it'll look better", and they didn't... I'd probably just do it like that too. Sucks, cause it gets in the way of everything (makes it harder to get in/out, impossible to take the dash out, etc).
#1698 | |
GSXRJJordan: look at the other post by JDworkz it shows the dash being out. |
#1699 |
I like your tube bender you made jdworkz. Never seen a cage built like that in front of the dash, none the less great work. I recently welded in a cage for an integra, need to take pics of it and post it. The cage i welded in it is a swing out version. so basically a hoop with two back bars, 4point, then the two front bars can be removed or put in to make a 6point.
Got done with this recently last week. Its a oil catch can/breather tank. I didnt design it, just welded it. Apparently the guy was having problems with his previous catch can spewing out oil while racing (road coarse car), so this one was made. Pictures of it after welded (nonpolished) ![]() ![]() ![]() ![]() ![]() Pictures of it installed in the car (polished), i didnt polish it, the shop owner did. ![]() ![]() ![]() ![]() Underneath picture ![]() Few shots of the engine bay ![]() ![]() ![]() Lastly a few shots of the car ![]() ![]() ![]() ![]() |
#1700 | ||||
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
[quote=DisEpyon;2776697]I like your tube bender you made jdworkz. Never seen a cage built like that in front of the dash, none the less great work. I recently welded in a cage for an integra, need to take pics of it and post it. The cage i welded in it is a swing out version. so basically a hoop with two back bars, 4point, then the two front bars can be removed or put in to make a 6point. Got done with this recently last week. Its a oil catch can/breather tank. I didnt design it, just welded it. Apparently the guy was having problems with his previous catch can spewing out oil while racing (road coarse car), so this one was made. Thanks......love your work too. I would love to see the cage you built with the swing arm. |
#1701 |
![]() Join Date: Oct 2006
Here are a couple things I've built at work
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I know the aluminum welds look like ass but I can't seem to conquer this "Vibrant" aluminum BS. Everything else turns out wicked. Just this Vibrant stuff is crap.... |
#1704 |
Those are some awesome projects Atutt, and great work, of course
#1705 |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Alright well I had to help finish the car at school and I finished by welding up the brackets for the shock mounts.
Some spots were tricky. I had to end up getting someone to push the pedal for me on the TIG lol ![]() ![]() |
#1706 |
Here was my "fun" project for the day.
We obtained a ex factory BMW ALMS car carbon intake manifold. My job was to make it all fit. I won't go into what I had to do, but it was a huge pain in the ass. This is on our shop E46 m3 ![]() Andrew also fabricated all the stickers for my new car. ![]()
#1707 |
just remember. you want the heat exchanger inlets and outlets to be smaller in area then the heat exchanger itself. simple fluids problem
![]() do this: inlet / \ [ ] \ / outlet not this: | | [ ] | | or this: \ / [ ] / \ looks good though.
#1708 | |
![]() Join Date: Jul 2003
