#1741 | |
this is a 'heartbreak' dyno not a number jet and if you read up on that austrailian site in the link 260 rwkw is all that can be achieved using a 2871r .64 . a new gtr wont even break 300 rwkw in austrailia in shootout mode. say whatever you want about my results/the numbers on the dyno it doesent change the fact that a 3071 .64 t2 spools the same as a 2871r but with way more potential. (top mount, twin scroll etc) Last edited by inopsey; 10-21-2010 at 12:09 PM.. Reason: spelling |
#1743 | |
![]() Join Date: Oct 2004
I have 326 /17PSI on a gt2871r.... on a dynodynamicss there was a guy that made 350whp 15PSI on a gt2871r.... on a dynodynamics Cody is probably making 360 on 21PSI on a .63 AR GT2871R.... seriously, Your on a dynodynamics... so are we... don't come on here and bs we are tuning on a dynojet.... but nontheless you have 344hp on a 24PSI on a GT3071R? Something is still not right. please don't be so ignorant
#1744 | |
the discussion was/is about the RESPONSE on the 3071/2871 .64 turbos not peak hp # all i wanted to do is show the response of this turbo as being not a 4k lag monster. |
#1745 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
I'd personally not run the 256 cams either...get 260 Tomeis/260 S3 JWT's/264 HKS cams. Lesson: Move out of California.
#1746 | |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
Yea, I thought about getting the 260s/S3s, but I got these for like $100 new. I couldnt really pass it up and at the time since they were dop in, didnt want to mess with anything else. Guess these will have to do for now...
#1747 | |
17 psi is achieved by 3600 rpm in 4th gear and 21 psi by 3700 rpm as shown by the dyno with a 3071r .64. looks a lot like a 2871 .64 in spool. |
#1748 |
![]() Join Date: May 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I've seen side by side dyno comparisons between Tomei 256 poncams and Tomei 260 procams. The difference between the two was about 1-2 whp. I went with the Tomei 260 procams not knowing this. IMO, it's not worth getting the procams and having to install aftermarket valve springs vs the drop in poncams. Then again, this was all done on a Mustang dyno which reads a lot lower than the dynojets dynos posted up on here.
#1749 |
![]() Join Date: Aug 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
This is a car i resently built. unfortunately the clutch didn't hold with the race gas tune. it did a nice 353whp on 91 Octane and 15PSI. but at 22Psi with Q16 , the clutch tapped out. currently has an Exeddy Supper Single, Upgrading it to a SZ/ Bardabe Performance Flywheel and Max 6-Puck clutch. then strapping her back down.
Update: Flawless Rides S13 Tuning Session is Over | |
#1750 | |||
Trader Rating: (58)
Swain Tech Coatings for engine piston coatings, race engine coatings, ceramic header coating, carbide metal coatings, thermal spray plasma coating, metalizing closures, spray welding Quote:
Lets also not forget that a dynojet (persay my example) is a non load bearing dyno...it will always spool later than it does with load (persay like a dyno dynamics). Again if your setup was the norm, there is ZERO reason why I would stay with my setup, especially if I could stand to gain some more top end...
#1752 |
![]() Join Date: Jan 2008
Yes i found this thread quite useful. didnt realize you were over here aswell^^ good feed back to.
My Twin Scroll Gt30r Sr22det Build |
#1753 | |
I am fully confident with my new winning streak and the recent EFI advanced research I have been doing we can eclipse the 400 WHP mark on my dyno...yes probably with 100 octane but then you would literallly be looking at the fastest 2871R car in the better part f the world, especially if you factor stock bottom end....For a while i was starting to think, even thugh the compressor maps don't lie for this turbo, that most of the sub 400 or even over 400 DJ dynos were either staged, corrected etc... Now that I have reaffirmed that it is / was indeed the quality of the work done to install the parts / mds before the dyno I am confident we can really break some records with this thing...
Like Me on FaceBook ![]() |
#1754 | |
Yes everything of any quality has gotten more expensive These are the little finishing touches that when paired with a smaller turbo option make the car much faster in the end than an overly laggy SR with a big peak number at the tp
#1755 | |
Trader Rating: (58)
![]() I just wanna see some trap speeds out of this thing, or for you to throw it on a dyno jet. For true comparison sake, as if anything we've learned, we dont' see much difference between the local Mustang Dyno and our Dyno...I just wish the Dynamics wasn't hours away I'd go up there for a pull to compare. I don't like this 'well it reads XX% lower, as we all know that's unfair to everything. Trap speed is the true equalizer
#1759 | |
yah there is a lot of timing on my map in the light load/low boost settings but no knock(single digits on pfc commander) |
#1760 |
![]() Join Date: Sep 2005
see i havent dyno'd my car yet so im not sure what the #s are...but at the track i cant grab traction to get down the track.
i do a great burnout and use a launch controller. my 60fts are good but then its all wheel spin in first gear. then i play catch up...sucks 2871rs .64 at 19psi with all supporting mods. so i cant be over 350whp but i bet there some serious torque going on. |
#1761 | |
Trader Rating: (58)
Or you're simply loading the shit outa the car down low to spool it (as the HP is way off for everything else). There is now ay you can introduce enough timing to make it spool that soon on stock cast pucks and headgasket.
#1762 | |
No the car posted above that hit 350 on 14 PSI was NOT on meth... The car that used METH was a totally different car.... Nice try Cody ![]()
#1763 | |
Trader Rating: (58)
I will say this though, meth is a wonderful thing to keep temps down. I don't use it for HP, just for the track/safety...man oh man does it work.
#1764 | |
#1766 |
Bring it to the dyno Mike!
Unless you want to go to the dyno twice! Seems like most of the cars I tune lately were "tuned" by another shop cough like gdim, or cough someone else and then still needed a re-tune....even after all that...why pay for a tune twice? As long as the install is tits and the parts are good quality should be solid... Is that HKS GTRS?
#1767 |
![]() Join Date: Oct 2007
=T My car is at g-dimension right now. all work is being done by them.
is that an issue? James has been nothing but extremely helpful. Last edited by m2mike; 10-28-2010 at 02:24 PM.. |
#1768 |
I don't think so I just have had a lot of their cars in my shop for re-tuning lately
IMO you go to an install build shop for install build and you go to a EMS specific specialist for dyno work... Some shops do it all but I havent seen any do it all properly since XS hayday... I'm sure he does good work though...
