08-15-2013, 08:13 AM | #151 |
well sorry for the no updates, looks like photobucket isnt giving me back any bandwidth. my reset day was yesterday and when i checked it at 7am i was at 10.1gigs...not sure how that happened in 7hrs but it did. ill make a new photobucket this weekend and post some pics
didn't want you guys thinking nothing is getting done lol
Admin- AZSupraCentral |
08-19-2013, 12:52 PM | #153 |
some small stuff
got board and painted my diff cover got some nyloc nuts for the mount points return line test fit of the rad, ill be taking out the core support and moving it forward...might go v-mount like i want but well see how things go
08-28-2013, 10:45 AM | #154 |
pulled the motor back out to fix some small stuff
sealed up my diff and installed it mocked up the harness how i would like to run it back in she goes proefi placement just a reference pic for where i would like my switch panel where the harness will most likely go through. might drill a hole right behind the motor but i think it will be a PITA to deal with later, all though it would be nice harness all to length, i will be changing out all the wiring to the same as what proefi uses. reason being is that the wire on the harness now isn't that great, other people that used it have had problems with the insulation melting and the wires shorting.
10-21-2013, 12:12 PM | #155 |
small update, for as long as i haven't updated this thread it should be a lot bigger but Ive been busy with the house.
got 25' of .120 wall 2x2 and 1x1 tubing fuel cell cage view from the back of the car been about 2weeks or so now that this E85 has been sitting in the cell, no signs of the bladder degrading so i should be good.
10-28-2013, 12:58 PM | #156 |
had me a bit of a busy weekend
finish welding up the trunk striped off the tail lights and bumper after it was welded shot it with sandable primer just to keep it rust free all said and done this is how it looked, will paint it fully when / if i paint the car after i finished that i felt like i needed to keep going...so i pushed the car back and started on the front putting on frontend bits started on my new core support bar, i am wanting to make this removable so motor pulls are easier o yea this showed up Friday too...40 micron and 10 micron filters
10-28-2013, 03:56 PM | #158 |
they are robbmc filters they were both like 125 shipped too my door
Welcome to RobbMc Performance Products
10-28-2013, 09:29 PM | #159 | |
10-28-2013, 09:34 PM | #160 |
We've proven them to over 750whp on E85
10-28-2013, 09:39 PM | #161 |
Nice. What fittings will you be running on these? How/where are you mounting?
The build is coming along really awesome keep it goin!
10-29-2013, 10:09 AM | #162 | |
thanks man really hoping to start it before the first of the year so i can meet my new year's resolution lol
10-29-2013, 01:07 PM | #163 | |
11-06-2013, 08:20 AM | #164 |
more frontend work this weekend, hoping to make my bash bar this weekend
put the hood on to see what im going to do about clearancing the gap the manifold hits first, then the motor will after that plans are to run without a hood till i make/get a new intake manifold and a new throttle body, once i do that i will get the hood to fit by allowing the 2j to poke through.
11-06-2013, 08:59 AM | #166 |
Some bs ebay ones right now but will be switching to getnuts or zerolift after the car is running. I don't know of anyone that has a jz swap that has a hood that fits right. All local guys that have / had jz swaps in 13's run no hoods, I myself would like one so what ever it takes to fit ill do and I like the idea of having the motor poke out a bit.
11-06-2013, 09:00 AM | #167 |
I made my mounts btw, they are stock hight
11-06-2013, 09:06 AM | #168 | |
11-06-2013, 10:58 AM | #169 | |
How much space do you have from the upper oil pan to the front crossmember?
11-06-2013, 11:06 AM | #171 |
I I'll have to check to see what the spacing is between the pan and crossmember. As for the mounts I can't remember the height but I measured a stock one and cut alm bar stock to length
11-06-2013, 08:47 PM | #172 |
Ok I have about 1.5" of room that is safe to lower the motor to the crossmember. My mounts are 2.750" tall
11-07-2013, 05:52 AM | #173 | |
Are you sure you have a full 1.5" before anything hits? Seems like a good bit of space.. Id say chop your mounts to 2.375-2.5" and re-check and keep going from there if you still have space
11-18-2013, 02:53 PM | #174 |
still haven't messed with the mounts but 1jzsilcoupe pm'ed me back and said his are 2" tall so im going to make another set at 2" and check them but...
some of the fuel stuff came in thursday / friday new style fuel line that anfittingsdirect.com is using now up close so you can see the layers of the line new VS old styles, on the -10 line you have to strip back the TPU coating or the fitting wont work return line at firewall feed line at firewall, this will be Y'ed to duel -8 lines under car lines coming into the trunk fuel rail with the fittings one of the -8 feed lines surge tank came in as well, still trying to decided how i want everything but this is most likely how it will end up after working all day its time to shine...
11-19-2013, 01:34 PM | #175 |
Awesome! I like the look of the line. Im at the final stages of running my lines from the tank to the firewall and this is good reference material - thanks! any better pics of how you crossed over by the differential to avoid all moving parts?
11-19-2013, 01:54 PM | #176 |
More or less just went right over top from the drivers side, I'll try to take some more pics of it tonight for you mike
10-06-2014, 08:20 PM | #179 | |
been real busy with work and finishing my MK3 up (will post vids soon) but i will switching back to the coupe soon so stay tuned for 240 pics soon and sick mk3 stuff lol
