#151 |
Thanks guys!
![]() ![]() I was invited to a car show this weekend to help promote my friends clothing company. Some people took some cool pictures... ![]() ![]() Thanks to Tony from MeatyFlush! ![]() ![]() Thanks to Erik from PRPL! Also a big thanks to PRPL for inviting me out! I had a great time. Be sure to check out www.prpllife.co !
#153 |
Could you go more into detail with your suspension setup, before your knuckles, because I love your stance and want to get my s14 to same way, also see you have a PBM FLCA tension rod combo, what did you have to do to run them properly?
#154 |
Thanks!
Roll your fenders, lower your coils, and find some wheels that fit! The FLCA is what gives you the wild camber up front. To run extended FLCA you will need a longer inner tie-rod. I would recommend S14 Tein inner tie rods (and you will need to buy S14 outer as well, I recommend MOOG or Tein).
#155 | |
And Tein Inners are longer than OEM? |
#156 | |
#157 |
Awesome build!! I know its been said a number of times but your thread is an inspiration!! I love your positive attitude and excitement, its definitely refreshing to read!!
![]() I don't know if I missed it but: did you mention how the car handles now that you cut the rad support?? Do you feel much difference when cornering?? I am actually thinking of doing something similar to my AE86 since I am going to be running a KA and I know space is an issue with these swaps... any tips or advice?? |
#158 | |
![]() so chopping, extending and boxing it up my FLCA would be best ![]() |
#159 | ||
![]() Quote:
This would be the best way for you to go, in my opinion. It is a tried and tested setup, that is proven to hold up... and costs a 1/3 of PBM FLCA. I extended a set 30mm for a friend and he loves them! Good luck!
#160 |
![]() Thanks man!! I appreciate the advice!! I think it is definitely something I want to do. And I can see how running a strut brace could help reinforce the rigidity in the front end. Thanks again!!
#161 |
![]() So at the last event, I kept running into issues with the car... I was able to press on and keep driving, but that car was not enjoying it. When I got home from the event, I began to look for the problem. Checked the spark plugs, tried another set of coilpacks, checked for boost/vacuum leaks, tried another MAF, replaced injector o-rings... Some things seemed to help, but nothing fixed the problem. I was stumped...I decided to yank my ECU out and make sure everything was well, but when I got the case out of the car I could hear something rattling around inside... ![]() ![]() ![]() I got to the track and decided to try a spare coolant temperature sensor, since my problem seemed to be occuring when the car would get up to temp. Stuck it in there, let her warm up, and back to stumbling and smoking. It was worse than the last event, the car would hardly move under its own power. I ended up messing with the car most of the day, and couldn't get it to run right. We got tired of it and decided to pack up and head home. I got right on the car trying to find the problem... After much deliberation, I decided the ECU had to be the problem. I do not see any visible damage to the ECU, and do not understand the board enough to dive much deeper into it... At this point, I was one week away from Club Loose East Coast Bash, and really wanted to try and make it out to that event. I went through the motor one more time, and made sure all seemed well. The car would run fine until the 20 minute mark, and then die out. Everything looked, and seemed healthy enough. I rushed to find a PowerFC and get the car over to my tuner. I only had a few days to work with, and he said he could squeeze me in... Awesome! Got everything together, and took the car over to MA-Motorsports. At this point, I had 3 days until the event. I got skunked the last weekend and really wanted to get back on the track. On Thursday I get the call from MA that cylinder 1 had low compression... F#@! ![]() ![]() Got it back home and was rushing to find a solution to get the car running for just a day... The ECU was not operating, so I tossed in a stock ECU to see what it would do. The Z32 AFM would not allow the car to idle properly, so back in the stock AFM went. Car would idle great now... But drove like ass. I decided to dig around in the back of my shop and see what I could find... I came back out with a set of stock injectors and a manual boost controller. Turned the boost back to 10psi, tossed the stock injectors in... and the car was running fine! Despite one cylinder not being too happy... ![]() ![]() I was a little nervous about the setup all day, I had just pieced it together and had zero time to test it. I had my fingers crossed, but had no idea what I was in for... Took it out for a test lap around the track and it seemed alright. Made a few passes around the track and was plagued with small stupid problems all day. The track was really rough for a low car, they told me I wouldn't make it around the track at tech ![]() ![]() I also forgot to mention, that somewhere in between all of this mess I finally recieved my Nismo R32 Skyline spoiler and got it painted and mounted to a spare trunk lid. I am loving how this thing looks!!! I will try to get better pictures sometime. So I brought it back home and had some time to finally relax, and think about what I should do. It could be cheaper to rebuild one of my damaged SR, but it may cost me a lot of time. Our drift season is only a few events long, and I would like to be back at the next event and finish the rest of the season strong! So the plan is to find another stock SR local, and once everything is running well again I will rebuild one of the damaged SR to have as a spare. ![]() Carlos came by and we pulled the motor out. Now I need to strip all of my good parts off of it, and go pick up an SR that I found at one of the local importers. I only got a few passes in at the first track day before the car began to run weird, which I now know was the daughterboard falling off... ![]() ![]()
#162 |
![]() So we last left off with the blown motor out of the car... I began to call around to all the local importers, and it seemed that I did not have a whole lot to choose from. I found some time at work, and decided to just ride down and take a look. When I arrived, it was not long before I had each employee pulling me off to the side telling me that if I waited a few days they could give me the deal of a lifetime LOL ![]() ![]() ![]() Stripped this motor down to the block, and put all of my parts on it. The automatic pilot bushing is a real pain in the ass! ![]() ![]() Kept chipping away at it every chance I got... Got everything hooked up! ![]() Finally got an appointment on the dyno to get the new PowerFC tuned! Took it over there and the fuel pump decided to die on me. ![]() ![]() But, worked past that and now the car is running again!!! ![]() ![]() ![]() Stay tuned!
#163 |
![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Dude, Awesome build thread man, I usually just scroll through the picture because i'm at work, but I read through the entire thing. I absolutely love this car, can't wait to get home and put in some work on mine. Keep up the good work.
#164 |
I finally got my car back out!!!
![]() ![]() Hauled the car Shenandoah Speedway for DriftValley 11. My last time here my motor gave out on me, and I was hoping to make the most of this trip! Got there early, and unloaded everything. Drove the car around the lot a bit and it was feeling solid, but I can't say I wasn't worried in the back of my mind. ![]() ![]() Photo Credit - Neil DeVera Took it easy the first lap around, got it up into boost and everything felt smooth. After having just blew up the motor, I was a bit timid to push the pedal down all the way. Took it out again and started to push on it a bit. Everything still felt smooth, and at this point I was ready to give it everything it had. Went back out and and held the pedal all the way down through third and into the big bank... ![]() ![]() Photo Credit - Jeremy Gray What a fucking blast! To feel everything working in harmony made me feel a certain type of way. The way the car handles, the way the power comes on, the way the car sounds... It is the dream I have been chasing for years, and here I was sitting in the driver seat thrashing it for all its got! ![]() Photo Credit - Neil DeVera ![]() Photo Credit - Mike Deckman ![]() Photo Credit - Tyler Griffith Now everybody knows, a drift day rarely goes by without a little drama... Sure enough, I was tinkering with the car a bit between run groups and got distracted. Buttoned everything up and got back out for my run group. First.. second.. third.. clutch kick.. wide-open throttle... aaaand my hood flies up! ![]() Got back out there and drove better than I had all day. The smoke was pouring out and my speed was picking up each and every run. Of course somewhere in between all this I mashed a cone in third gear and tore my new Aero bumper up, but I'll fix that later. A friend of mine had been bugging me to tandem [for my first time], but I had not been feeling it up until the end of the day. He pulled up next to me in line, and I already knew what he was going to ask. I give him the thumbs up and he jumped in front of me in line. What a fucking blast that was! I managed to keep up (with a 600hp car) and was really rolling some coal! Probably one of the best runs I had of the day, and of my life. I was stoked! ![]() ![]() Photo Credit - Mike Deckman Video Credit - Bill Pullin Got home and found a spare hood hinge and switched out the remnants of my Aero bumper for a bash bar, in preparation for the next day. Hauled the car out to Summit Point Motorsports Park for the Drift Nirvana event. This was my first time drifting two days back-to-back, and probably my last. I could hardly wake myself up in the morning, as opposed to waking up 30 minutes before my alarm on a usual drift day. We dragged ass out to the track, slapped the car together, and I was out on track again! I was on the same track that claimed my tension rod last year, and is a terrible track for low cars. However, it is a pretty 'standard' course in our area and I need to learn how to drive it. Spent most of the day fighting my suspension as I rode up and down the waves of asphalt, listening to the symphony of my frame rails grinding off in unison. But I made the best of it and finally started to get the hang of the track. Towards the end of the day I made a few respectable passes and I left happy. ![]() ![]() Photo Credit - Neil DeVera Video Credit - Bill Pullin It felt great to have the car last two straight days of thrashing. Hopefully it lasts many more! ![]()
#166 |
Damn Nick! Car is rad as hell. How long have you been running the expreme exhaust manifold? I heard mixed reviews on them. You said you have been waiting for a long time for your car to sound like that. What has changed for you to achieve said sound? Reading through your build, it looks like you have always had the expreme manifold, the new add of the tomei turbo, tomei outlet?, what else am I missing? Definitely makes me want to go turn wrenches on my cars man! Keep up the motivational build!
#167 | ||
![]() Quote:
I was running the Expreme manifold and turbo outlet when I was still on the stock turbo. I have been using the Expreme manifold for two years now with no complaints! It is a high-quality piece, as you would expect from Tomei. The turbo is what really changed the sound of the car. It has a very signature sound compared to any of the other SR20's at the local track. I love it!
#169 |
Thanks dude! Right back at ya!
#171 |
Grab a cup of coffee and a pack of cigarettes, this is about to get awfully interesting...
After many long, hard weeks at work...it was finally time to head to the track! I had no time to mess with the car in between events, I was just hoping to load up and head out. It was a small event so I was not worried about things like bumper and headlights, I was just hoping to get some good practice in. I got to the track, unloaded everything, and set up our area. I was switching my rear wheels to ones that actually had some tread, when one of the lugs decided to start rolling in the hub. I spent the majority of the morning fucking around with that, and was becoming very frustrated. My friend Adam had a goliath electric impact gun, which finally extracted the lug nut. So out on track I went. I only made a few passes before it happened… I was coming in hot, yanked the handbrake, and the car did not respond. I am still not sure why, it all happened so fast. I had came in fast and wide, without much room for error. I tried to stop the car using the foot brake but there was not enough space. I went hurdling in to the wall in third gear. So many thoughts were rushing through my head. It all felt like a bad dream. I could not believe what had just happened. This could quite easily have been one of the worst moments of my life. Physically, I was fine. Mentally, I was crushed. As I sat there looking at my car, I couldn’t help but think of all the great times I have had with the car. It was such a shame to see the car that way, it still bothers me to this day. However, there was one thing I knew for sure… I couldn’t let this get me down! I did not come this far to go out this way. I have way too much invested in this to stop now. As soon as I arrived home I knew I had to get to work. I wanted to prove to myself that I could beat this. This was by far the most serious accident I have had on track, and I knew it was really going to test me. I had to push all my emotions to the side, and get the fuck to work! I began furiously tearing apart what was left of the car. The next day the motor was out, sitting on a pallet. I assessed the damage, and began to make a list of what would need to be replaced. This list was staggering, to say the least. ![]() Thankfully, I had a hatch sitting around. I had found the car on Craigslist for cheap, and jumped on the opportunity. I had plans to use it for something to cruise around in, but never had the chance to get the pissy little single-cam up to par. So it sat and sat, until finally one day it was pulled in to my garage. I worked on it every single day. I would set small goals to get done each day, then start thinking of what I could do the next day. I did my best to keep the parts flowing in, so I could stay working. I worked on the car as much as I possibly could, I wanted to get the new car running and out on track ASAP! I would work every weekday from about 5 p.m. until around 10 or 11 p.m., only taking a break to eat. Weekends I would usually get started by noon and work until around 4 or 5 a.m. Some nights I could not find any help, and would have to work alone in to the wee hours of the night. I am pretty sure I was going crazy, but I couldn’t stop. I had one thing on my mind, building my new car. It became hard to concentrate on real life. I was missing a lot of sleep, and it was dragging me down. But I kept pressing on, giving it 100% of what I had. ![]() ![]() ![]() For the first few weeks, I was really feeling overburdened. I was still bothered by the loss of my old car, and progression seemed very slow on the new car. Finally, after about three weeks, the new car began to take shape. After all the hard work, I was finally beginning to feel a connection with the new car. Progression was picking up and I was becoming very excited. At the rate things were going, it was looking like I may be able to make the next drift event that was on my schedule! Despite my serious lack of sleep, the excitement provided me enough energy to continue pushing on in to the fourth week. Which is, of course, when I started to become very sick. I knew that if I could keep the pace at which I was working, that I could be at the next event like I never missed a beat. However, it was steadily becoming more and more difficult to continue on. ![]() ![]() But, I kept visions of the next event in my head and worked towards it with everything I had! I found myself working on the car until around 9:30 p.m. the night before the event. Which is extremely out-of-character for me… unfortunately, I had no other options. At around 9:30 p.m. the night before the event, I decided that the car was ready to be taken to the track and tested. There was still some interior/exterior work to be done, but the car felt sound mechanically. We loaded up and quickly went to ‘sleep’ before the big day. I could hardly shut my eyes though, as I went through everything I had done in my head. ![]() ![]() We woke up bright and early the next morning, and begun the trek out to the track. It was a very tense ride up, all I could think about was the car. Did I rush through it too quickly? Is it ready for the track? Did I tighten that bolt enough? Finally, after a long three hours, we arrived at Shenandoah Speedway. It was a weird feeling for me. A combination of ‘nervous-as-a-motherfucker’ and ‘so-happy-that-I-want-to-scream’. Here I was, back at the same place that I crashed, exactly one month and four days later. With a brand-new car ready to fuck shit up! I cannot explain to you how great it felt to beat the crash like that. As soon as I passed through the gates a giant shit-eating grin took over my face, and I am not sure that it ever left until the weekend was over. ![]() Photo Credit - Ed Anderson We unloaded the car off the trailer and I was quickly greeted by a few ‘WTF?!’ faces. I was so busy working on the car, that I hardly had any time to post what was going on and not a lot of people thought I would be driving the next event. I teched the car in, and started getting ready for the track. The first few passes back out there were strange… I felt a whole new respect for the track. I spent a few laps just driving the course. Feeling out not only the car, but myself as well. I could already tell it was going to be weird throwing the new car back at the same wall that claimed the old one. After a few laps and some small adjustments, the car was feeling solid and I was ready to get it sideways. I started on the small, open turns in the infield. Just trying to get back in the groove. Let the steering wheel spin a bit, stab the throttle a few times… I was feeling pretty good. I decided the best place to try and get back up to speed, would be the second-to-third gear turn coming out of the infield on to the bank. I came through the infield, hit the limiter in second and latched third as I started to get close to the clipping point. The car jumped around the point just as I had planned, and the smoke started rolling. It felt so good to be back out there again! The new car was felt solid. It ran great all day despite wanting to heat up after too many passes, which was expected in the hot summer weather. Once I was feeling settled in, I decided to run the solo comp for the hell of it and ended up taking home first place! The ride home was much more relaxed, the new car had done it’s duty. It took a full day of hard drifting, and I even brought home a trophy with it! ![]() Photo Credit - Kenny Sirivongxay ![]() Photo Credit - Jeremy Gray ![]() Photo Credit - Jeremy Gray Video Credit - Paul Fregeolle Video Credit - Paul Fregeolle ![]() Now I need to go back through all of my work to check everything for the umpteenth time, and start on getting this thing painted! I still feel strange about the loss of the old car, but I am excited to see what the new car could bring. ![]() I would also like to take a second to thank my father (again). Throughout this entire process, he was there every chance he could get. He is willing to push himself, as hard as I am willing to push myself. Once we got in to weeks 3 and 4, we both started to become really worn out. You could see it in our faces. We began to constantly bicker about stupid shit, and it would even get pretty serious sometimes. But we managed to stick it out, and build yet another track-proven machine. I can’t thank you enough for all your help; whether it is laying under the car with me, or just giving me your straight-up honest opinion (even when you know I don’t want to hear it). It’s awesome to think about how we are still kicking after all these years, here’s to many more! I would also like to thank Thomas. Probably one of the coolest dudes that I have met through this ‘junky-old-Nissan’ obsession. I appreciate all the tools you loaned me, and all those late nights you spent in the shop helping me! “The only way to find your limit, is to push your limit.” -Ben Williams, Fresh Roots Motorsports
#179 |
Thanks everyone! No sense in crying over spilled milk. It's the risk you take every time you go out on track. Like falling off your skateboard... You gotta get back up and do it again!
![]() Here are a few pictures from my friend Neil DeVera! ![]() ![]() ![]()
#180 |
![]() Join Date: Sep 2012
what a hell of a comeback. thats fuckin awesome you just got right back at it man. major props. not to bring up sore times but do you have pictures after you wrecked the coupe? sucks to see one of my favorite s13's gone but its fuckin awesome to see you get right back on the saddle.
