03-20-2010, 01:10 PM | #152 |
Trader Rating: (22)
Feedback Score: 22 reviews
SWEET build on a CA motor not many people put that much money and time into that motor anymore!!! GREAT JOB!!! That aero and those wheels have got to go though man, 180SX aero with some Work wheels would be SICK especially aith that engine bay!
03-23-2010, 09:53 AM | #153 |
Picked up my new Tial waste gate valves from Svensk Turboservice yesterday. They came straight from the Tial assembly line in the USA.
Worth waiting for! They are the new, upprated version with integrated water cooling. How small are they? I compared them with the earlier bolt on 38mm Tial WG and I can tell you. They are very small! Good! Since I do a twin installation and there isn't much space to talk about. MV-S V2.0 This revamp features water cooling ports, three bottom air ports and two top air ports. Water ports are not required for operation, but come in handy at road racing, the top hat is close to the turbine housing/down pipe or when the engine bay doesn't get a lot of airflow. Air and Water ports are clearly marked so there is no confusion. (mine are silver/aluminum coloured). |
03-30-2010, 10:56 AM | #156 |
Awesome thread!
I love all the upclose macro pics. I cant wait to see the transformation your car will take when it is all complete and with different styling. I am jealous of your shop space! Keep it coming!
PARTING/SELLING MY COUPE. PM ME. |
03-30-2010, 11:16 AM | #157 |
Yeah I have been heard a lot about the MVS, if you were to use the water ports, where would you tap for the source? and I assume the two water ports is water in and water out?
How about the air ports? hwo do you use them? Thanks for sharing awesome build.
Turn and Burn! |
03-31-2010, 12:00 AM | #158 | |
I will continue to inform you about whats going on. When I come back from Paris after Easter, the engine/gearbox will be installed in the engine bay |
03-31-2010, 12:30 AM | #159 | |
(three bottom air ports and two top air ports). My new turbo doesn't have any water cooling. There is as you know a water cooling system on the engine, used for the original T25-turbo and I will reuse that for the Tial MVS (with new piping). You are right, there is water in and out on the MVS. Connection of the air ports will basically be like Tial suggest and I will use a Haltech electronic 3-way boost valve together with my new DTAfast ECU. I have a bunch of different springs to install in the MVS and I will use a basic spring load of 1-1,7 Bar (14-25 Psi) and with the Boost valve the Max Boost will be set to about 2,5-2,8 Bar (36-41 Psi). This together with all other tunings will result in some +700HP. |
04-16-2010, 08:42 AM | #161 |
Today I made a major investment.
I bought a spigot bushing for a massive $8 Part no. is 32202-7f401 For those not familiar with the term, the spigot bushing is a bronze sleeve bearing in the tail end of the crankshaft which carries the nose of the gearbox input shaft to provide proper alignment of the clutch disk. Soak it in oil for a day or two before you install it. The oil penetrate the tiny holes in the bushing. The old one is removed with a rod just a tad smaller than the inner diameter of the bushing and some ordinary grease. Fill up the hole with grease, put the rod inside the opening and tap it with a hammer a few times. The rod will press against the grease and the grease will force the bushing out. May take some harder taps if the bushing is a bit grumpy. |
04-21-2010, 01:08 PM | #165 |
Lots of pins to crimp on the cables for the DTA-ECU. Only remain some heat-shrink tubing and they are all done. The photos show the sensor cables. The Power cables I finished earlier.
04-21-2010, 02:02 PM | #167 | |
For power I use ordinary low resistance wiring. I have +12V, +5V, ordinary chassis ground, one separated sensor ground for normal sensors i.e oil pressure, temperatures etc and another separated sensor ground for hall sensors (CAS). 20 and 22 AWG |
05-03-2010, 12:48 AM | #174 |
05-06-2010, 09:39 AM | #179 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
dare i say it, i now have a reason to fly to sweden...holy hell i love this build...
im not down with the chrome, but thats just ur flavor...but the detail and work and all around effort, i respect to the utmost...great thread... if anything, i found the next person to bug if i have questions about this motor...
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
