#151 | ||
![]() Join Date: Jun 2008
![]() Quote:
I ordered the tubs from one of the fabricator here in Australia. |
#152 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
you will be fine to rebuild a z32 trans with a short shifter and run a twin disc. same combo im running and i love it. not as fun as when i had a dog box but almost same results and is alot more reliable for a fraction of the cost. then do the ppg gear set later down the road.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE! 10.79 @ 124 MPH WITH A 1.48 60' |
#154 |
UPDATE:
Guess time for an update as well. The following are some of the stuff that we had ordered Prefab front tubs (I found that I'm having scuffing issue at full lock on the current setup) Cusco SR20det Engine Mounts (hopefully this will lower the engine abit 10-15mm +10mm from current nismo mount) 12x Rocker Studs 12x Rocker Washers 12x Stainless Dome Nuts(these just tidy up the usual ugly nuts and bolts that come with the engine) SR20ve Exhaust Gasket Nismo Thermostat S/H Thermostat Housing S13 Dipstick ( engine didn't come with these) Sard type RJ Fuel Pressure Reg 2x AEM Fuel Filters AEM Pencil Coils Plazmaman Throttle Body (proper 90mm, originally was going to purchased a Q45) So if everything go to plan the following weeks should see us starting on the car. Some of the things that on the to do list for now are... Inspect old engine (Now some of you may have read that the originally excuse to purchased this new engine because the old one blew...well we not entirely sure about that. Will keep you guys posted, if anything we might be able to salvage it for some coins) Remove old engine, gearbox and ancillaries Clean up engine bay Cut and weld new front tubs (hopefully will be here end of next week) Respray engine bay Replace new engine bolts and nuts with new stainless nuts Redrill exhaust manifold to match ve port Ceramic coated exhaust manifold and turbo rear housing. |
#156 |
Got bored one day so decided to removed some of the body panels to make our life abit easier come this weekend when we start work on the car.
Front end last pic of the old engine. ![]() ![]() Side fenders ![]() There practically a 1mm gap there, this is with 6 castor. ![]() Also received my front tubs today, they look pretty gross on photos but that because of the wire brush treatment. ![]() ![]() ![]() ![]() |
#158 |
^^^ I wish...I'm enlisted a mate who will be helping me with the car. It's actually quite convenience since he abit of jack of all trades ie parts shop, custom fabricator mechanic and auto electrician lol.
#159 |
Epic day...we started at 8am with Taark arriving with all the necessary gears to pull the motor out. All in all we did the whole thing within 7hrs....the man is so meticulous and efficient it's amazing :thumb:.
Initially we start going over the old motor to see what has been giving the miss firing, which back then I was told that the engine has grenade itself by a certain workshop. The engine kick over the first go with no obvious noise or miss firing :wtf1: While checking over Taark found that there were some earthing cables that weren't done up properly. On removing one of them the car immediately start miss fire (the exact same symptom that the car been doing the last few months). Anyway we'll be open up the sump and have another looksie to be sure, but going by what we have seen it could be that the loose earthing has cause one or more of the coils to fail causing the miss fire. Anyway on to the photos. Taark arrived with some of the parts... 20v cas, sard fpr, 20ve exhaust gasket, cusco engine mounts, plazmaman tb etc. ![]() 90mm Plazmaman TB. ![]() ![]() A rough demonstration of the difference in height between the nismo and cusco EM. We'll also mod the brackets to lower the engine a further 5mm in the hopes for top clearance. ![]() The man himself. ![]() Up ![]() Up ![]() and away ![]() ![]() All the part that we have removed ![]() And this is the result ![]() |
#160 |
![]() Join Date: Sep 2004
it's amazing how much the s15 engine bay looks exactly like the s14 engine bay, front core support and everything. the bumper support for the headlights looks like the only bit that's different.
#162 |
It just p..s me off when workshops suppose to help you out, but all they do is after your money and do dodgy works. Funny things is they all are supposedly reputable shops. Oh well what can you do.
Next time we get tackling the engine bay. |
#165 |
pretty much identical chassis. shame, they could have released in the us.
@pwrmves14 |
#167 |
So we've got some more stuff done, niggly little things but need to be done regardless.
Machined VVL solenoids ![]() The Mazworx intake manifold come with grooves rather than using gasket for sealant, unfortunately they didn't come with the rubber orings, so we got some make for it. ![]() ![]() And here some pics of the AEM fuel filter, pencil coils and some NGK plugs ![]() ![]() ![]() |
#169 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
You had to make the o-rings? How did you go about that? They look pretty prefect. Did you call them and ask what you were supposed to do (seems like with a manifold that costs as much as that one does they would provide all the necessary bits or have another plan)?
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#170 | |
#171 |
![]() Join Date: Oct 2006
its all the little stuff that adds up - I do like that intake manifold a lot though - I went with the xcessive one - it sucks btw.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#175 |
So we started the day thinking that we could get the tubs in fully welded and then may be an undercoat for the engine bay, that certainly not the case. It turn out that there a lots of differences between a 180sx and an s15 front tubs. There were a lots of cutting and trimming and tacked and retacked. Then since Taark using a Tig so there was a lot of frustration with the sealant causing contamination in the welds, however Taark eventually got them in there Alleluia Alleluia.
Really feel sorry for the man, but by the end of it all he did an excellent job for a first timer. So if anyone contemplating of getting these tubs for their s14/s15 then get them as an individual since there will be some mods that need to be done to get them to fit. Otherwise the quality of Rex Kelway Tubs is :thumb: The points of no return. ![]() ![]() ![]() Driver side ![]() ![]() ![]() Passenger side ![]() ![]() ![]() ![]() ![]() Scrap metal anyone? ![]() Scrubbing issue? Pshhhh ![]() |
