Old 01-07-2012, 05:42 PM   #17971
deolio
deolio's Avatar
Originally Posted by c4lvin View Post
It still applies. Obviously if the same manufacturer already makes sidewall differences between models, why would it not apply to other manufacturers to the same size tire? It's the same thing. YOU PAY ATTENTION.
shut the fuck up.
Old 01-07-2012, 05:43 PM   #17972
c4lvin
c4lvin is an unknown quantity at this point
Originally Posted by deolio View Post
shut the fuck up.
yumadtho
c4lvin is offline   Reply With Quote
Old 01-07-2012, 05:46 PM   #17973
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
You're a fucking idiot.
He asked if there's a difference between a Toyo T1R and a Federal 235. There is. You said there wasn't and you're wrong. Shut the fuck up.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 01-07-2012, 05:47 PM   #17974
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
http://www.federaltire.com/en/images...ec/spec595.pdf
here is a spec sheet where you can find a 225/45/17 federal.
notice how its fucking bigger.
after all your gibber jabber about oh the sidewall may look blah blah but theyre the same width.
CLEARLY you need to shut the fuck up.
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 01-07-2012, 05:47 PM   #17975
c4lvin
No, you're just angry because you guys are actually wrong.
Old 01-07-2012, 05:50 PM   #17976
c4lvin
Section width is .2" wider than a 512 or 912, yes. .1" variance on each side is negligible.
Old 01-07-2012, 05:52 PM   #17977
revat619
Retired General
revat619's Avatar
angry? No
amused by your ignorance? Very.
www.Jspec.com
Old 01-07-2012, 05:53 PM   #17978
c4lvin
angry? No
I'm ignorant? Pot, meet kettle.
Correct usage of the word "narrow" would have solved this like 10 posts ago.
Old 01-07-2012, 06:00 PM   #17979
ILoveJDM
federals run wider
DODOlogic.ca
Old 01-07-2012, 06:01 PM   #17980
c4lvin
I love your pecs bro. You work out?
Old 01-07-2012, 06:03 PM   #17981
!Zar!
!Zar!'s Avatar
Federals run wide.
Every manufacturer measures their tires differently.
The same goes for shoes. Try some Nike's on, then go try on some Converse Chuck Taylors. Same, 'size' different fit.
Old 01-07-2012, 06:05 PM   #17982
c4lvin
No, shit, sherlock. Sidewalls are inclusive of fit on wheels. Unless if you're rubbing on the actual tread, you're rubbing on the sidewalls. Beefier sidewalls = more rub, thinner looking sidewalls = less rub.
Again, correct usage goes a long way.
Old 01-07-2012, 06:07 PM   #17983
Lovely Idol Inc.
Banned from the Marketplace
Lovely Idol Inc. is an unknown quantity at this point
Send a message via AIM to Lovely Idol Inc.
Looks like a whole lot of who gives a flying fuck in here, you're all fucking stupid so someone get sick on some fitment please.
FYI, I fucking hate all of you
Lovely Idol Inc. is offline   Reply With Quote
Old 01-07-2012, 06:36 PM   #17984
WindyCity
WindyCity is a well-known jackass
um... back ON TOPIC retards.
varrstoen polished
18x9.5 +12 15mm spacer
225/40/18
18x10.5 +15 30mm spacer
245/40/18
30mm front fenders
50mm rear fenders
WindyCity is offline   Reply With Quote
Old 01-07-2012, 06:38 PM   #17985
towlie
This is dumb, of course the same tire sizes will varie slightly from manufactorers.. Compounds, mold, etc.
Btw all your examples suck, 512s and federals?
Old 01-07-2012, 06:42 PM   #17986
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
There are definitely differences in sidewalls but my 235/40 NT05s were both wider and taller then my 235/40 Azenis. Both unmounted and mounted on the wheel.
There are some general trends with tire manufactures. As in Federals typically run a little wider then other brands, their sidewall differences depend on the sized tire you get - as their 215/45s have taller sidewalls then 'normal' and their 215/40s have shorter sidewalls then 'normal, but bother run a tad wider then 'normal'. Falkens have a different sidewall shape for sure but also run narrower, I have measured this myself.
I don't have any experience with Toyos though, my gut says they run narrower based on some images I've seen but I'd like to hear from someone with experience.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-07-2012, 07:00 PM   #17987
Lovely Idol Inc.
Falken's a fucking dickhead, they don't stay with a common thing. All of their tires are super different from each other.
Old 01-07-2012, 07:03 PM   #17988
deolio
deolio's Avatar
i had some 265 pirellis that were wider than 275 continentals. both 35 series. shit was crazy.
Old 01-07-2012, 07:27 PM   #17989
c4lvin
Too lazy to argue again, so here's another pic of what I am working on.
Old 01-07-2012, 08:23 PM   #17990
Wake
Wake's Avatar
Page 600 fucking sucked.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 01-07-2012, 08:31 PM   #17991
19kouki98
19kouki98's Avatar
19kouki98 is an unknown quantity at this point
19kouki98 is offline   Reply With Quote
Old 01-07-2012, 09:18 PM   #17992
Lovely Idol Inc.
Car doesn't even have tires yet and you are arguing some shit that no one cares about other than you?
Old 01-07-2012, 09:22 PM   #17993
c4lvin
Oh yeah, forgot I needed tires to know about tires.
Old 01-07-2012, 10:27 PM   #17994
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
boo boo whack page
this should make things better
http://www.youtube.com/watch?v=http://www.youtube.com/watch?v=LAo-DmzdvK0
matts13vert is offline   Reply With Quote
Old 01-07-2012, 11:02 PM   #17995
s13silvia_R
s13silvia_R's Avatar
s13silvia_R is making a name for him/her selfs13silvia_R is making a name for him/her self
lol that vid is jokes. matty post more of your vert dude.
s13silvia_R is offline   Reply With Quote
Old 01-07-2012, 11:08 PM   #17996
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
^^ video made my day lmao
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 01-07-2012, 11:54 PM   #17997
90240sx07
90240sx07 is an unknown quantity at this point
http://www.youtube.com/watch?v=VCjKCZysJqY
Hellaflush Pwns Joo - YouTube
lol gotta love moto iq
90240sx07 is offline   Reply With Quote
Old 01-08-2012, 01:49 AM   #17998
ABACABB
ABACABB is an unknown quantity at this point
300* agreed!
ABACABB is offline   Reply With Quote
Old 01-08-2012, 08:55 AM   #17999
WindyCity
page 601 sucks too. might as well close the thread.
varrstoen polished
225/40/18
245/40/18
30mm front fenders
50mm rear fenders
fitment is better than it looks
Old 01-08-2012, 09:54 AM   #18000
EhrikETFG
EhrikETFG's Avatar
EhrikETFG is an unknown quantity at this point
put the wing back up
EhrikETFG is offline   Reply With Quote
