07-02-2015, 02:29 AM | #18421 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
theres a lot to the picture youre not mentioning... |
07-02-2015, 09:00 AM | #18422 |
The vacuum line on the bottom of the throttle body cracked on my ka24de. My question is if the restrictor pill is necessary to have or can I just take it out. Thanks!
07-02-2015, 04:55 PM | #18425 |
Ok, clutch question on s13 sr20 red top transmission. Car is sometimes not wanting to go in any gear when stopped. Usually I'll get it to go in 3rd and then I can bump to 1st to start moving. Today was the first time when I pulled back in to the driveway, waited for garage door to open and the car wouldn't go in gear. Clutch pedals I da felt normal to me, but when is push in to 1st gear the car started moving forward a bit. After a few tries it acted normally again I could pull in.
I'm guessing this is the slave cylinder going? |
07-02-2015, 05:01 PM | #18426 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
that is called clutch creep. either your slave or master cylinder is shot or (most likely) your clutch is WAY out of adjustment. if youre one of those guys who runs their pedals engagement almost at the floor, you need to properly adjust your clutch.
get under the bottom console with a 12mm wrench and a flash light. break the tension on the master cylinder input rod, start turning the rod so it pushes the clutch AWAY from the floor (while youre turning it, if you watch the pedal it will slowly go away or toward the firewall). your engagement so be no less than an inch from the floor. more play in the pedal is better than less! clutch creep means youre burning your clutch out. |
07-02-2015, 05:33 PM | #18427 |
Ok thanks. My clutch does its engagement work about halfway down, it's fully disengaged before it hits the floor. I've been running that for 4 years now. So I'm guessing the Slave is the issue. I check my fluid, it's still where it always has been but it's dirty looking.
07-02-2015, 07:31 PM | #18429 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
07-02-2015, 11:30 PM | #18430 | |
I've had urethane rack bushings, the adjustable arms you mentioned, and Moog rod ends for years. Otherwise, everything is factory, including the LCA's. I asked about the clock spring and the front coilovers because those are the things that were changed out immediately prior to the problem. I also did a 5-lug swap with OEM parts, but the front requires no disassembly of the steering, just the hub itself. For those who don't feel like going back a page- my steering won't return to center. Alignment is on point. |
07-03-2015, 08:05 AM | #18431 | |
If you get a steering wheel hub puller(Harbor freight has a set for under $20) MAKE CERTAIN your wheels are as perfectly straight as possible before starting. Remove the steering wheel, and 'reclock' the HUB to correct center, then put it all back together. If your issue is suspension related, my question is HOW THE FUCK DID IT GET OUT OF THE SHOP? And also, DID they even test drive it? TAke it back, make them ride wiht you and SHOW THEM if it on them. If it;s on you, well, you got something wrong, look hard, find it, fix it, get it aligned again
07-03-2015, 08:59 AM | #18432 | |
I've wondered if maybe my rack is shot but will do ball joints in a week or two and see what happens. |
07-03-2015, 09:07 AM | #18433 |
I won't call it metallic but it's a tad bit of milky and is dark. I think I'll toss a z32 slave in any put new fluid through it. I have upgraded clutch so the larger slave should make the pedal feel better.
07-03-2015, 06:48 PM | #18438 |
s13 clutch pedal in s13 240
Can you use the s13 clutch pedal in a 240? I just ask cuz when i looked it up nothing came up. There also is alot of s13 clutch pedals on ebay, so i figured i might be able to save some money.
They're in the same order for RHD so it should work right? |
07-04-2015, 10:28 PM | #18441 |
Trader Rating: (18)
Feedback Score: 18 reviews
96 240, s13sr.. Any issues with leaving the evap line unhooked on the engine bay? I dont notice any issues so far with doing it other then the tank never having any pressure in it when I take off the gas cap..
07-06-2015, 07:56 AM | #18442 |
Gas tank never has pressure! it has a vacuum. What you hear when you open the gas tank is a inrush of air into the tank, not out. Besides it smelling like gasoline and an occasional fire in the engine bay, you are good to go! If you are not going to hook it up, then remove the lines completely or disconnect the lines at the gas tank so the vapors (you know, the flammable part of the gasoline) escape as far away from the hot engine as possible
07-06-2015, 09:21 PM | #18447 |
Question and quick info.. I'm about to do an RB26 swap in my s13. I've done an RB25 swap and used a GTS-T r33 crossmember to s13 with a syko mount kit. I just ordered an R32 RB26 clip.
I hear the crossmember on the GTR sits different so that means I would probably need a longer driveshaft if I use the syko kit again... Are they different? |
07-08-2015, 02:57 PM | #18449 |
07-08-2015, 11:01 PM | #18450 |
I installed tein h-tech springs on kyb gr2 that were on the car already about 6-8 months ago and the rear passenger side looks like it's at stock height in person. I tried to redo the rear passenger shock/spring to see if I missed anything but nothing changed when I put it all back together. Anyone got an idea why the passenger side is so high? Its like 2-3inchs over rear driver side. I also have aftermarket arms but I installed them a few months after the springs.
