#1863 |
Anybody got a power steering cooler with their jz swap?
I'm wondering if I add one, do I need a thermostat for it, and what size to buy, where yo mount, etc...
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#1865 | |
618 whp tuned by alpha |
#1867 |
![]() Join Date: Sep 2011
![]() Feedback Score: 10 reviews
for people using cheaper [ebay] T4 tubular manifolds what are you using? im stuck between
CXracing [newer?] turbo manifold: Cxracing Thick Turbo Manifold 2JZGTE 2jz GTE 98 05 GS300 Swap T4 11 Gauge | eBay or this older & cheaper manifold: Toyota Supra 93 98 2jz GTE 2JZGTE MKIV Turbo Manifold | eBay hopefully some of you have experience with either, i just want to know if there will be any clearance issues in my S13. either one i go with ill be replacing the wastegate flange for 44mm tial mvr waste gate. Also E85 people share your fuel setups!!! |
#1868 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
@Babilla.....I could see why Omar. I was using SolidWorx to simulate what a triple Walbro 255 would flow like and based on the fluid dynamics assessment in the program, there is a great chance of cavitation with that setup and the risk increases with more efficient pumps like your triple Denso. Makes sense why you switched your setup. The stupid design of our oem fuel tank and the small space between the triple pumps once installed will not create for a good scenario. If I need any more pump than the dual 340 setup I have I will be going with a single and ditching this setup. Much easier to locate an issue with 1 capable pump versus a more elaborate setup.
#1869 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
#1874 |
Can you please tell me which pin you had to use? Does the fuel pump prime for a couple seconds in acc postion (with engine off) or is it continuous?
wilbo666 [licensed for non-commercial use only] / 2JZ-GTE JZS147 Aristo Engine Wiring The only pins I can see by a quick skim were the fuel pump controller and the diagnostic. |
#1877 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Should I cut and weld that smaller nipple on the new GE coolant pipe?
![]() I bought this line from a fellow member - It appears to be too long and may have the wrong type of hose ends (straight + 90deg). Is there a problem with running the line like so or should I scrap it and get another one? ![]() ![]() Thanks
#1880 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
I think the drain for the turbo is usually clocked at more of an angle and the 90* fitting comes off of the turbo and the straight fitting goes to the block. Your setup looks perfectly fine though.
#1882 | |
Thanks guys
#1885 |
![]() Join Date: Dec 2009
I know this maybe a stupid question but is there anything else you need to do besides having the wiring service done when swapping a 1jz into a Automatic S14.
#1886 |
Check out Di-Devol's build thread. He's doing a 1jz with r-154 or Flicktitty's thread - he did a 2jz auto both have tons of great info
