07-24-2008, 02:34 PM | #1891 | ||
Specs are high disk front (max brake clearance) and super low disk rear (max lip) AME Shallen LX in Diamond Machine Cut finish Quote:
235/45/17 is WAY too tall of a tire 225/45/17 technically is a bit tall as well I think 215/45 all around provides the best options, because not only can you swap fronts to back and so forth, but also makes clearance easy (versus say a 235/40/17), and is a very affordable and common tire size (especially if you run Federal 595's for example) I haven't got any services from Autobacs before But I always mount my wheels and tires at City Tire right now, they are in South Gate off the 710 (www.citytireonline.com) Tell John or Brian that Logan referred you and watch the magical treatment begin!
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us! |
07-24-2008, 03:32 PM | #1892 | |
07-24-2008, 05:00 PM | #1893 |
215/40/18 fronts 235/40/18 rears i like it wish i would have gone 225 in the rear but its all good.
HUSKY HAULERS!! breaking axles since 2007 CITY TIRE ONLINE |
07-25-2008, 02:09 PM | #1894 |
18X9.5+12
18X10.5 -8 50mm fenders -2.5 deg Rub to fit |
07-25-2008, 06:22 PM | #1896 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
uh oh...i got em on the car now (still need to play with camber and toe a bit...im sans fuel injectors at the moment so the car is kinda stationary)
cant wait to get em out in day light and take a few photos of em |
07-26-2008, 04:48 PM | #1898 |
Front:19X9 255/35/19 (20offset)w:20mm spacer
Rear: 19x9.5 275/40/19 (15offset)w:25mm spacer http://i295.photobucket.com/albums/m...rifting/Q1.jpg http://i295.photobucket.com/albums/m...rifting/Q4.jpg http://i295.photobucket.com/albums/m...rifting/Q6.jpg http://i295.photobucket.com/albums/m...rifting/Q7.jpg http://i295.photobucket.com/albums/m...rifting/Q8.jpg http://i295.photobucket.com/albums/m...rifting/Q9.jpg |
07-26-2008, 09:28 PM | #1899 |
damn man iwant more pics!!try and get out of the garage!!!
" NEO VVL BABY FTMFW!" Originally Posted by shagspeed Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines |
07-28-2008, 11:40 AM | #1900 |
Cheapo China 18x10 all around, I cant remember but I think offset is +22
front 235/40 Falken Ziex, 15mm bolt on rear 255/40 used, 25mm bolt on When I get my front studs in I will use a 10mm spacer. Lots of space I still cant decide what rear fenders to get..
AERO-K GARAGE |
07-30-2008, 01:38 PM | #1902 |
255/40/17 rt615 dumped on stances basics... idk camber or anything. 17x10.5+26 i think. maybe +24 gona go get a 5-7mm slip on spacer pass side rubs but drivers doesn't? don't understand that. |
07-30-2008, 01:50 PM | #1903 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
your camber or toe is off...also might be from the roll and pull you did...but get the camber and toe set up correctly and that problem will more than likely go away (usually its a toe problem) |
07-30-2008, 03:13 PM | #1904 |
Front fitment for now still on jacks thanks to a faulty brand new fuel pump
17x9 +5, 225/45 Feddies. 215/40 RT615s by next week. Cell phone pics
Slide 'n Hide -'72 240z LS1 project |
07-30-2008, 03:24 PM | #1905 | |
i was thinking maybe just running a 5mm slip on just so that it clears for the time being and getting it aligned. only suspension piece i have are coil overs tho. wouldn't i need rucas and stuff like that so it can be set.? full car pics coming soon............... -------------------------------------------------------------- more camber up front coming soon... she's just chillin now til an ignitor chip comes in. |
07-30-2008, 09:05 PM | #1906 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
17x9 +5, 17x10 +19 215/40 fronts. 235/40 rears. 4* camber up front. 3* camber in the rear. Rolled fenders only(heat gun + hammer) No pull. |
07-30-2008, 09:29 PM | #1907 |
CrimsonRockett
i really dont know how you guys get so flush in the front because mine is about that low yet when i make turns the tire likes to touch the fender... |
07-31-2008, 05:57 PM | #1914 |
i got some new wheels coming in and i'm curious what kind of fitment issues i will have.. i feel like i'm going to have many.
first off the front are 18x9 +32. That was the lowest offset they offered. I have a BBK also as well now.. just curious on how much of a spacer you'll think i need. i was thinking 10-15mm. The rear are 18x10.5 +25. I have stock fenders rolled so maybe a good pull would do it?
95 SR Zenki | @ e_form daily - A34 Maxima | A36 Maxima |
07-31-2008, 06:27 PM | #1915 | |
08-02-2008, 07:57 PM | #1917 |
The Architect.
08-02-2008, 08:15 PM | #1918 |
2015 Subaru Outback Overlander - Wagonofdoom |
08-02-2008, 08:50 PM | #1920 |
The Architect.
Check out the post pics of your car thread.
And, my specs are just a few posts above. |
