03-25-2016, 01:01 PM | #19471 |
quick question I bought bride digo II seats im just worried if I buy the bride rails it will sit too high on the 240 anyone have these seats on their S14 and if so what rails did you get and did the seats sit low like oem.
thanks |
03-25-2016, 03:30 PM | #19475 | |
Probed the TPS and it's at .5v at idle, and around 4v at WOT. I know the spec at idle is .45v but I couldn't seem to adjust it any lower than .5v |
03-25-2016, 05:20 PM | #19476 |
Quick question, is there a shorter option for the stock sr20det t25 compressor outlet? My hot pipe fitment is so bad. My go to is to find a shorter compressor outlet but if not possible ill get a good hotpipe. Thanks guys.
03-25-2016, 07:57 PM | #19480 |
Ok list of mods and yell at me after
S14 sr20det Fmic S15 dbb t28 Walbro 255 Nistune Z32 maf-on its way 740cc Tomie injectors -will be on b4 tune Nismo fpr-will be on before tune 3in turbo back exhaust What number would I be able to push with these mods, it sits at 212hp without maf injectors and fpr. Also is a fuel rail needed when upgrading the injectors and fpr? Thanks in advance I'm just looking for a reliable 290-300hp Is that achieveable? |
03-25-2016, 08:14 PM | #19481 |
they're both 10mm and the same thread, I don't see any reason why they wouldn't work.
I recently used some ka pressure plate bolts on my RB, pretty sure everything would be fine, as long as you use all of them or use a ka bolt and make sure the bolt opposite is a ka bolt. shouldn't matter but that's what I did when I snapped one. Of course torque them down to be pretty equal to all the others. |
03-25-2016, 08:45 PM | #19482 |
03-25-2016, 09:50 PM | #19483 | |
http://zilvia.net/f/showthread.php?t=626306 dorki was on E85, the 2nd person, my pal, was just on pump, and I'm not sure what fuel the 3rd person was using. As for an upgraded fuel rail, it's not required for your power goals. The stock one is fine up to 400whp. |
03-25-2016, 10:13 PM | #19484 |
I am not slammed but during autocross, in the tight corners and transitions, the coilover compress enough that the wheel hits the wheel well and causes me to bounce. I had to raise the car up to remedy the problem. I want to go lower but have a stiffer suspension to keep from rolling. I'm not sure if 10/8 was too aggressive or if I should do 9/7 or something.
Latez. Sent from my SGH-T889 using Tapatalk |
03-26-2016, 12:26 AM | #19485 |
Ok WTF:
Bought S14 with claimed "Z32 VLSD"... took apart rear end. In fact does have z32 vlsd. Noticed, axle just kinda fell out. (Don't recall which). Removed axles, cleaned and reassembled. Nothing fits right. Axles aren't all the way into the diff. I'm confused and wondering WTF. Upon research, the current axles I own, are OE 6 bolt open diff S14 axles.... which does not work. (Rear undercarriage was nasty, greasy, etc.).. makes sens now So it looks like I have 2 options: Get 95+ J30 stubs (6 bolt, 2x3) Or get VLSD complete s14 axle assemblies. (5 bolt, but lengths are right?) Any thoughts here? Little pissed about this, lease ends in 30 days :/ |
03-26-2016, 09:27 AM | #19486 | |
If you really want to set your car up right, go to a track shop, and have the thing properly set up, corner balanced, and adjusted. Your lap times will thank you in huge amounts
03-26-2016, 01:55 PM | #19487 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
how old are your Cusco dampers? have you tried turning up the damping on them? what size wheels/tires are you running? |
03-26-2016, 02:01 PM | #19488 | |
Thanks, Latez. |
03-26-2016, 02:38 PM | #19490 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
03-26-2016, 03:02 PM | #19491 | |
Latez. |
03-26-2016, 08:08 PM | #19492 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
With that said, set engine to TDC, line marks up on the distributor, and send it in. Quote:
03-27-2016, 04:11 PM | #19493 |
Does anybody know what AAC% is supposed to be at idle? Ive read a lot of different answers.
Mine sits at 8% on a completely warmed up engine. Timing is correct at 15btdc(checked with a timing light and put in to base idle mode via NDS) and idle is at abour 850rpm. From what ive been reading, i believe my aac% is too low |
03-29-2016, 09:31 AM | #19494 |
Thinking of using an MTX-L 0-1v output to simulate the stock narrowband O2 sensor on my s14 SR20 ECU but I read somewhere that the ECU will check for the presence of the sensor's heating element before using it's input (rendering the simulation useless)
Is that true? |
03-29-2016, 06:40 PM | #19495 |
Does anyone have a picture of the bolt to secure this bracket on the kouki bumper reinforcement? The standard m6 bolts don't have a large enough washer.
http://imgur.com/bfK2TBK?r |
03-29-2016, 07:03 PM | #19496 | |
03-30-2016, 09:54 AM | #19498 | |||
Trader Rating: (58)
Honestly, I'm not even sure what is considered 'normal', but in the other side of things, if it's working and not being wonky, I'd almost not worry? I just looked over my datalogs and never once even ticked the box to check AAC value BUT I then looked at my friends cars (BlankZenkS14 on here, Kyle) and his seems to be around 50% at idle, only moving between 45 an 65% through the revs Quote:
Just get a bolt and buy some 'fender washers'
03-30-2016, 10:01 AM | #19500 | |
you dont need them with coilovers either but you will suffer from camber wear. with lowering springs, you wont notice a thing. prolly wont notice any difference in ride height either lol
