07-14-2011, 11:19 AM | #1951 | |
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
07-14-2011, 01:28 PM | #1953 | |
Autox Technician
With the current setup of 285/30R18's up front, I've got a decent amount of bump travel in order to stay off the frame rails, which would cause wheel lockups under heavy (1.2g) braking. Strut clearance is tight, but I'm not running a spacer with the strut housings that I currently have on the car (early prototype Deviant housings). I believe the newer version housings have more clearance, so it may be possible to run more backspacing/ offset. I think I might be at Meadowlands after Nats, but most likely not before.
07-16-2011, 11:59 AM | #1954 | |
07-16-2011, 05:00 PM | #1955 |
My new autocross setup, they're Hoosier A6s so they're going to be wider than your average street tire.... It's not as staggered as you would think because the 225 hoosiers are really wide... The front pokes a bit but has no room to go strut side. Hopefully just a roll but might need a little pull too. As for the rear, I'd have to look closer, but it appears the rears have both a tad of front space and back space so maybe a 295/35/17 A6 in the future?? And it might not even need a roll, but I'll go ahead and do that. And yes I need wider rims but they're both within specs of the tires. Will go wider down the road.
Rear 275/45/16 16x8.5 +37 (equivalent to ~285/295 street tire...) Front 225/50/16 16x7.5 +22 (equivalent to ~255/275 street tire...) |
07-18-2011, 08:49 AM | #1956 |
255/275 MB Weapons
Put more preload on the front springs for a track day so the front is kinda 4x4 status here. Fixed now.
95' S14 w/ SR20DET - 412hp |
07-18-2011, 08:29 PM | #1957 |
I just fapped (not really of course), that is amazing. I really wana see what you do step by step better take lots of pictures! Looks amazing just sitting on there lol.
07-18-2011, 09:37 PM | #1958 |
just bought my car and it has
vs-kf's f 18x9 +13 215/35/18 dz 101's r 5mm spacer (i think) on18x10 +0 225/40/18 dz 101's and i want to put some real tires on it, so i was thinking 275/35/18 on back and 235/40/18 on front, i know these offsets suck but....also its a '98 s14 with 12mm fenders in front and rolled and extremely pulled fenders in back |
07-19-2011, 02:52 AM | #1959 | ||
AZ Wilwoods
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
07-28-2011, 12:04 PM | #1962 |
Instead of being a scrub, why don't you calculate and post your proposed backspace, and then we can talk.
07-28-2011, 12:42 PM | #1964 |
MAX backspace Rear~ 172-179mm (you can usually add 0.5" to this)
7in backspace = 177.8 mm Pushin it to perfection!
08-01-2011, 04:47 PM | #1966 |
Why not? I'm planning to have my XXR 527's widened from 9.75" to 11" so I can comfortably run a 315mm tire in the back of my coupe.
Silvia, built 5.3 turbo, 4l80e, 9.8@142 |
08-01-2011, 05:45 PM | #1968 |
used rotas ($300) have a friend widen wheels, idk 200? lets say total 600 for some odd costs. 600 is still cheaper than wide wheels available, considering he's going to get x12.
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 |
08-02-2011, 02:01 PM | #1970 |
We'll decided on 18x9.5 +12 all aroundfor my s14. Just need to know if I can run 275 all arond or do I gotta go 265. Stock suspension till winter. Street car and some track days..auto x and strip s14 sr
08-02-2011, 02:28 PM | #1971 |
Weldcraft racing in Michigan does wheel widening for $150 Each wheel. to get 2 wheels widened is only $300. not a bad idea.
08-03-2011, 07:24 PM | #1976 | |
Do you have the back spacing on any of these wheel setups?? I guess I could post some pics of my 295's on 10" rears... |
08-03-2011, 07:25 PM | #1977 |
i read its better to run same size wheel and tire front and rear (staggered) should i do this? doesnt seem to make since and run 18x9.5 +12 all around and then run staggered tires.... most the people in here have staggered..
08-04-2011, 09:04 AM | #1979 | |
It has its pros and cons. There's more weight from the bigger wheel, but You can't rotate the wheels just like with a traditional staggered setup. Tires often have better control and more precise feel on a wider wheel (to an extent). So a narrower tire on the same size wheel up front will improve control, and in the rear you can run a wider tire for more grip. Some may do it for fender clearance reasons as well. I'd go with a square setup to maximize front grip and simplify the whole getup.
08-04-2011, 04:13 PM | #1980 |
Alright the wheels I want come n+ 12 or+ 22 i want to run a 275 out back and idc if i have to roll the fenders. but i cant find pics of anyone with 265 or 275 on a 9.5 wheel with +12 or +22 or even close to it...on the front ide like to run 18x9.5 +12 with a 255 or 265 and cant find that either. im not into the stretchin stuff so i think this is the right thread....
