#20101 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
I bought a black one from an S15
#20102 | |
Buy the engine, put it on a stand, flip it over, and replace the crank bearings and rod bearings. Cover everything you can with assembly lube. Open the valve cover and do the same, making sure the lube is on everything. Then rotate it and make sure it is well lubed before start up. OR, you can have it sit for a year in a paint shop like mine, then run it for maybe 500 miles before you have issues
#20103 | |
![]() Join Date: Sep 2015
![]() ![]() ![]() Feedback Score: 2 reviews
#20104 | |
Bearings have dried out, these are cast iron areas with steel, corrosion, which may be scuffed out upon start up is still there. It will run fine, but those bearing surfaces will sooner than later go south and you will hear a deeper bearing squeal coming from either rod or crank bearings. Just thoughts on long term issues with the iron blocks that I have seen over time, and found upon opening up to rebuild
#20105 | |
Sent from my SAMSUNG-SM-G925A using Tapatalk |
#20106 |
![]() Join Date: Nov 2005
S13 related:
What other cars use the same side mirror glass? I ran maxima ones for the blue tint but one of them fell off. If I can't find another one in the junkyard (or another s13) is there another 80/90s Nissan that has the same glass? Like an Altima or a Sentra or something?
http://www.nissanroadracing.com/ |
#20107 | |
![]() Join Date: Nov 2010
#20109 |
![]() Hey guys, i just bought a 1997 kouki. I am trying to learn more about cars thus my reason for buying it. My car threw 9 codes. it was originally a auto and it was converted to manual. The guy i bought it from did a shitty job with the wiring and said the car still has the auto ECU. i was wondering if these would be the reason most of these codes are thrown. most of the codes are emissions based. If anyone could help me out it would be greatly appreciated.
codes: P0505 idle control system malfunction P1441 Manufacturer control auxiliary emissions controls P1605 Manufacturer control auxiliary inputs auxiliary outputs P0135 02 sensor heater circuit malfunction (bank 1 sensor 1 ) P0141 02 sensor heater circuit malfunction (bank 1 sensor 2 ) P0446 Evap emissions control system vent circuit malf P1400 Manufacturer control auxiliary emissions controls P1105 Manufacturer control fuel air metering ![]() |
#20111 |
So my drivers side rear wheel clanks a lot when I hit a bump and I accelerate. It's pretty rough, the more gas I give it the harder it does it but if I keep on the gas it'll go away at higher rpms. Wheel also has a lot of in and out play when I push on it when it's jacked up. I already replaced the wheel bearing so I'm not sure what it could be, maybe the axle? Car is a 91 s13.
#20112 |
I desperately need a rear hub and bearing on my s14 SE. question, since it has ABS, there seem to be hubs online with small wiring harness attached. is this the case? will my SE with ABS require a specific hub/bearing assembly or can i simply use any of that year. any help would be greatly appreciated.
#20113 | |
Sent from my SM-G930P |
#20114 |
thank you kind sir
#20115 | |
#20116 |
My passenger side view mirror just fell off and needs new adhesive to be reattached. Has this happened to anybody and what adhesive did you guys used? I already cleaned off the old putty/poster-tack whatever adhesive that was on there.
#20117 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
#20120 |
Sorry if this has been asked before, but is a tune needed on a sr20det with walbro 255 fuel pump and greddy intake manifold? I'm asking because my car is still running very rich I think and has a hard time hitting boost. Also if a tune is needed would a wideband and fuel pressure regulator be useful to install before it gets tuned? I'm still looking for any vacumm leaks and the ecu isn't showing any fault codes but I just thought "well maybe it needs a tune." Thanks in advance for the advice.
under cover brother |
#20121 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
an adjustable FPR with gauge should always be installed with an upgraded fuel pump as the fuel pressure being output will usually increase (with walbros, it jumps up to 55-60psi on an OE SR FPR). curious though, how do you know your car is running rich? |
#20122 | |
The color of the smoke is white but I don't think it's a blown headgasket Since I just replaced it with a stock one. Also it doesn't have a "sweet" smell to it and I'm never low on coolant. It doesn't smoke all the time and it won't smoke on a cold start or any other time I've started it. Usually white smoke from the exhaust happens when I'm sitting at idle and it idles at a solid 1500 rpm's all the time. After driving it for a while I can wipe a rag around the inside of the exhaust tip and it's it seems like there is a small amount of oil in there. I thought if its burning oil the smoke would have a blue tint to it and I'd be a little low on oil. Sorry for the way to long post but I appreciate all of your advice.
#20123 |
Hey fellow S-Chassis owners, I have kind of an odd scenario. So recently I swapped out my left and right motor mounts and while I was raising the engine I was so focused on not hitting any hard fuel lines or vaccum hoses from the firewall that I completetly ignored the fan blades. In other words while I was raising my engine from the bottom of the oil pan to get some clearance, my fan blade was gradually raising the fan shroud and eventually broke just the top left piece where the charcoal canistee hoses are routed. Other than that the lower and everyrhing else but the upper plastic piece near the upper rad broke. My question is should I worry about my water pump being damaged from my fan hitting the fam shroud as I raised it or should I disregard it since it takes little to no force to break plastic. None of the fan blades nor the top pieces of the fan were damaged while it was being raises against the shroud. I just don't wanna have a pully being put of balance and causing damage to it but visibly I see no problem with the pully or fan clutch
#20125 |
Ok cool. Pretty much what just broke was the upper part of the shroud because of tha fan raising it and eventually cracked it due to the force of the blade pushing it upwards. I let the car idle for a while and the temp stayed where it should be (under the white tick mark on the temp needle gauge). Just wanted to take precaution
#20127 |
So I bought this 240 that the PO overheated because of coolant hose under the intake mani dripped out coolant. I'm worried about a blown HG. The oil is milky and there is nothing under the oil cap but when I took off the intake mani I saw coolant in one of the valves. Should I just replace the HG since I already took off the intake mani or just see if it's fine? I'm probably gonna swap the HG anyways but just wondering.
#20128 | |
#20130 |
