Old 03-30-2011, 06:55 PM   #2011
TheClutchKicker
TheClutchKicker's Avatar
TheClutchKicker is an unknown quantity at this point
Originally Posted by chiboy002 View Post
BLM
discontinued as of like 06 lol
I guess that just went to the RARE section lol.
TheClutchKicker is offline   Reply With Quote
Old 03-30-2011, 08:00 PM   #2012
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Are those my old BLMs?
http://bhworld.wordpress.com/
Old 03-30-2011, 10:17 PM   #2013
chiboy002
chiboy002 is an unknown quantity at this point
no sir
msglnght
street dancer.
GLEAM
Old 03-30-2011, 10:18 PM   #2014
lflkajfj12123
No, I still have yours King of Dope.
Old 03-30-2011, 10:22 PM   #2015
Brian
Brian's Avatar
Trader Rating: (54)
poopie !
Old 03-30-2011, 10:25 PM   #2016
lflkajfj12123
Bone collector
Old 03-31-2011, 09:26 AM   #2017
mikefc
mikefc is on a distinguished road
here's a better interior picture. Now with more SWEATPANTS
Hey man, neat interior. Now go drive.
MOON LIGHTER
mikefc is offline   Reply With Quote
Old 03-31-2011, 09:56 AM   #2018
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Hey chiboy, what'd you use to mount the gauges in the din pocket? Are the gauges 52mm? I have 3 gauges I need to mount, and I want to do it in the same spot you did, but idk what to use to go about this.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 03-31-2011, 10:11 AM   #2019
ONE80ESSEX
ONE80ESSEX's Avatar
ONE80ESSEX will become famous soon enoughONE80ESSEX will become famous soon enoughONE80ESSEX will become famous soon enoughONE80ESSEX will become famous soon enough
ONE80ESSEX is offline   Reply With Quote
Old 03-31-2011, 10:33 AM   #2020
whitefedorafilms
whitefedorafilms's Avatar
whitefedorafilms is an unknown quantity at this point
^^^^ some serious cracks on that dash. thats gonna be a whole lotta hello kitty bandaids.
whitefedorafilms is offline   Reply With Quote
Old 03-31-2011, 10:37 AM   #2021
chiboy002
i can't afford track days cause of impulsive spending
i will this season though
for now i just wedged those things in there lol
theyre 60mm so they fit pretty snug without anything cause its pressed against the radio but i bought some 1'x2', 1/8" thick abs plastic from amazon for like $7 so i can make a small din slot cover thing. I just gotta make it on a cnc machine
street dancer.
GLEAM
Old 03-31-2011, 10:40 AM   #2022
Irresistible
K that's what I was thinking of doing, then dremeling out the holes or using one of those drill things that electricians and plumbers use to drill out holes for pipes in walls. To me, it won't matter how clean it looks because I'll wrap it in some sort of fabric. Where did you pass the wires through from the sensors to the gauges? I have yet to establish that.
And for those that can't afford track, Stupid and Illegal Message Deleted
Old 03-31-2011, 10:42 AM   #2023
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
It's called a hole saw
Sears: Online department store featuring appliances, tools, fitness equipment and more
I even found a 60mm one for you.
kyles1988 is offline   Reply With Quote
Old 03-31-2011, 10:49 AM   #2024
Irresistible
Originally Posted by kyles1988 View Post
Damn, what a sweetheart. LOL. I forgot what they were called, but my dad has a bunch of them. My gauges are actually 52mm, but thanks anyway.
52mm for anyone that needs it: http://www.sears.com/shc/s/p_10153_1...1&blockType=G1
Old 03-31-2011, 11:38 AM   #2025
TheClutchKicker
Originally Posted by ONE80ESSEX View Post
Damn this dash has been chewed on. lmao
Old 03-31-2011, 04:04 PM   #2026
chiboy002
for the sensors, if you pull your passenger side kick panel you can see where it feeds through from where the fender is. Pretty much just cut a hole in the grommet and feed it through there so water doesn't get into the cabin, then through the triangle cut out and to where ever it needs to go. It's where the passenger harness feeds to the ecu.
it literally took me 5 minutes to feed it through, when i had previously expected like an hour of work
When you cut the grommet cut it towards the top so the sensor wires go over the harness to prevent rubbing, then pull that shit tight and ziptie it to something inside to keep tension on it so it won't sag and rub
street dancer.
GLEAM
Old 03-31-2011, 07:06 PM   #2027
Irresistible
Thank you sir.
Old 04-02-2011, 11:01 AM   #2028
bradyd15
bradyd15's Avatar
bradyd15 is an unknown quantity at this point
bradyd15 is offline   Reply With Quote
Old 04-02-2011, 12:25 PM   #2029
chiboy002
LOL what the hell did you do to your dash/console/door panels
is the tennis grip any comfortable?
street dancer.
GLEAM
Old 04-02-2011, 12:30 PM   #2030
ZilviaKid
ZilviaKid's Avatar
ZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the rough
i have never in my life seen a worse looking interior than that.
how does that even happen?
2004 Nissan 350z
2002 Nissan Silvia
ZilviaKid is offline   Reply With Quote
Old 04-02-2011, 12:35 PM   #2031
Wake
Wake's Avatar
Ive seen much worse, but the cage looks like prison bitch asshole, and you shouldnt have flocked FUCKING EVERYTHING!
Just the dash and door panes would have been proper. Should have left all the trim plastic. Now the inside of your car looks like a shaved bigfoot.
I do like the AFC/radio/turbo timer setup tho, looks well done.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 04-02-2011, 01:44 PM   #2032
towlie
The rollcage reminds me of a lollipop.. And the dash/center console looks like bigfoots asshole
Old 04-02-2011, 01:54 PM   #2033
Wake
Wake's Avatar
I just realized it looks bad because he shaved all the vents/Climate control.
S.P.P.S. Member #00
Old 04-02-2011, 01:58 PM   #2034
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
it looks like the material they use to wrap the subwoofer boxes, i hate that stuff :/
andisan is offline   Reply With Quote
Old 04-02-2011, 01:59 PM   #2035
lflkajfj12123
He didn't even flock it, he wrapped the whole interior in some shit cloth that will probably glare way worse than the stock dash would have.
Not to mention it looks like SHIT.
Old 04-02-2011, 02:00 PM   #2036
tinys s14
tinys s14's Avatar
tinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-known
Lol looks like he wrapped the dash in trunk carpet
tinys s14 is offline   Reply With Quote
Old 04-02-2011, 02:01 PM   #2037
nathanong87
nathanong87's Avatar
i'm going to wrap my dash with astro turf.
natelife.tumblr.com
Old 04-03-2011, 05:39 AM   #2038
NismoDriverS13
NismoDriverS13 is an unknown quantity at this point
lol, i dont think it looks that bad. it looks comfy, however......the material could have been a little bit different. like full on suede or some shit alike. but to each their own!
NismoDriverS13 is offline   Reply With Quote
Old 04-03-2011, 02:08 PM   #2039
h2v7
h2v7 is an unknown quantity at this point
someone had putting green as their floorboards
h2v7 is offline   Reply With Quote
Old 04-03-2011, 03:38 PM   #2040
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
chiboy sell me your gauges are they water temp and oil pressure?
airhead is offline   Reply With Quote
