11-03-2016, 04:26 AM | #20431 | |
I love grip, the more the better, but I am only looking at some minor adjustment to metal after I get a body kit(Z fender flares), so I'll go lower just a bit.
11-03-2016, 08:01 AM | #20432 | |
11-03-2016, 08:57 AM | #20433 | |
You need to find used ones from an SE model, or order new ones from Nissan. Might be called a tension spring, but it's the metal rods that connect the two hinges. SE ones are beefier. Quick scan of nissanparts.cc turns up these part numbers: BODY HARDWARE / TRUNK LID / LID & COMPONENTS / Torsion bar Part Number: 8443265F10 torsion bar w/spoiler Right Part Number: 8443365F10 torsion bar w/spoiler Left |
11-04-2016, 08:11 AM | #20437 |
Looking into getting the Blitz Nur Spec-R for my s13 sr20, only thing is im pushing about 300whp and im trying to get up to about 330-350, and ive heard the Nur Spec becomes restrictive up before that point. Can anyone comment on this? Ill be running catless
11-04-2016, 10:11 AM | #20439 |
Sorry I guess I wasn't clear but that's not what I was asking, I'm not expecting an exhaust to actually net me anything. What I'm saying is that I've seen a couple people claim that the Nur Spec restricts flow at around the 310 or so hp mark and I'm looking to see if it'll support[/I] that horsepower level (which will come via ewg, tune, injectors) and if anyone is running that sort of power on that specific exhaust
11-04-2016, 11:24 AM | #20440 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
not sure where or how you heard that it "restricts" exhaust flow... its a standard straight thru design with (probably) standard 85mm piping. theres a resonator built into the piping with resonated muffler design. outside of the resonator, there is nothing that would cause turbulence or any sort of "restriction" (and the resonator just helps absorb sound, thats it)
11-04-2016, 11:29 AM | #20441 |
Yeah it didnt seem like it would be a real hindrance, just a couple things ive read got me skeptical. Dont want to go spend the better part of $800 on something that wont support my setup
11-04-2016, 11:55 AM | #20442 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Buying an NA KA style exhaust would be the only restriction, but even then it would still flow better than stock. Its the lack of bends and angles in the piping plus larger outlet design that gives the motor power, not always the size (though larger diameter DOES help). When exhaust gasses (much like air flow into the intake manifold) experience turbulance in escaping, this causes flow issues and will prevent the motor from breathing easily (basically expelling its waste element). Remove turbulence in the flow of exhaust and you allow the motor to breathe easier
11-04-2016, 12:27 PM | #20443 |
Guess Ill just hope I dont run into any issues with it especially with the ecv ill be running. I have a feeling ill miss the response of the straight through setup with whatever I choose Thanks for the help dorki
11-04-2016, 12:52 PM | #20444 |
Trader Rating: (26)
Feedback Score: 26 reviews
I was actually going to suggest going straight pipe if any type of restriction scares you. The only time you limit yourself is exhaust diameter. If it's too small or too many bends, this can hurt you but most designs now are pretty straight forward and avoid those types of things.
11-04-2016, 01:17 PM | #20445 |
Yeah I really wish I could keep the straight pipes, but I need something thatll pass a visual muffler inspection and be able to be quieted down enough so the neighborhood babies stay asleep...
11-04-2016, 01:22 PM | #20446 | |
11-04-2016, 01:33 PM | #20447 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
this is what im running on my car... lost a little top end power compared to my Trust PE2 i previously owned, BUT, totally worth it in that it looks 100% stock, its NOT loud under normal cruising and idle and is still a full 3" turbo based exhaust. probably my most favorite catback ive ever owned! but then again, im not into the hoonafuckboiflushlifeyo! http://www.frsport.com/HKS-31013-BN0...3_p_21407.html an older shot of my car the day after installing... recent shot with my current aero... looks 100% stock and sounds amazing my SR is pushing 12psi on a GT28 off an S15 SpecR... will work with 300+ HP as well |
11-04-2016, 01:42 PM | #20448 |
I don't know. I would lean more towards an OEM option for something like this, but you're more than welcome to experiment!
11-04-2016, 08:02 PM | #20449 |
Clutch Creaking
When I release the clutch up slowly to engage it, there is a loud creaking that can be felt through the peddle if that makes sense. It doesn't do it when you let go of the peddle fast or when you press it down. I know it's not the squeak from the spring or anything like that because I can hear it coming from under the car by the transmission. I don't have anyone around to press the peddle while I look under at the moment but I'm just wondering what I should look for when I'm under there or any suggestions. It's just a stock clutch and a stock ka transmission
11-05-2016, 04:37 AM | #20451 | |
Inline 4 with a 3" system will flow anywhere that engine and turbo can push it to, ie, 436hp if you want. In fact, any 3" system will support, not hinder your SR, same with a KA-T. Now if you are getting close to 500hp, you may want to jump to a custom 4" system, because that 3" system will in fact cause you a slight loss in exhaust velocity. Using a LS? Under 500hp? Typical 3" exhaust will be fine. Pushing that beast over 500hp, better jump up to a 4" system IF you are using big power adders. Yes, a 3" system will be fine, but if you are trying to get that last few hp at the top end, 4" is where you want to go, because that V8 us pushing equal to double your I4. I6's respond very well to 3" systems to 500hp, over that, try a 4" system
11-05-2016, 12:28 PM | #20452 |
Thats the sort of thing Im looking for, thanks redline. I was skeptical enough of, granted, the very few things id seen about it being restrictive that I thought Id ask here. Glad to have gotten some good info on it though.
Dorki that shits dope! Im not a huge fan of the way the nur spec and all the cannon style exhausts look but Ive never heard a better sounding tone on an sr. It only needs to be quiet for neighborhood startups and the odd cop spotting if Im feeling paranoid, which is why Ive got the p2m ecv. I can deal with the loud cruising but ill look into those more stock looking hks setups |
11-07-2016, 09:31 AM | #20453 |
sorry if this has been asked before but I'm in the process of rebuilding my s13 sr20. After taking off the head I noticed one of the guide pins were stuck inside of the head. I'm just wondering how to remove the pin out of the head. Thanks in advance for the advice.
under cover brother |
11-08-2016, 04:44 AM | #20455 |
It is in the most fucked up place you would ever think. Roof, behind thee driver, over the back seat. Look up Body Electric on NissanPartsDeal.com, fourth diagram shows the location
11-08-2016, 07:27 AM | #20456 | |
11-08-2016, 07:27 PM | #20458 | |
Trader Rating: (22)
Feedback Score: 22 reviews
11-09-2016, 04:28 AM | #20459 |
11-09-2016, 09:38 AM | #20460 |
Currently, my buddy is trying to set his pressure on his FPR but it will not change from 74psi. To be safe, we ran the motor and removed the fuse so all the gas can be burned in the cylinders.
Can a bad AFPR (Adjustable Fuel Pressure Regulator) be unable to change the pressure? Is there a fix?
