#181 |
Thanx man I just got my complete refund Thanx and sorry for all the trouble..... Good guy I wold buy from him again
http://www.myspace.com/break_loose |
#182 | |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Xenith Xenons - Your HID Conversion Specialists http://www.xenithxenons.com [email protected] Prestigious quality|World-renowned customer service|Speedy shipping |
#183 |
All PMs and e-mails replied to, thanks everyone
#184 |
got them in today..
cant seem to get them to work. anyone know what im doing wrong? it doesnt turn on. i got the h1 kit for the kouki..plugged all the wires and checked the connections still no power. do i have to have the engine running or something? |
#185 | |
Try switching the wires that go into the car, maybe the polarities are swapped. Also, try placing the ballasts on different sides to see if there's any changes. It sounds like you're not getting any power.
#186 | |
I tried switching the wires..tried a different ballast ..bulb..still not powering up...i'll try again later anyone got pics of an install on a kouki? it would be much appriciated |
#187 |
do you have a multimeter? check for voltage at your headlight harness...if you dont...check obvious fuses, and then check for the connector on the batter to make sure its on tight....i had that come loose once and i lost power to random things...couldn't find it....then i saw that connector on the battery was loose
#189 |
Hey guys,
Sorry for the late response, didn't even get an e-mail notification stating there were responses! Hehe.. mtx450: Thanks for giving the info when I was gone, much appreciated ![]() james5x: Glad to hear you got it to work! If you need anything else, don't hesitate to contact me. Also, pics would be great if you have the time, thanks!! I appreciate it ![]()
#190 |
here are a couple pics..still need to beam them down lower..i'll have more pics when i get them done...took this in the garage at 1 in the afternoon..so you can barely tell.
H1 4300k kit |
#191 |
Wow those pics are nice, really shows the color well in your beam pattern! I appreciate the pics man. A good way to lower your headlamps is to park 20ft away from a wall and lower the light so that the cutoff is 3 inches below how high your headlights are. So if you're headlights are 30 inches off the ground, have the cutoff be 27 inches off the ground
#192 |
#194 |
Hi,
Yes the H4 Bi-xenon setup comes with a relay harness that connects directly to your battery and also comes with a connected relay and 2 amps.
#197 |
Thanks for doing this, I appreciate it
![]() -George
#198 |
Front page has been updated with new pics of the lightout of the 6000K!
More pictures on the way! Just waiting for them to get watermarked ![]()
#199 |
All PMs and e-mails replied to, thanks Zilvia
#200 |
![]() Join Date: Sep 2005
Do all kits come with that anti glare shield? I am looking into buying some HIDs for my 97 jeep grand cherokee. I would like to keep high and low beams, let me know what you got in 6k.
Thanks
#201 | |
The 97 Jeeps Grand Cherokee shows a bulb size of 9004LL. I'm not 100% sure if that's the same as 9004 but you can double check with your dealership. For sure the 9004-series uses the same bulb for high- and low-beam though. If you wanted to keep HIDs for both high- and low-beam, you'd want the 9004 Bi-xenon setup. If you're OK with just halogens for the high-beam, then the 9004 Hi/Lo setup would be more suited for you. The Bi-xenon is $35 more and the Hi/Lo is $5 more. We have both available in 6000K ready to go! Let me know, thanks. Best, George
#202 |
Thanks, I would probably be intrested in the Hi/Lo setup. Do those come with the anti glare shields? Is there any additional wiring for these?
I will double check, I have the package from my bulbs that are currentlly in there at home. But I am away at school until this weekend.
#203 | |
#204 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
hey, i'm looking into getting hid's, i've already got h4 conversion housings, so i'm assuming the h4 hids just fit within the housings
Slip Gypsies Blog Quote:
#205 | |
Yep our Xenith H4 HIDs will fit directly in plug and play. Let me know if you have any other questions, thanks. Best, George
#206 |
#207 |
Hey guys,
My PM box got reduced in size for some reason so any questions just e-mail me at [email protected], thanks! Best, George
#209 |
For sure man
