#181 |
![]() Join Date: May 2007
bumpity bump mr. hpipro. [p.s. good thing I didnt waste my time tucking on my ka24, the motor I had ended up being garbage, now researching how to eliminate all the bullshit on an sr20].
#182 | |
![]() Join Date: Dec 2008
Trader Rating: (71)
![]() Feedback Score: 71 reviews
goodluck bud |
#183 |
I want to do a full over like you did, nothing a little more research wont fix. Get me learn'd real gud. Howd that aero come along?
#184 |
I have an S13, Silvia headlights, no heater etc.
I can get rid of both relay boxes,both OEM fuse panels and replace it with about a 12-18 Fuse box? How many relays would I need? |
#185 | |
![]() Join Date: May 2006
I've been doing a lot of custom chassis harnesses lately, but have come back to doing more OEM-style tuck-and-loom jobs on high-end cars that want to retain all their factory systems. By far the hardest system to keep is HVAC, just because there are so many different units (blower motor, mix door, etc, etc) and control is very decentralized... you end up not cutting anything out and having to re-wire the whole thing into your new chassis harness.
Like I tell everyone, no matter what car - if you read the FSM and can't instantly be comfortable with the wiring schematics, you will have a very difficult time at best, and create a nightmare that will never work at worst.
#186 |
Ok that sounds not to bad, I was in the process of relocating my panels to the glove box but what I did was cut the harness, pull it out of the engine bay, loop it around the other way and solder it back together, but now it just looks fucked and it would probably be easier for me to just start over.
#187 | |
#189 | |
What do you guys think of using this setup? 14 CIRCUIT FUSE PANEL W/FLASHERS/HORN RELAY on eBay.ca (item 110448768946 end time 16-Dec-10 09:54:24 EST) " TR-1400 Replacement Fuse Block The TR-1400 Replacement Fuse Block kit allows for just the fuse panel in your vehicle to be replaced. The TR-1400 also includes many of the great features that our complete wiring kits have. It includes:
#190 |
The generic wiring harness/fuse block setups that I've seen don't do the important stuff very well ~ you're left with one ignition relay (usually fused at 30A) to handle everything that's ignition-switched. Not ideal. Depending on the chassis, you also have problems with lights/blinkers/etc.
Aside from that, they handle the little stuff well, and usually are a compact package.
#191 |
What would you suggest then with out spending too much money? I want to be able to keep it under $300 for everything, I guess I could spend a little more for a good setup though.
#192 |
Trader Rating: (71)
thought id update my build......
scored a ka-t stuff locally and decided to take out dash again and re-wire/relocate where my gauges will go...decided that im going to ditch center vent and creat my own triple gauge pod using fiberglass stay tuned... ![]() ![]() ![]() also wired in an viper 5901 remote start system...lovin it! ![]() ditched the center and taped it with foil tape...y?? i dunno i felt like it..haha ![]() moved some of the relays to the top so their not showing underneath glovebox. ![]() i g0t very creative and modded my toplite that i never use and manage to fit my greddy mss(use as fan controller) in there w/o doing anything to much just using dremel w/cut off wheels and viola!!!!!i think it turn out perdy cool. wat ya think? ![]() ![]() |
#193 |
![]() Join Date: Dec 2003
You sir, are my hero.
My new plan is to find a dash/chassis/engine room harness out of a 91+ with power options and completely rewire my piggy as a chuki when I do my dohc swap. Then after i build a custom harness for a track car ill build a new one for my DD.
![]() **CoUpe LOve** Member #00 |
#194 |
That's supposed to be a tucked dash harness? I mean, I get that you de-loomed it and zip tied it, and I assume you cut some un-needed wiring out, but damn.
That still looks like a whole pile of stuff I don't want/need under a dash. I'd also look into relay holders that can be mounted to a plate (or that heater box you still have) rather than having all your relays free-hanging and moving. This is a custom fusebox/relay setup that I did for a SR20'd Datsun 510, retained all OEM functionality (with OEM switches, ugh) in addition to an alarm and 9 gauges. ![]() Another one, you can see the three sections of loom that converge to cross the dash (engine harness, front chassis harness, rear chassis harness) and the back of the bulkhead connectors here ![]() Are you still using the SMJ and driver's side interior fusebox?
#195 | |
Trader Rating: (71)
i am too looking for a black dash.....been hitting my local junkyards but their all junks lol...maybe ill just paint my brown dash instead. yea i didnt bother sleeving the wires since their underneath the dash...like anyones gonna be peeking thru...lol works just fine i dont feel like changing em again but thats neat idea tho |
#196 |
I have a badly cracked black dash and a HUD dash with a tiny crack on the hood above the gauge cluster. dunno if that does you any good but if you plan on flocking or fiberglassing or something over a dash I got you covered.
Hey jordan you still any kind of write up or info on the wiring of that 510? I will be doing the same thin on my buddies dime pretty soon.
#197 | |
2) Pen and paper the new electrical system, choose circuits, fuses, then wire size 3) Run wire, solder into pigtails as close as possible to connector 4) Loom everything. Loom some more. Then do some more looming. 5) Connect crappy 1960's switches to your awesome new harness, making it only slightly more reliable than it was 6) Test 7) /wrists if anything doesn't work, since you've already loomed it all (my stuff always works)
#198 | |
What wires u had to extend as for starter and alternator
#199 |
![]() Join Date: Jan 2008
keep the brown, i like it.
My Twin Scroll Gt30r Sr22det Build |
#200 |
I generally run a 100amp inline fuse in a marine fuse holder between the alternator and starter on a street car with 4ga Mil-spec wire, then 4ga back to the battery with a large fuse near the battery to protect the wire running through the car (200A-300A). Then you just loop the alternator exciter wire up to the alternator charge post and you're set.
#201 |
![]() Join Date: Feb 2010
at first i thought "this dude is nuts"..... but as i see your Results..im LIke "Wow".... Mad Props..... whish i had the patients for wiring.... well i guess i might since im building up my hatch right now.. =).....
#203 | |
#205 |
looks good
#210 |
![]() Join Date: Feb 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Damnit man. This is probably one of the best threads I've come across so far.
Thanks for all of the helpful info, and thank you Jordan for answering one of my biggest questions. Harnesses are de-loomed now and I'm laminating my diagrams.
Good at wrenching, terrible at electrical. Lord help me... HAHAHA |
