Old 01-15-2012, 06:18 PM   #181
Melonburst
Melonburst's Avatar
Melonburst is an unknown quantity at this point
Originally Posted by Tanuki View Post
The post lines up with the frame rail there, but I could be wrong. Also it lines up with the halo best there.
You're right, that is the best place for it to go. Any experienced cage builder will put it there.
Melonburst is offline   Reply With Quote
Old 01-15-2012, 10:19 PM   #182
Tanuki
Tanuki's Avatar
Tanuki is an unknown quantity at this point
Yeah for the question regarding licensing, I am probably running lap battle one more season and working on licensing as I can afford it.
Thanks for te confirmation on the cage. You guys had me second guessing for a min there.
Tanuki is offline   Reply With Quote
Old 02-07-2012, 08:26 PM   #183
Tanuki
Tanuki's Avatar
Well how about some cage updates? I think it has been a while, and this thing is almost done! Should be out of the shop on Friday!
Old 02-07-2012, 08:35 PM   #184
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
looking good so far, keep it up!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 02-08-2012, 08:18 AM   #185
Tanuki
Tanuki's Avatar
Thank you sir! I am getting excited to get this thing home so the motor can go in!
Old 02-08-2012, 08:53 AM   #186
Functiontheory
Functiontheory's Avatar
Functiontheory is an unknown quantity at this point
love it!! its cool to see a build other then a drift car, very refreshing. looks awesome cant wait to see it when its done.
check out my functional car blog,
http://www.FUNCTIONTHEORY.com
Functiontheory is offline   Reply With Quote
Old 02-08-2012, 09:07 AM   #187
jefferz
jefferz's Avatar
jefferz is an unknown quantity at this point
deleted wall of text.
S13 Coupe, S14 Kouki
Crew Chief jeff Jones Racing
jefferz is offline   Reply With Quote
Old 02-08-2012, 11:36 AM   #188
Tanuki
Tanuki's Avatar
^thanks for the wall of text, but that is misinformation, well I guess depending on what rule book you are looking at.
Look up NASA 15.6.11
Thanks
Old 02-08-2012, 12:52 PM   #189
jefferz
jefferz's Avatar
Thanks
15.6.11
Rear Braces
The main hoop must have two (2) braces extending to the rear. The braces shall be
attached as near as possible to the top of the main hoop, and no more than six (6)
inches below the top.
The braces must not contain any bends*. There must be at
least 30 degrees between the plane of the main hoop and the plane of the rear braces.
The main hoop rear braces shall be installed to form no more than a one hundred five
(105) degree angle or no less than a seventy-five (75) degree angle with the main hoop
when viewed from the top. The main hoop braces must be mounted at the rear shock
mounts or suspension pickup points
pretty sure the wheel well is not the shock mount or a suspension pick up
I own a shop and i cage cars. I know the rules.
the cross bars that are welded to that bar between the strut towers is not right either.
A friend a mine right before i started doing cages got his car done by some ghetto shop got one similiar to your rear set up. Did NOT pass tech.
Make the guy do it right.
Old 02-08-2012, 02:32 PM   #190
Tanuki
Tanuki's Avatar
Why not quote the whole rule instead of the parts you are wanting to quote?
15.6.11 Rear Braces
inches below the top. The braces must not contain any bends*. There must be at
when viewed from the top. The main hoop braces may be mounted at the rear shock
mounts or suspension pickup points (providing that the braces remain in compliance with
all other sections of the CCR). They may go through any rear bulkhead(s) provided the
bulkhead(s) is sealed around the cage braces. *There may be certain exceptions
allowed for cars that cannot possible meet this “no bend” requirement. One exception is
listed [Ref15.6.11.A)]. Other exceptions may be made (not guaranteed) if all of the
required bars meet the specifications for a vehicle in the next heavier weight
classification and the alternative design is submitted to the NASA National Office for
special allowance.
15.6.11.A Rear Braces - Exceptions
On cars where the rear window/bulkhead prohibits the installation of rear braces
(Porsche 914, Pontiac Fiero, etc.) the main hoop must be attached to the body by plates
welded to the cage and bolted to the stock shoulder harness mounting location. There
must also be a diagonal bar connecting the top of the main hoop to the lower front
passenger side mounting point (“Petty bar”). Some cars built for racing in other
recognized sanctioning bodies may be granted a waiver of this rule, however they must
show proof of compliance with the current published rules for their class.
It does not say that it is required to mount to the shock mount or suspension pick up. It says that you can mount it there. The plates that are on there cover the rule. I have done my research and there is nothing on this cage that will not pass tech.
Old 02-08-2012, 02:48 PM   #191
Prove It
Prove It is an unknown quantity at this point
It wont pass xdc , or fd. Like stated it must go to strut tower
Prove It is offline   Reply With Quote
Old 02-08-2012, 02:53 PM   #192
bb4_96
bb4_96 is an unknown quantity at this point
I didn't know he was running either.
bb4_96 is offline   Reply With Quote
Old 02-08-2012, 04:10 PM   #193
Tanuki
Tanuki's Avatar
Right. The car is being built for NASA events primarily as well as some Time Attack. The cage meets all FIA/NASA regulations.
Old 02-08-2012, 04:52 PM   #194
jefferz
jefferz's Avatar
you think it will. but it wont formula d and xdc base there rules off of FIA/NASA rules. there cage rules are direct copy of FIA/NASA rules basically.
Old 02-08-2012, 06:02 PM   #195
Tanuki
Tanuki's Avatar
I have spoken with many people including a Continental Series Crew Chief and the Director of the Wasatch NASA Chapter. No one else has said that this design will be an issue.
I do appreciate you looking out for me though. Not trying to be an ass about it at all either, just saying thanks for that.
Old 02-11-2012, 08:32 AM   #196
Tanuki
Tanuki's Avatar
Well yesterday was extremely busy.
Basic schedule:
Work: 7:30-1:30
Pull Engine from wrecked 240: 3-5
Pick up a trailer and head to cage shop: 6-8
Finish cage and bring home car: 8-12
But on the busy day was worth it. The car is now sitting in the garage, waiting for a new heart.
Old 02-11-2012, 08:36 AM   #197
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
Forget the crappy 90s car...more pics of that truck!
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 02-11-2012, 08:40 AM   #198
Tanuki
Tanuki's Avatar
this is the only other pic I have:
Old 02-11-2012, 08:44 AM   #199
irritatedmax
That thing is sickkkkkk.
Props on the SR power.
BRICKHOUSE PRODUCTS
Old 02-11-2012, 10:50 PM   #200
Tanuki
Tanuki's Avatar
^Thank you sir.
I don't have more pics of that datsun. I will try and get some soon.
I started cleaning out the interior today using aircraft stripper. I got a lot of it done, but i need to finish going through it all and then start painting. I also need to drill some mounting points for the lap straps on the harness.
Oh and the SR20 went in today. Motor was pulled and new motor mounted in less than 10 hours. Long day, but totally worth it.
Here are specs on the engine:
About the engine. I had it rebuilt at Element with
new rod bearings
stock rods
forged pistons
new head gasket
new gasket and sill kit
new s14 SR water pump (better flow than s13 water pump)
The head is stock but has new lifters
stock turbine on the engine but aftermarket exhaust manifold and dump pipe braided oil and coolant lines
stage 2 single plate clutch w/ ligthened fly wheel
Engine has a little less than 5k miles on it since rebuild. Engine, tranny, wiring harness (wired for S14), ecu, mafs, ignitor, r33 gtr intercooler w/ piping, and full exhaust.
Here are a few new pics of the cage, swap, etc. The engine needs cleaned up and the valve cover needs some love, but it is all in and solid.
Old 02-12-2012, 09:28 AM   #201
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Are you able to keep your class with this swap? Sorry if this was covered
Darren is offline   Reply With Quote
Old 02-12-2012, 11:11 AM   #202
driftwhat
driftwhat's Avatar
driftwhat is an unknown quantity at this point
Wow man that's an amazing cage build!!
I love haters!
driftwhat is offline   Reply With Quote
Old 02-12-2012, 06:35 PM   #203
Tanuki
Tanuki's Avatar
^thank you sir. I appreciate it!
Decided to get started on painting the interior. Still a long ways to go.
Old 02-12-2012, 06:37 PM   #204
Tanuki
Tanuki's Avatar
Darren,
So few people run here that they combine classes a lot. I will probably just jump into whatever class is biggest so that they can get prize money into that class. I think that a class must have 10+ cars before they start contingency/ prize money.
So for now, classing in the local nasa series should be fine. I will be running against most of my friends. Had I done the LS1 I would have moved classes though.
I may be wrong about the way they run classes, though here. Either way I will fit in somewhere and have some fun!
Old 02-13-2012, 04:57 AM   #205
irritatedmax
Is the interior paint some sort of brush on paint?
BRICKHOUSE PRODUCTS
Old 02-13-2012, 07:06 AM   #206
Tanuki
Tanuki's Avatar
Yeah it is por15 white coat. I kind of wish I'd just used spray can auto paint
Old 02-13-2012, 08:01 AM   #207
Darren
Darren's Avatar
Darren,
That's cool, i've had some dealings with scca type rules here with AutoX (we have no proper road tracks around here) so i know that changes can adversely affect your class and make you less competitive, even though the car is faster
Old 02-13-2012, 10:59 AM   #208
Tanuki
Tanuki's Avatar
^Yeah I think autox is always like that too.
Old 02-14-2012, 12:13 AM   #209
Tanuki
Tanuki's Avatar
Little bit of interior flare.
Old 02-15-2012, 06:07 PM   #210
vehicle336
vehicle336's Avatar
vehicle336 is an unknown quantity at this point
^ That's actually a really good idea. Gotta keep an eye out for what's coming up behind you.
vehicle336 is offline   Reply With Quote
