07-20-2010, 11:18 AM | #183 |
Honestly I have seen cars spool up faster and make better HP and Torque curves with a cheapo 50 TRIM T04E compressor and a smaller turbine than any of the 2871R setups.
If you want to have a great setup for spool up use a T04E 50 TRIM Garrett wheel with a .60 AR T04B ported compressor housing, then use a .48 turbine housing T3 with Stage 3 turbine wheel. At 22 PSI you should be right around 415 WHP range, even on a real dyno, like Dyno Dynamics, which is about 25% better output than most 2871R setups can reach at 18-20 PSI range. If your goal is to have a more efficient turbo than stock, with a bit more output and bolt on then I think the 2871R is a great option. But it seems like from the very beginning people have been led to believe that you just bolt on a 2871R variant and you automatically get 400 flywheel or even wheel HP. In my expereince it's a dream. Only on dyno jets, with correction runnin in the background, a lucky run or very controlled conditions. And then it's hard for it to even be replicated. On brake eddy dynos the 2871R variants only make it up to around 360 whp MAX. Sometimes 375. Which is amazing for such a small turbo. If you want a bolt on turbo with true high output capability I suggest a GT3071R with T28 flanged housing. Or even better the 3076R with T28 flange - both of these we have tuned up to the 400-430 whp range, even on pump gas a few times. Even on pump gas, 50 TRIM on a 100% stock redtop we have done 375 WHP pulls on the DD, (425 WHP on a DJ) on 91 octane with only HKS cams and Haltech EMS and larger injectors. True 430 WHP I would say test the car on a dyno dynamics. Otherwise you are just giving me a number that represents the speed at which your cars engine can turn a given fixed weight up to a given speed.
Like Me on FaceBook ! |
07-20-2010, 12:54 PM | #184 |
Our S14 with S14 SR20DET with 2871r put down 393whp at 18psi on pump gas. This was done on 75deg day, on Dyno Dynamics.
We haven't had time to tune on race gas yet, but should be able hit close to 430whp. So it is possible
Performance Parts // Track Prep // Fabrication **Follow us on Instagram @TFWorks For all the latest TF★ news visit our blog!! |
07-20-2010, 06:12 PM | #185 |
should have gone with a gt2876r. i made 380hp on a mustang dyno on 18psi and on pump gas. dont have a copy of my dyno sheet but m-a can vouch for it. just last week i made a 11.20 pass at 121 mph. that really is a great turbo for staying t-2 bottom mount and i am still internally wastegated.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE! 10.79 @ 124 MPH WITH A 1.48 60' |
07-20-2010, 07:50 PM | #186 |
I dont think i can get it on a DD because i dont think we have any close by, but there are local Mustang Dyno shops, My evo 8 put down 551whp on 93 pump gas+meth on a mustang dyno thats not to far from me.
07-22-2010, 05:37 AM | #187 |
Well i finally got the car back from Gato's shop got the Cutout welded on and the *90 bend for the Tial V44, i will get a pic with the wastegate on ASAP and post it but this is what was done so far.
Enjoy until i get pics with it mounted. |
08-05-2010, 01:10 AM | #188 |
yeah dude. i still am waiting for your dyno results with this. and more pics!!!
My Twin Scroll Gt30r Sr22det Build |
08-07-2010, 02:08 PM | #191 |
have you seen the new tomei arms turbo.http://zilvia.net/f/advertiser-annou...60-turbos.html
08-07-2010, 08:49 PM | #192 | |
Yea they are pretty sick, it kinda reminds me of a 20g. I hope somebody gets one to try it out and its rebuildable. |
08-09-2010, 04:33 PM | #193 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
Another thing for new guys contemplating this, is to consider though is overall cost. Lets consider the cams and inlet manifold already part of the equation, and just 'exhaust' related parts. To make 400 whp with a 2871r .64: 1000 Turbo 200 Greddy J Pipe 125 downpipe 500 bucks for Extrude Hone 175 for Swain Coat 2000ish Dollars To make the same power, perhaps another 20 whp with a T3T4 550 Turbo 800-900 dollar manifold 350 for Tial 44mm 50 to 100 for a v band tube tube 250-500 for a custom downpipe w/vband 2000ish small end/2400ish big end. (Sure prices are high, as I use new part prices...I never consider used stuff when 'pricing' anything, as they to often are not stable and or never around when you need them...I always just use prices new, and then any money saved is a 'perk' of going used.) Both will work, and probably cost the same in the end. One can be installed in a weekend, one requires fab work to make it fit. In the end though, the Top Mount setup could easily make more power, but at the expense of a few more hundred dollars. Quote:
The best dyno is trap speed, not what each computer calculates hehe (luvya!) Quote:
Don't get me wrong, there was a lot of money/time and genuine resarch from my FWD days (more hands on that most) to get to this point, but It's there, and I've been there now for quite some time. Looking back was it worth the extra stuff to get there? Well, maybe, but today there are certainly easier options to make a 120 car than when I built mine (this side of a big lazy turbo). Bottom line is a v8 would be the easiest (and probably equal cost) and be much more reliablew for turnkey abuse. Quote:
Why not get trap speeds to *really* know? Lets be serious, the DD or Mustang dynos are better for 'tuning' but in the grand scheme, but all dynos of every type are easily manipulated. For guys that don't know the difference, the goal is to remain constant with dyno type used, and or the exact same dyno. If you're doing HP pulls and want to see if parts made and incrase, you should always try to duplicate the 'conditions' as best as possible and use the same dyno. We see to many people dyno on a MD at Shop A, and then come to a DynoJet at our place, and have different numbers (some high some low) and we never 'really' see if the mods made a measurable/worthwhile difference.
08-09-2010, 04:42 PM | #194 | |
Trader Rating: (58)
1. Not a real dyno graph 2. Not stated if WHP or Crankpower (probably crank, due to graph) 3. It's a 2.2 liter, so even if numbers were 'real' it's false to assume it even remotely applies to a 2.0 4. It's internal gate (yuck) Is the price good? Yea I guess...however if you want to really make a comparison, the regular 2871 setup's we see on here make equal if not better power than the ARMS kit.
08-09-2010, 11:07 PM | #195 | |
I'm just not sure how trapping 120 or so in a 2700-2800 pound car is "getting lucky"....
Daily driven |
08-10-2010, 02:49 AM | #196 | |
i am talking to a guy from germany, his handel on here and nico is thomas i guess. he has a youtube vids of his 2.2liter sr with and hks gt3037 lay down some serious power.YouTube - ‪Dyno SR22DET S13 June 2009.wmv‬‎ i will ask about that being a crank or wheel dyno. here is the tomei pamphlet for these turbos http://www.tomei-p.co.jp/inf/pdf/166-AE-A4.pdf
08-10-2010, 02:55 AM | #197 |
those are crank numbers on an engine dyno the factory pamphlet say so. well thats disappointing
08-10-2010, 08:53 AM | #198 | ||
Trader Rating: (58)
To me, that ARM's turbo is a waste. 460 crank power is how much you made before with a 2.0 and a smaller turbo...why would you want to make the same? I'd run for a smaller Borg Warner or a mid range 30r if I were you...much better options for the 2.2 than a bottom mount t2 flanged snail.
08-10-2010, 03:23 PM | #200 | |
08-15-2010, 04:45 PM | #201 |
well i got a good deal on a gt2871r .86 so we will see what happens with it. might not be a dyno tell next spring or later this fall.
08-22-2010, 10:28 PM | #202 |
Haha wastegate is HUGE lol.. its jus about done now all i need to do is add E-85 and fluid flush new oil, coolant, gear oil etc.. I should pull down the T2 record with this, im going to be running 26-28 psi and belive me this turbo still makes power after 22psi. This should be on the dyno soon i have to make an appointment
08-23-2010, 09:00 AM | #205 |
Remind me again what you are doing that makes you so sure about this....not doubting that you can do it, just remind me what is special about your setup Oh and also, are you talking about "record" as in peak horsepower? Peak torque? Best powerband? I think with that manifold you may see a high peak hp number, but your area under the curve will probably be poorer than a bunch of other setups out there
Daily driven |
08-23-2010, 10:35 AM | #206 | |
Special things about my set up/Different: -T04E 3071R Compressor -.72 Turbine housing -Tial V44 -E85 -3"Cutout -Standalone EMS -Tomei 270 duration cams i think one other person used this on here. I just have high expectations for it especially when im not using the same setup as most people on here. Like BC264, enthalpy tune,52 trim .64 2871,93 pump gas 740 injectors etc and putting down 320-340whp on a dynojet. Ive seen a couple people do something different on this board like codyace(extrude honing and JWT cams),4x4le (E85,Nistune),Idaho tuner (24psi lol), DrifterProdigy85 (Tomei 270 procams 12Xmph traps in the quarter), etc. they have all been sucessful with going 4XXwhp. If i dont put down atleast 400 i honestly would be dissapointed. So im going to stop with the Bench Racing and let it put down the numbers. |
08-23-2010, 10:44 AM | #207 |
Wait so what turbo is this exactly?
Is it a 2871R with a 3071R (T04E with 3" inlet) compressor housing and the EWG-44 turbine housing? So it's just a 2871R with different housings, right? Paired with those cams and E85..... On pump gas, with those cams, I would guess that you could put down 410 or 420+, peak power, but it is not going to be anywhere near as responsive as Cody's setup for example. My guess is that on pump gas, you won't see 300 ft-lbs until at least 4500 RPM or so.
Daily driven |
08-23-2010, 10:52 AM | #208 | |
08-23-2010, 11:27 AM | #209 | |||
Trader Rating: (58)
I mean, my car when 11.6 at 120.....which isn't bad (should be a low 11 with more time and a drag suspension), so it's proven that the traditional setup could nail you a high 10 with a lighter car...so I don't know why you'd not just go big topmount and really make hp (again not trying to sound dicky or take anything away, it's a neat setup, but seems counter productive to a point) Quote:
08-25-2010, 10:11 AM | #210 | |
but as of now im thinking of getting a splitfire coilpack set up and some Weld&Mickey Thompson Big and skinnys as far a wheel tire choice for drag. |
