#21094 | |
I ran the front setup with 20mm with 225/45/17 on the 17x9+22.[making it 17x9+2] -2.5 camber in front. fits good. rubs only when drifting. legit.
#21095 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Thought so, haha. Lemme know how much camber you end up running out back, and how it fits. Along with what modifications you did to your quarters and tire size. I have 235/40 Faterals and am running -4* on just rolled quarters. I feel like that's a bit too much, and I'm tempted to pull the quarters a little bit...
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#21096 | |
![]() Join Date: Apr 2010
Trader Rating: (22)
![]() Feedback Score: 22 reviews
![]() Front is -2 as well, running 215/40 Rotallas. I think I might stick with the 25mm spacers cause of the 215s, but I'll see tomorrow!
#21100 | |
I don't know how you guys drive around any lower than I already am. I have about 2 inches of clearance between the front bumper and the ground. I think because I put on tires with meat it just looks taller. |
#21102 |
![]() Join Date: Jul 2006
![]() Feedback Score: 6 reviews
At least 25 mil spacer. 9j-3 with a 235/40-17 sounds awesome on stock metal and will perform well! Add in some star specs so no expense is spared!
38 mil spacer if u wanna crank dat camber soulja boy Last edited by nathanong87; 11-20-2011 at 09:42 AM.. |
#21108 |
which projector did you use for the retro fit?
95 240sx RB20 415whp 91 Nx2000 VVL yo |
#21111 |
I want your lights Kevin!
LNSPLTBLVD.COM |
#21115 |
they are yellow glass domes found in lexus, mercedes, acura etc. fog lights. Attached to the reflector with high temp epoxy.
here is the low beam light output. cutoff is a little bit fuzzy with the 4 year old lenses, they really need to be polished. ![]() a little more detail about the retrofit: http://www.hidplanet.com/forums/show...mirror-shrouds. Last edited by silviaks2nr; 11-20-2011 at 05:21 PM.. |
#21117 |
![]() Join Date: Sep 2005
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
I can't believe this car made its way back to me... well to my roomate at least...
![]() in case you forgot... this is what it used to be. ![]()
IG: @bwagg88 |
#21119 |
![]() Join Date: Aug 2010
http://www.tarmac-spl.blogspot.com/ |
