#21421 | |
![]() Join Date: Jun 2010
Splice the stock valve inline with SR20 heater hoses, and keep the cable connected. |
#21422 |
#21423 |
Probably won't make too much of a difference, but I would place it on the same side of the heater core as it was stock. And in the same flow direction.
#21424 |
![]() Join Date: Nov 2016
Hey guys I’m in the market for a leak down tested. Some offer a 12mm adapter others a 14mm, can’t find one with both so my question to you guys is, is the spark plug hole in the KA a 12mm or 14mm? I want to get the right one the first time , Thank you
Sent from my iPhone using Tapatalk |
#21429 |
![]() Join Date: Jan 2013
Has anyone bought a brand new set of wheels from Rays or any type of company and painted over them for a different color?
If so what was the process? I really want a set of Gram Lights 57CR but hate the colors they offer and wanted to get it painted a glossy silver. |
#21430 | |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
#21431 | ||
GM2 (SW/AW)
![]() Quote:
I second that, spray paint the F out of them. If all else fails, powder coat them. DONE!
KA-T for life! Current for sale advertisement ![]() |
#21432 | |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Well yea, but was curious if you had to strip the original paint off the wheel yourself or do they just sand blast it for you? If you do have to strip the paint what's the best way to do so?
Instagram: Nismo_Lk |
#21433 | |
#21434 | |
Rattle can product is not good quality. |
#21435 |
Quick question for anyone:
So I'm installing a new distributor in my s14, and I've followed the correct steps to doing a removal/installation of a distributor to the best of my ability up to the point where you're inserting a new distributor. I have the rotor lined up towards cylinder 1 but the distributor just won't fit in completely. It gets really close, but I can't budge it to go in all the way. Anyone have any issues with this? And what would you recommend? Thanks. |
#21437 | |
But overall, I'm pretty stumped. |
#21439 | |
It stops like right before the o-ring consistently. |
#21440 |
I've read on a couple places that sometimes you need to do some light sanding if its hard to remove/install, but that's not an option currently. rip
I'll keep messing with it. Update: The distributor, although its supposedly the correct distributor via Amazon, the shaft isn't the same to where it would need to be sanded down. So I'll have to get a new one, rip. Last edited by mikeybb1011; 11-13-2017 at 12:32 PM.. |
#21441 |
![]() Join Date: Jun 2014
How much camber do stock S13 ruca’s give at the lowest end?
I am trying to find some nice arms for mine, but seems like there are actually very little selection that gives you some nice camber. I am trying to get around -5 to -6 degrees and Voodoo13 only gives -2.5 extra degrees. PBM rucas shorten up only 16mm from stock. Please help me out guys! I’ve tried to get some info of these, but there are not much of it around.
Juucso - Instagram |
#21442 |
![]() Join Date: May 2012
Anyone know how the concavity of 18x9.5 +30 LMGT4's compares to 17x9 +22? Im trying to run 17/18 stagger but I've heard the 17's are more concave and don't want something goofy looking.
Follow me on Instagram or don't @cason880 |
#21443 | |
![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
#21444 |
#21445 | |
9.5" 18, 9" 17, translates to 1/4" on the outside 12mm difference between the offsets, translates to no more than a slight difference in concavity. Total math without looking, says no more than 3/4" of concavity or less with the rear wheel having a slight amount more. After looking at Omori/Nismo, it's not a noticeable difference unless you are on the spectrum and have associated OCD
#21446 |
Most of the time the face of the wheel is exactly the same (the part that makes it "concave"), and the offset is done by varying the thickness around the wheel hub. Or the position of the face relative to the barrel is changed (giving larger lip for example). Either way the spokes are the same.
#21447 | |
#21448 | ||
#21450 |
Have you seen my car? There is no going back at this point lmao
