#21451 | |
#21453 | |
The only way to fuck this up is to get your TDC 180 out...ask me how I know #rookiemaneuver #lookatthefuckingdotsonthesprockets
#21454 | |
#21455 |
Align the dots. That little lines so the dot is off about a tooth, then stab it. this way the dot(#1tdc) is correctly aligned as the distributor turns on the way in. Assembly lube on the inside of the engine and on the distributor shaft help. You KNOW trying to slide shit in dry don't work, right?
#21456 | |
#21457 |
does anyone have experience or any comments on the enjuku clutch package with the "Competition "White Bunny" Clutch set up with ARP Flywheel Bolts"? thinking about buying it but want feedback on it before hand
#21459 |
It's all heavier than the ACT Stage I kit. It's not rebuildable like the ACT kit. ACT might be 200 more, but I prefer the lighter flywheel
#21460 |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Hey guys I have a bogging problem with my s14. It’s a 96 all stock with an auto. So one day I was driving it was all good, stoped at a stop sign and tried to accelerate and it bogged hard. Car bogs under WOT and hunts for idle.
When I give it slow throttle it revs all the way to redline. Under WOT it bogs like crazy the revs jump all over under 1000rpm. I replaced the maf, new knock sensor, put in new plugs and wires, cleaned the dizzy cap and put in new fuel and new fuel filter. No check engine light Any help would be appreciated thanks! Sent from my iPhone using Tapatalk |
#21461 |
Recently started working on the subframe for my S14. Picked up the Energy Suspension master kit and had a question about the install. Going between the instructions and past threads, my question is how many of the inner sleeves need to be cut out? The instructions show only the spindles while old threads say ALL the sleeves get cut. Any help?
#21462 | |||
GM2 (SW/AW)
S14 owners correct me if I'm wrong, but I had to cut out all of the sleeves on the S13. You will be able to tell when you take them off as well.
KA-T for life! Current for sale advertisement ![]() |
#21464 | |
GM2 (SW/AW)
Check to make sure before you go doing that though. http://www.240sxforums.com/forums/be...ce-values.html
#21465 |
A buddy of mine hooked it up with a free set of slip in subframe collars for my S13, the problem being that one of the bottom collars is missing. I have all 4 of the top collars and only 3 of the bottom ones. Would it be a problem to not run one of the collars? Or would this make my subframe sit lopsided?
#21467 |
I am looking at doing a braided fuel line coming from the stock fuel sending unit using AN fittings. There are quick connect, fuel line adapters, and push on types. I'm seeking for people that have done this mod to their 240's, and what kind of setup/size they have for connecting it directly to the tank
#21468 |
![]() Join Date: Nov 2015
![]() ![]() Feedback Score: 6 reviews
Just for a quicker shipping preference, is it cheaper to purchase postage on USPS's site? Or in person? Given both transactions use the same length, width and height as well as weight.
Skurr ![]() |
#21470 | |
Skurr ![]() |
#21471 | ||
GM2 (SW/AW)
Printing a label via eBay (dependent on the users seller status) is even cheaper. I'd die paying USPS' online or in store rate.
#21473 |
I've been using USPS for years...had an old business, Distorted Services Fine Cigars while in the Army. Sure, prices on the shipping have gone up over 10 years, but what hasn't? It's too easy to click and pay, and leave the box in your mail for pick up(can arrange pick up on the site too), or drop it in whatever pick up receptacle is available. USPS is right by my house, so I just walk past the big line, drop the box on the counter, smile and let the guy know Flat Rate/Fragile and look at all the grimaces as I leave with an even bigger smile(that's the best part, watching all those line waiters eat that particular shitty cheese) 😅😅😅😅💀
#21474 |
Best tires for everyday and drifting?
Hey, I'm pretty new here and I was wondering what tires you guys would suggest for everyday as well as drifting. I'm looking for mostly a drift tire that can be used for everyday. Im driving a PS13 on Work Emotion D9Rs.
Thanks! |
#21475 | |
@dorki forgive my sarcasm. You guys are all good gents. Thank you! Sent from my SPH-L720T using Tapatalk
Skurr ![]() |
#21476 |
Yeah bro sometimes I drift on my way to algebra class, too.
#21478 |
#21480 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
^ Origin Type 3 for sure, b/c I just saw a coupe with Type 3 overs a couple days ago.
Pretty sure most (if not all) Origin rear overs wrap around the taillight corner of the qtr panel. Also, you might find this thread more helpful: http://zilvia.net/f/showthread.php?t=599319
