Old 12-05-2017, 06:16 PM   #21481
Jacob Butler
Jacob Butler is an unknown quantity at this point
ok so im having this strange issue with my ka24e, theres no spark coming out of my ign coil. i check the voltage coming out of the harness connector. it reads 10.83. i crank the car over. i check it again. it reads 13. basically every time i crank the car the voltage reading changes up or down. One time it read like 60 volts, one time 1.3. battery is 12.45 volts. Anybody ever heard of someone having this issue? any help is greatly appreciated
Jacob Butler is offline   Reply With Quote
Old 12-05-2017, 06:26 PM   #21482
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
You don't have 60v coming out of a harness connector.
You should get a different mulitmeter.
mechanicalmoron is offline   Reply With Quote
Old 12-06-2017, 04:08 PM   #21483
Jacob Butler
yeah idk its weird, thanks though, i will try a different multimeter when i get a chance
Old 12-07-2017, 08:59 AM   #21484
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
Correct me if I'm wrong, but the 62 and e5 ecu are interchangeable for the sr20det blk top engine.
lewisfk is offline   Reply With Quote
Old 12-07-2017, 09:19 AM   #21485
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
to an extent... both ECUs are compatible between SRs, but youll loose your O2 sensor support. i believe 62 ECUs O2 sensors are grounded via engine harness while E5 ECUs are grounded via the ECU itself. also, the redtop 'skinny' O2 sensor reads differently than the blacktop O2 so they cannot be swapped between motors.
Old 12-07-2017, 10:21 AM   #21486
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Redtop sensors are titania sensor. Blacktop are zirconia. Each ecu are programmed differently to read the different type of sensor. The ecus are interchangeable in that the motor will run, but the sensor won't be read correctly.
Old 12-07-2017, 12:56 PM   #21487
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
I have a question, but it is more for informational purposes. ive wondered about it for a while, so I will ask: Cosmis wheels, are they on the "okay" or "cool" list of wheels to buy?
I have zero interest in buying them (too pricey for knockoff Taiwanese cast wheels for my taste). But I am just curious as it seems like a lot of people have them, and they seem to escape all the ridicule that XXR, varrotstein, etc get all the time. Why is this? I thought I remember seeing something about some professional driver/drifter starting this company, is that a reason for the pass? It does seem like the price has come down a little bit on them (looking at enjuku), but I remember them being pretty damn pricey earlier this year (300+ a wheel)
for a 1,000+ bones for a set of 4, why would you not save up and get some cast rays wheels made in japan for a couple hundred more? none of this makes any sense to me.
jumpman2334 is offline   Reply With Quote
Old 12-07-2017, 06:07 PM   #21488
Jacob Butler
So the new multimeter I just got hasn't gotten around to reading 60v yet but the voltage still changes Everytime I turn the key off and on. Now the voltage just varies between 8 and 11 volts. Any ideas??
Old 12-08-2017, 08:42 AM   #21489
mechanicalmoron
Yeah.
Your battery is dead as shit.
Old 12-08-2017, 09:40 AM   #21490
mikeybb1011
mikeybb1011 is an unknown quantity at this point
I have a Zenki here, and there's two vacuum lines right above the alternator that doesn't connect to anything (they're just hanging), anyone have any idea where those are supposed to go?
I can put up pictures if needed.
mikeybb1011 is offline   Reply With Quote
Old 12-08-2017, 10:42 AM   #21491
mechanicalmoron
Well uhh, what do they go to? Do they have vacuum on them, or do they need vacuum on them? That will tell you if they're coming from the manifold, or if they need to go to the manifold, respectively.
In situations like that, follow the wire or hose back to the next place that it's clearly origionally supposed to be secured, then see how big a circle it could have been in, and search that.
Old 12-08-2017, 10:53 AM   #21492
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
They may also be coolant lines for the throttle body, perhaps bypassed by a previous owner. Hard to know without pics.
jaysgottaredtop is offline   Reply With Quote
Old 12-08-2017, 03:58 PM   #21493
Jacob Butler
Yeah.
its not. car cranks really good battery has 12.45 volts. its just not getting spark
Old 12-08-2017, 05:46 PM   #21494
mechanicalmoron
Voltage shouldn't be fluctuating like that, that's at the battery? Or the coil? When cranking, or just sitting?
I've never had any reason to screw with 240 ignition, but you should have a hot wire, a tach, ground, output, trigger (somewhere, something approximating that, anyway)- have you tried jumping to hot/ground, and/or trying to trigger it, to check for voltage drop/etc?
Old 12-09-2017, 08:01 PM   #21495
drfftn
drfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond repute
Guys,
Y'all think a pull would be enough to tuck my tires?
Sent from my SM-G930T using Tapatalk
drfftn is offline   Reply With Quote
Old 12-10-2017, 08:14 AM   #21496
mechanicalmoron
stock ka rebuild - is it worth putting clevite rings and bearings on an enginetech rock auto kit? Is it even a good idea, since they say to use their enginetech rings on those pistons?
Any experience with them? Anything else in that kit that should be a fel-pro, etc? (other than all of it)
Old 12-10-2017, 11:03 AM   #21497
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
Originally Posted by drfftn View Post
Guys,
Depends on how good you are...seems doable. (Especially w/ - camber.)
Sent from my SM-G930P using Tapatalk
[240sx] is offline   Reply With Quote
Old 12-11-2017, 07:24 PM   #21498
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
Dumb ass question are silvia brick and triple projector wiring harnesses the same?
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 12-11-2017, 09:44 PM   #21499
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
that would be a big negative...
Old 12-12-2017, 07:05 PM   #21500
Juucso
Juucso is on a distinguished road
Does anyone have installion pictures of lambo door hinges on S13? I am trying to figure out how to mount them to the door. I think there should be some kind of strengthen plates?
Juucso - Instagram
Juucso is offline   Reply With Quote
Old 12-14-2017, 05:32 AM   #21501
Tomek_PL
Tomek_PL is an unknown quantity at this point
Hey guys, I'm new to the scene, been lurking and learning, but i just want to confirm that the only real difference in terms of bodies between the s14 zenki and kouki is the front end. If so, then the side skirts and the little rear corner bumper trims should be interchangeable as long as its usdm to usdm or jdm to jdm, do i have this right or not? don't want to start buying stuff that wont fit... i have a 98 kouki if that makes a difference.
thanks in advanced.
Tomek_PL is offline   Reply With Quote
Old 12-14-2017, 06:29 AM   #21502
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
thanks in advanced.
You are correct.
Old 12-14-2017, 06:38 AM   #21503
Tomek_PL
awesome! thanks a lot! time to start shopping :P
Old 12-14-2017, 09:52 AM   #21504
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Anyone know if the CA18 Nismo strut bar is actually higher than the standard S13/14 Nismo strut bar?
My Fuel rail and injectors will not allow my S13/14 one to fit over them, even with drift_freq mounts.
Standard SR:
CA18 Specific:
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 12-14-2017, 05:43 PM   #21505
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
CA18 strut bar was a totally different shape from the SR20 based bars due to the slant of the motor. dont know about the over all height, but i imagine it being slightly higher!
what kind of rail and injectors are you running?!
Old 12-15-2017, 09:24 AM   #21506
Jacob Butler
Battery voltage is consistent. Voltage at various harness connectors, like fuel injector, dizzy, and coil, they all get 8-11 volts. Car still gets fuel. The car gets a very very small spark out of brand new ign coil, not enough to start. I have also tested the "pulsing" wire in the coil connector that goes from open loop to closed and back to open to fire the coil. That tested good.
Old 12-15-2017, 09:26 AM   #21507
5280VertDET
[img][/img]
Thanks! I wish someone had a side by side before I sell mine and look for a CA18 cusco or nismo...
Running some tall top feed 760's and radium fuel rail. It does have a fitting on to for the FPG line, but even if I remove that it's still tight...
Old 12-15-2017, 10:40 AM   #21508
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
i think your best best i to go find a CA based strut bar and test it out... wont run you much. you can always recondition one thats a bit worn too (should help keep it cheap)
Old 12-15-2017, 11:14 PM   #21509
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
What are some ebrake options when running G35 front and rear brembos? Would z32 setup still work?
Sent from my SPH-L720T using Tapatalk
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 12-17-2017, 09:00 AM   #21510
Jacob Butler
Voltage while cranking is a steady 8 volts. If I turn the key to on, read the voltage, turn key off and back on, I read it again and the voltage will be different every time. It never gets a full 12 either.
Also I took coil off the car and triggered it with 12v and it didn't fire. So I tested the resistance and it was way off. So AutoZone replaced it with another one that was within spec. I haven't hot wired this one because I don't want to risk shorting it. I'm pretty sure the problem is not the coil itself.
