Old 10-12-2018, 05:25 PM   #22261
loser101
loser101 is an unknown quantity at this point
Send a message via AIM to loser101
What are the vacuum and coolant nipples on the intake manifold made of?
It looks like there is a coating on them that sands off, if the coating is gone will they rust?
loser101 is offline   Reply With Quote
Old 10-12-2018, 09:35 PM   #22262
derass
Originally Posted by LoSt180 View Post
Is there such a thing as a Wideband that does NOT come with a gauge pod? I basically want to replace the stock O2 sensor, have the output available for logging, a narrowband output fed to the ECU, but be able to hide the box somewhere.
https://www.aemelectronics.com/produ...afr-controller
https://www.innovatemotorsports.com/products/lc2.php
Originally Posted by jumpman2334 View Post
so, when the photobucket-gate thing hit, there was a link that was going around that would pull up a previous version of the site, prior to pb screwing us. does anyone have that link?
its getting tiring finding old lexus threads with a lot of good info, and the pictures don't work.
Just search for Photobucket extensions for Google Chrome.
Old 10-13-2018, 08:34 AM   #22263
inopsey
what ecu? if its a standalone just hook up the wideband sensor, input the calibration table into the ecu and your done.
Old 10-13-2018, 12:23 PM   #22264
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Would just be an S15 ECU with Nistune board. Nistune board won't take a wideband input directly, but software can use it for logging.
Old 10-13-2018, 07:25 PM   #22265
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
im not sure what ballerbolts sold, but if youre after Ti stuff, check out Toronto cycles or pro-bolt.
ive ordered from Toronto cycles before and haven't had an issue. their website looks like it was made/designed around the time the caveman discovered fire, but id still recommend buying from them. I haven't ordered from pro bolt, but my dad does fairly frequently for the sprint car he works on. pro bolt is sorta pricey, but ti isn't cheap to begin with. their black Ti is also DLC.
Checked these sites but they dont have what I need.
>Does anyone know where I can order good quality M8x1.25 turbo exhaust housing to dump pipe studs? And are the OEM ones 35mm in length?
I read something about steel studs not being cut out for the job due to heat-cycles so Im trying to avoid steel replacement studs. I'll check ACE but I think they'll carry lower grade metal studs (I could be wrong). I couldnt find anything from ARP either.
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 10-14-2018, 07:28 AM   #22266
I'm Redline
I'm Redline's Avatar
If you are going to go stainless or other metal harder than basic treated steel, AND if you are using ANY bolt and nut combo or bolts in a car(EXCEPT head studs) use silver colored anti seize. This dab will stop heat welding for those of you who still do not understand why exhaust hardware is hard to remove
My work in progress...
Old 10-14-2018, 08:55 AM   #22267
DJTTon
DJTTon's Avatar
So youre saying I can get away with using ACE hardware stainless studs as long as I apply some anti-sieze? What metal are the SR230 turbos made out of anyway?
Skurr Skurr
Old 10-14-2018, 01:28 PM   #22268
1993fdrx7
Trader Rating: (32)
1993fdrx7 is an unknown quantity at this point
Feedback Score: 32 reviews
are there aftermarket s chassis front knuckles that have provision for cts-v brakes or do you always have to use the adapter?
1993fdrx7 is offline   Reply With Quote
Old 10-15-2018, 04:46 AM   #22269
I'm Redline
Not ACE or Lowes et al, NOT THEM. Go to your local FASTENER shop. We have Fastenal and a local guy here(Clarksville Fasteners) that do nothing but bolts, nits, washers, a few things like Kroil(It IS made in Nashville)
Old 10-15-2018, 05:29 AM   #22270
DJTTon
DJTTon's Avatar
There's a fastenal in my area too so I'll check that out
Sent from my SPH-L720T using Tapatalk
Skurr Skurr
Old 10-15-2018, 03:11 PM   #22271
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
im sorry. you said baller bolts, so I had assumed you were asking about dess up bolts and not turbo hardware. I had to look it up on their site, but it does look like they sell SR turbo studs.
if im understanding correctly what you need, FR sport has them for $1.09 a pop:
https://frsport.com/frsport-stud-8mm...1-25pitch-stud
jumpman2334 is offline   Reply With Quote
Old 10-15-2018, 05:21 PM   #22272
jumpman2334
thank you. I believe I tried this a while ago and I couldn't get it to work. I will have to try on the home computer.
Old 10-15-2018, 06:35 PM   #22273
DJTTon
DJTTon's Avatar
Youre right, I wasnt looking for dressup bolts. Im kinda bummed ballerbolts was a hoax, they seemed to have the right idea. I was totally ready to buy driveshaft bolts
Skurr Skurr
Old 10-16-2018, 06:22 PM   #22274
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
How do I convince my ex-wife to give me back my kids
brokeboi01 is offline   Reply With Quote
Old 10-16-2018, 08:18 PM   #22275
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
You have a court tell her to do it.
Sent from my SM-G955U using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 10-21-2018, 02:27 PM   #22276
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
Question for those with z32/r32 rear drums. I installed them today and the hub is hitting is just barely hitting the anchor and spring perches. I have the PBM ebrake spacer, so I dunno if that is pushing it out too far or what. Any clues?
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 10-21-2018, 03:50 PM   #22277
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Looks like you have the thick anchor that doesn't need a spacer. It shouldn't be that close to the hub.
Old 10-21-2018, 04:05 PM   #22278
theStig880
theStig880's Avatar
I thought so too but looking again, they should be the thinner ones. Its got the nub and the hole isnt tapped like the one on the left.
Old 10-22-2018, 12:06 PM   #22279
j4r1ll41990
j4r1ll41990 is a well-known jackass
Are the '03 350z brake parts the ones I need for my s14 240sx big brake conversion?
j4r1ll41990 is offline   Reply With Quote
Old 10-22-2018, 06:52 PM   #22280
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
So I own a rhd silvia s13 which comes with 5 bolt rear axles/output shafts and a jdm vlsd diff. I have a welded diff out of a us 240sx that has 3x2 output shafts that I would like to install.
Is it possible for me to install the 240sx welded diff and use the jdm 5 bolt axles output shafts with the 5 bolt axles?
e30gangsta is offline   Reply With Quote
Old 10-22-2018, 08:46 PM   #22281
cynabel
cynabel is an unknown quantity at this point
240sx with sr20det no spark
Hello all. I have what I hope are not silly questions (know very little about these engines/cars) Helping my son to troubleshoot. He swapped his ECU for a Power FC. It ran great for a couple of weeks, then lost spark. I've read a ton about no spark situations and checked everything people recommended. All looks good except when checking pins on the ECU, several pins, including the ECU ground, have good ground, but also 8 volts?!? Might that cause no spark and/or messed up the ECU?? Also, backup power (pin 46) shows 12+ volts (not constant), but ECU power(pin 47) shows nothing?!? Could that keep the ECU from "saving" information? Thanks for your help. (Nevermind, I think I posted in the wrong area. I'll repost in Engine Tech).
cynabel is offline   Reply With Quote
Old 10-23-2018, 10:50 AM   #22282
240msh
240msh's Avatar
240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known
What clutch master cylinder is everyone using? Everytime I use an exedy replacement or some autozone trash I constantly have issues.. opinions on the wildwood clutch master?
@Michayyl
240msh is offline   Reply With Quote
Old 10-24-2018, 06:54 AM   #22283
I'm Redline
Centric, ie, Stop Tech makes great brake parts. Theirs is bored at like .020 over OE with brand new oversized parts...which makes stopping really nice
Old 10-31-2018, 06:40 PM   #22284
DJTTon
DJTTon's Avatar
Hi friends,
I am in dire need of someone that understands how 3-piece wheels work (l0l). I am currently working with 18x10 +13 (4.0" Outer Lip, 6.0" Inner) VS-XX rear wheels and it's improperly sized for the stock S14 body. Mind you I bought the car with the wheels already in place.
The issue is that the rear lip protrudes a solid 0.5-0.75" past the fender; the tire sits in such a way that the lip is the post protruding piece of the wheel. I am trying to figure out what specs (lip and inner barrel) would achieve a wheel that sits flush with the fender. Ideally I could reuse either the 4" lip or 6" inner barrel.
My logic thinks I can get a 3" lip and that should do, but would changing the inner barrel to 0.5" shorter make a difference or is that just from the suspension side and outside will be unaffected?
Skurr Skurr
Old 11-01-2018, 05:50 AM   #22285
I'm Redline
Hi friends,
Perfect flush fitment on the S14 is with a Square G6 model with 17x9+15. The below calculator is pretty dang good with the measurements from center and offset to check lip distance. Do your math and look at the link's information more than the picture. The math data is accurate
http://www.rimsntires.com/specspro.jsp
Old 11-01-2018, 06:07 AM   #22286
DJTTon
DJTTon's Avatar
I never really understood these calculators that compare one wheel to the other, I dont have a starting point. Furthermore, Im not trying to forego the 3 piece wheel for something else.
Skurr Skurr
Old 11-01-2018, 06:51 AM   #22287
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Your starting point in the current wheels, the calculator will help you see what changes to the barrel will effect.
For a 3 piece wheel, the center disk is static, and the sizes of the barrel and lip will effect width and offset. Your assumption is correct though, a reduction in lip size will bring the outside edge in by that amount with no other changes. 1" is roughly 25mm, so you'd end up with a 9" +38 offset (if my math is correct). Might have to play around with a calculator to verify though.
Old 11-02-2018, 06:17 AM   #22288
I'm Redline
Look at the center line of the barrel. This is static. Then look at the offset line for the hub. Note the barrel measurements from center line or offset line. Look at the lines that show how far out the wheel pokes over stock.
1" = 33mm
Your HUB surface is your center line. Offset as in a positive number works as follows:
STOCK SE wheel: 16" x 6.5" +42mm This is a battle sunk wheel. It is about 2" inside the wheel well and fender line. The front surface of the wheel is roughly 4" from the hub surface
Like I said, use the calculator, and look at the picture. DO THIS UNTIL YOU UNDERSTAND. You are smart, you will figure it out, then suddenly wheel fitment, A disc, B disc, and 0 Disc will suddenly be easy to figure out
Hint: 0 disc is perfect center, A disc is weak, B disc is strong
Old 11-03-2018, 01:38 PM   #22289
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
1" = 33mm
jaysgottaredtop is offline   Reply With Quote
Old 11-03-2018, 04:21 PM   #22290
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Originally Posted by jaysgottaredtop View Post
He's obviously using penis inches for those conversions instead of standard inches.
