#2252 |
![]() Join Date: Jun 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
50mm fenders, 18x10+22 wheels 25mm spacer, 255/40 tires. about -2.7 camber?
front-stock fender 18x10+22 wheels 15mm spacer 235/40 tires. Camber plates maxed. S14 LCA ![]() ![]() ![]()
AERO-K GARAGE |
#2255 | |
SPL parts The gas station pic was before I lowered the front all the way. I still have my collars so I preloaded the spring in the mean time. (haven't had time to take the coilovers off) The rears although, are completely maxed out. I'm not happy with the height in the rear. So unless I can cut some thread off of it, I'm not sure what to do. As far as the front goes, I'm on 17's so my front lip is really close to the ground (after the gas station shot). I need to get some photos of how it sits now. Sizes are: 18x10.5 -6, 17x9.5 -5 (w/8mm slip on spacer for Z32 brakes) R- 225/40/18 F- 215/40/17 |
#2256 | |
Also, glad to know 8mm slip on spacers work. I have 10mm on there and it looks like a tight fitment, but I really would like to get an 8mm over using the 10mm just cause I don't want the front to stick out THAT much. BTW, in the rear, if you're using SPL Parts/KTS coilovers, you need to droop the springs, not preload them, to get the rear lower. |
#2257 |
![]() Join Date: Jan 2006
KTS coilovers?
i have those and i had to modify them to get them as low as i would have liked. Shorter spring, smaller spacer between the upper spring perch and camber plate, remove both collars... |
#2258 | |
Yea, I thought about going with a shorter spring as well. I just haven't had the money or the time. Do you daily your car? cuz ive seen pics and your car is low as shit too. The roads here in Miami are whack as fuck, and the car hits everything I can't wait to see what happens when I get some aero |
#2260 | |
Also, I heard that you can take off the camber plates and mount them upside down on top of the strut tower, and then mount the shock to them like that through the strut tower hole, which is like an instant 3cm or so body drop. Although I looked and on S13's you'd have to run washers under the camber plate since they have the raised circle on top the strut tower, and you wouldn't be able to have your negative camber maxed out. |
#2261 |
![]() Join Date: May 2006
As most of you know I sold the s14 back in August.... i picked up a 350z. After waiting forever for my wheels to arrive... i figured I'd jump back on here and post some pics of my Z.
old car: ![]() new project begins: Next is aero! 19x9.5 +4 19x10.5 -2 225/35/19 245/35/19 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2262 | |
this is with the previously stated setup. without a motor in the car. ![]() gotta lower the rear yea yea |
#2263 | |
Jeez, I'm jealous. I'll have to look at my coilovers tomorrow. Is it ok to just remove the spacer completely? Haha. |
#2265 |
Yeah that collar is almost half an inch thick depending on the coilovers.
Anyway... this is wheel fitment whore thread, not "lowness" thread... More pics/specs of wheel fitment please. |
#2267 | |
THIS IS THE WHEEL FITMENT THREAD GUYS!!! |
#2269 | |
i'm not picking a fight sideways, just saying if it's on the topic of wheel fitment (which it is) i don't see the problem |
#2271 | |
![]() Join Date: Sep 2007
#2272 |
Banned from the Marketplace
well i had to raise it up toget it on a tow truck to bring to my new house, but ill post a pic
fronts-18x10-17 (225/35r18) rears-18x12-17 (265/35r18) the car will be lowerd back down 1.5 in the front and 2inch in the rear! enjoy ![]() ![]() ![]() ![]() ![]() ![]() |
#2274 |
www.SonicMotor.com
![]() Join Date: Aug 2005
Trader Rating: (113)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 113 reviews
i was about to say the same.
I guess its becuz our cars are the same color
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK ) |
#2275 |
#2279 |
My little brothers 17x9 +11 SSR Dish. Just put them on tonight. Can't drop it any more until roll/pull. Keep in mind the car does not have rotors and it still has stock RUCA's. If we can find new barrels to widen these wheels we're going to move these up front and tear apart the fronts (17x8 +5), widen them, and shove them in the rear. Anybody know where we can find any? Maybe he'll just have to buy another set and mix/match.
#2280 |
Same style wheels and close offsets!
17x8 +8 front 17x9 +5 rear ![]() [QUOTE=240sxaddict;2455494]My little brothers 17x9 +11 SSR Dish. Just put them on tonight. Can't drop it any more until roll/pull. Keep in mind the car does not have rotors and it still has stock RUCA's. If we can find new barrels to widen these wheels we're going to move these up front and tear apart the fronts (17x8 +5), widen them, and shove them in the rear. Anybody know where we can find any? Maybe he'll just have to buy another set and mix/match. ![]() QUOTE]
