Old 09-08-2019, 04:25 PM   #22801
Presto
Presto's Avatar
Presto is an unknown quantity at this point
Harbor freight tools
I get minimum wage so I’m broke and new to cars so I got a pretty dumb question,
Should I spend my money on harbor freight timing light and compression test kit?
Or will I regret it and wish I bought more expensive ones somewhere else,
does the harbor freight stuff work alright?
Presto is offline   Reply With Quote
Old 09-08-2019, 06:12 PM   #22802
irax
irax's Avatar
Harbor freight tools work fine. Keep receipts and when they ask if you want to buy the extended warranty just do it. Sign up for their promotions and use the coupons every time.
irax is offline   Reply With Quote
Old 09-08-2019, 06:14 PM   #22803
S14rebuild
^ cause ur a noob. Refer to the forum rules and ull understand all.
Old 09-10-2019, 10:46 AM   #22804
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
My driver side headlight will not come up when I press the headlight button.
I move it up manually and
It will go down when I press the button but not up. Passenger one works perfectly fine.
Checked voltage to socket and everything is getting power where it should. Checked the three relays and they’re fine. Checked my driver side fender harness and all is good. Abit stumped.
Instagram: Nismo_Lk
JrDarknes is offline   Reply With Quote
Old 09-10-2019, 02:22 PM   #22805
My!
My! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enough
does anyone know if s15 silvia rear main seal is the same as previous generations?
edit: answer is yes
My! is offline   Reply With Quote
Old 09-10-2019, 02:40 PM   #22806
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
Who's the master ADMIN on this site? that deals with technical stuffs.
mau5trap is offline   Reply With Quote
Old 09-11-2019, 10:58 AM   #22807
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
neither one come on the site anymore. your best bet is to contact PHLIP or ThatGuy
Old 09-12-2019, 09:12 AM   #22808
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Zilvia, please steer me in the right direction.
I have what I believe to be an S14 LSD installed, but it clunks like a mf between gear shifts. I took it out at some point to try to identify the issue, and what I believe is happening is the actual differential assembly itself has too much play not the ring/pinion clearance; when I grabbed both axle stubs on the disassembled diff and rotated them in opposite directions, there was a lot more play compared to a spare S13 LSD that I have.
To fix, I believe everything has to be taken apart up to the spider gears and the clutches inside may need to be replaced, but Im not 100% sure. I am considering having the differential rebuilt by a shop, and was wondering what kind of costs I could expect from a differential overhaul.
What would you recommend, buy another used LSD? Pay to fix this one? Pay for aftermarket?
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 09-12-2019, 03:34 PM   #22809
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
either way, youre gonna pay $500-$1000. id steer clear of buying a used LSD unless its an OEM S15 HLSD... best OEM diff EVER!
if you do buy a used LSD, call the manufacturer and order a rebuild kit... then have it fully rebuilt and installed properly by a trans shop.
Old 09-13-2019, 12:26 AM   #22810
shobotan
shobotan's Avatar
shobotan is an unknown quantity at this point
[QUOTE=JrDarknes;6356934]My driver side headlight will not come up when I press the headlight button.
I've had similar and it was intermittent but when the light stopped comin up I couldn't getting it going again unless I manipulated it manually. Initially I thought the steering column switch was the problem.
I removed the ground wires for each motor, cleaned up the oxidation on the lugs and haven't had a problem in a year. You might be lucky, give it a try, it could be a cheap fix.
MECHANICAL INJURNEER
shobotan is offline   Reply With Quote
Old 09-13-2019, 06:40 AM   #22811
Presto
Presto's Avatar
Ka24e only runs good when I put my hand over the intake, tried to fix ignition timing but distributor won’t let me past the 3rd mark from the right
Old 09-13-2019, 06:44 AM   #22812
Presto
Presto's Avatar
Old 09-13-2019, 09:12 AM   #22813
ArcherV2
ArcherV2 is an unknown quantity at this point
Lost my old account - but Just recently picked up an S15 sitting on HKS Hipermax coils.
Will 17x9 +22 and 17x9 + 35 (all wrapped in 215 / 45 / 17) clear all suspension and fender issues without problems? I don't care about supreme flushness - a little sinkage is fine with me, I just want to make sure I'm not rubbing on anything!
ArcherV2 is offline   Reply With Quote
Old 09-15-2019, 05:19 PM   #22814
Presto
Presto's Avatar
Accidentally posted twice
Old 09-15-2019, 05:20 PM   #22815
Presto
Presto's Avatar
I did a compression test on my ka24e, I got exactly 120 across the board and cylinder 3 was just like a tiiiiny bit under like near the next notch down,
I’m a noob sooooo I forgot to press the gas when I did it
-Spark plugs weren’t taken out but they were disconnected as well as coil and fuel relay
EDIT: I just went back outside and pressed gas down, all spark plugs out, let it crank 5 times, every cylinder reading exact same 120
-I’m using a $30 compression test kit from harbor freight, the brand is Pittsburgh. Car probably has a vacuum leak somewhere as it only runs good when I cover the intake with my hand otherwise it’s rough idle, also I’m not sure if the car was totally warm as it was running for maybe 2-3 minutes before I tested
Should I be worried about engine swap right now? Or is it cool for me to buy more parts to get it running better
Old 09-17-2019, 05:29 AM   #22816
180sx_
180sx_'s Avatar
180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about
i have a hks actuator on my t28bb turbo, currently at 10 psi. I have turned it up heaps but still hasnt increased boost? could this be because of a worn out spring or something?
also ever since around a month ago after every time it rains or i wash the car it becomes so slow, its weird because it only does it as of a month ago. i dont have a vented hood or anything so i have no clue where the waters going to cause the car to be slow
180sx_ is offline   Reply With Quote
Old 09-18-2019, 10:09 AM   #22817
1illsuspect
1illsuspect's Avatar
1illsuspect is an unknown quantity at this point
Hello Zilvia OG’s. I’ve been searching and seeing a lot of guys running on 240’s Evo Brembos, and CTSV Brembos, what about Dodge Srt8 Brembos? I saw one thread where a guy had brackets for a z32 but that was From 2011. Can’t find any conversion kits online for them. Someone local is selling a set of front and rear for $300 with rotors and lines.
1illsuspect is offline   Reply With Quote
Old 09-18-2019, 02:35 PM   #22818
mosilvia
mosilvia is an unknown quantity at this point
Throttle Position Sensor 96 S14 MT
I want to change new TPS for MT and looked for Ebay and Amazon
They have only for Automatic's TPS that have two connections
On Nissanusa.com parts #2262031U15
Is this fit for my S14 manual transmission?
mosilvia is offline   Reply With Quote
Old 09-18-2019, 08:14 PM   #22819
SRSmith
SRSmith is an unknown quantity at this point
Which mark on an sr20 is top dead center?
Most places I've seen say second from the left. However, in this video he's doing second from the right.
https://www.google.com/url?sa=t&sour...N8ZFOD4xbU2nov
Is he just doing it wrong? The engine sounds fine.
Thanks
SRSmith is offline   Reply With Quote
Old 09-19-2019, 09:37 AM   #22820
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
Have any of y’all imported an engine off the Yahoo Auctions? I found something I want but I dont know who can do it. I know Jesse doesn’t handle stuff like that typically.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 09-19-2019, 09:39 AM   #22821
theStig880
theStig880's Avatar
Old 09-19-2019, 12:15 PM   #22822
S14rebuild
Omg the questions hurt my mind
Old 09-23-2019, 03:01 AM   #22823
mint40
mint40 is an unknown quantity at this point
Hey guys my oil feed stripped bad. So we blocked it off on the block and I’m going to run the oil feed from my k-tuned oil pressure npt adapter. My question is does anyone know what size thread the oil feed line on a t25 turbo would be in AN fittings? Also what size line? My research has lead me to -3an but I’m not sure never used AN line
mint40 is offline   Reply With Quote
Old 09-23-2019, 05:49 AM   #22824
S14rebuild
Minty40-
https://zilvia.net/f/showthread.php?t=121400
Took all of 30 sec search....
Old 09-23-2019, 05:51 AM   #22825
S14rebuild
No such thing as a 2011 z32....... thats ur issuse
If ur looking for 2011 Z33 they thats a diffrent story...
Old 09-23-2019, 08:03 AM   #22826
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
No, it's the same story as there isnt a 2011 z33 either lol
Sent from my Galaxy Note 10+ using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 09-23-2019, 09:18 AM   #22827
S14rebuild
Z34 lol
So confused....
Old 09-23-2019, 10:00 AM   #22828
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
^ I don't think that's what he meant. Reads as 'the thread' was from 2011, not the chassis model year.
[240sx] is offline   Reply With Quote
Old 09-23-2019, 09:19 PM   #22829
Andrewkd
Andrewkd's Avatar
Andrewkd is an unknown quantity at this point
s13 what is this?
hey guys, currently swapping my pop up front for a Silvia front, as I was disassembling the front end I found this, what is this? do I keep it for the Silvia front?
thank you!
https://imgur.com/gallery/2k9oQPG
Andrewkd is offline   Reply With Quote
Old 09-23-2019, 09:21 PM   #22830
Andrewkd
Andrewkd's Avatar
s13 engine bay grounding for fuse box
hello guys! any way you guys could share pictures of where the grounds are for the main fuse box? (on the right side of the vehicle), also where the fuse box is attached to, can't seem to find how its supposed to be held down, currently installing my fuse box harness! thank you everyone, I'm new to this s13 life
