Old 04-08-2013, 08:50 AM   #2281
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Originally Posted by Ryan_1 View Post
Jus have a question I have ordered a set of vskfs in 18x9.5+2 r disk and 18x10.5+1 o disk. jus wondering will i need much of pump of the gaurds. and the fronts should clear standard calipers?
...for what car?
Old 04-08-2013, 12:26 PM   #2282
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
R-disk fronts will pretty much clear every big brake kit for the S-chassis fronts.
You will need to pull the fenders no matter what chassis it is, a butt load more on S13/S15 vs S14.
CLICK HERE!!!
Old 04-08-2013, 03:31 PM   #2283
Ryan_1
Ryan_1 is an unknown quantity at this point
Sorry S14 S1
Ryan_1 is offline   Reply With Quote
Old 04-09-2013, 04:53 AM   #2284
Attridge_300ZX
Attridge_300ZX is an unknown quantity at this point
I've decided I'm going to get a set of Work Meister S1 3P for my 1990 300ZX. Now it's just deciding which disk types and offsets to get. I want wide tires on my Z, so I'm leaning more to the conservative offsets. I'd also like to be BBK friendly in the front.*
I'm leaning towards option two up front.
1) 18x9 + 29 (L disk) Pros. Larger lip. Cons. Have to run a spacer for BBK
2) 18x9 + 31 (R disk) Pros BBK friendly without spacer. Cons less lip than option 1.
For the rear there are more options. I'm leaning towards option 1.
1) 18x10 + 43 (O disk) Pros. Will fit without roll, decent lip size, fit wider tire. Cons. Not BBK friendly.
2) 18x10 + 30 (O disk) Pros. Large lip. Cons. Rear roll needed, not BBK friendly, fit narrower tire.
3) 18x10 + 42 (L disk) Pros. Should be BBK friendly, no roll needed. Cons. smaller lip,
4) 18x10 +29 (L disk) Pros. Should be BBK friendly, decent size lip for disk type. Cons. roll needed, smaller lip than O disk
So let me know which options you'd pick and why.
Here is a link to the size chart for Meisters*http://www.workwheelsusa.com/media/w...03P%20Spec.pdf
Attridge_300ZX is offline   Reply With Quote
Old 04-09-2013, 05:44 AM   #2285
fliprayzin240sx
Look around rimtuck and make a decision. But from what I've seen...I like this setup:
Specs: 18 x 9.5 +11 255 / 35 18 x 10.5 +23 275 / 35
SO looking at that, my recommendation for be close to those specs: 18x9.5 +12 R-disk and 18x10.5 +24 O-disk. R-disk to clear BBK or any other BBK you can think of up front and O-disk in the rear since it should clear the Z32 rear brakes.
CLICK HERE!!!
Old 04-09-2013, 09:25 AM   #2286
Attridge_300ZX
Doesn't look like stock rear quarters, and I would only be able to run 35 in the front with that low of an offset. Doesn't look too bad though.
Old 04-09-2013, 03:58 PM   #2287
silviaguy240
silviaguy240's Avatar
How is needing a roll a con? And you can order any offset, obviously it will take a little longer.
Old 04-09-2013, 04:47 PM   #2288
Attridge_300ZX
Roll is a con. because it's something I'd rather not do. You mean I can order offsets that are not listed on the spec sheet? Custom offsets?
Old 04-09-2013, 04:53 PM   #2289
zooopreme
Trader Rating: (38)
What's the point of having wide wheels with high offsets? Are you purposely going for the sunken look?
Rolling your fenders isn't hard and if you choose not to do it yourself, there's always somebody around that'll do it for a fair price.
And to answer you questions, you won't know until you ask. From what I remember, they do, you just have to take the initiative and ask if they still do and how much that'll run you.
If not, you're stuck with buying the right offset, sucking it up, and rolling your fenders (mildly) or you'll be stuck buying wide wheels with poor offsets for your chassis and stacking spacers to achieve the look you want.
Old 04-09-2013, 06:55 PM   #2290
fliprayzin240sx
If you dont roll the fenders, it'll be sunk and you wont be able lower the car much. Basically, you'll be buying $4k worth of wheels that will make your car look like poops. But hey, your car, your money...the fuck do you need our opinions for right?
CLICK HERE!!!
Old 04-09-2013, 07:04 PM   #2291
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
hey guys, i'm currently running hankook v12's in 225/40/18 and 255/35/18 on an 18x9.5 + 12 and 18x10.5 +15 but i'm thinking of switching to 215/40 and 245/35. Anybody have any experience with these tires on the wheel specs im running? Just trying to run something a bit smaller with more stretch but nothing insane. Camber is gonna be -3 or so in front and as close to zero with how low i am in the rear...so probably like 1.5 or so
It's not so much a matter of how will i fit them(i make my wheels fit regardless), but rather how the tires will look/stretch on those sizes. Thanks.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 04-09-2013, 07:30 PM   #2292
Attridge_300ZX
+45 is the factory rear offset for the Z32, so running a 10 wide with + 43 offset will sit rather flush, and allow me to run at least a 285 tire. The lower the offset I get the less wide of a tire I can fit.
Old 04-10-2013, 06:06 AM   #2293
fliprayzin240sx
Oh you're right...not possible to run wide tires on low offset wheels on a Z32.
Oh wait a minute...
Nissan 300ZX 2+2 1991 18 x 10.5 +18 285 / 30 18 x 10.5 +18 285 / 30
Nissan 300ZX 2-seat 1990 17 x 11.0 +8 245 / 35 18 x 11.5 +22 275 / 35
Yup...Immmm-Fucking-Possible...again, the fuck do I know since I'm just looking at other people's setup.
CLICK HERE!!!
Old 04-10-2013, 06:44 AM   #2294
NORFY
NORFY is just really niceNORFY is just really niceNORFY is just really niceNORFY is just really niceNORFY is just really niceNORFY is just really niceNORFY is just really niceNORFY is just really niceNORFY is just really nice
hey guys, ive got a question, basically i need to get lower.
my car; s13, Meister-R coilovers. FRONT: 17x10 et 15 (plus 12mm spacer) with a 235/40, s14 lower arms. REAR: 17x10 et 15 (with a 15mm spacer) on 225/45's. semi tubbed front arches, relocated loom work.
this is how it sits
but i want it lower. ive recently gone from 15" rims up to these 17" ones. with the front arches off ive got roughly 1" clearance from the top of the tire to the strut top, infact its showing signs of rubbing.
just want to know what you guys do to get lower than this? not sure i want to go to a 35 profile just yet.
NORFY is offline   Reply With Quote
Old 04-10-2013, 06:51 AM   #2295
Attridge_300ZX
The first setup looks good, the second one looks retarded and doesn't fit. Do you know for sure the first setup is running 285 on all 4, and what kind of work he did to get that setup to fit. You can make anything fit with enough work, but I'm looking for function over form, that second setup does not function well.
Old 04-13-2013, 01:46 PM   #2296
MrSanchez925
MrSanchez925 is an unknown quantity at this point
Will a set of rota grids 18x9.5 +20 with a 235/40 clear the front coilovers on my s14?
MrSanchez925 is offline   Reply With Quote
Old 04-13-2013, 01:49 PM   #2297
MrSanchez925
Oh wait a minute...
That white z32 isn't running a 285 in the front or rear. It's a known car in the z32 community .
Also in order to fit. A 285 in the rear will need a higher offset or you will start rubbing in the Rucas
Old 04-14-2013, 07:57 AM   #2298
fliprayzin240sx
You mean lower offset? I dont see how higher offset (sinking in) will help you clear RUCAs.
I'm just going by what was posted on Rimtuck...guy said he's running 285 all around per his specs.
CLICK HERE!!!
Old 04-14-2013, 08:41 AM   #2299
MrSanchez925
Sorry I meant lower offset .. Derp moment. Lol.
Old 04-14-2013, 08:57 AM   #2300
humilde_s13
humilde_s13's Avatar
humilde_s13 is an unknown quantity at this point
I will give you my pistol ammo at the speed of light towards your doom
humilde_s13 is offline   Reply With Quote
Old 04-14-2013, 09:01 AM   #2301
fliprayzin240sx
Hmm...after looking at the white Z32, isn't that Edgar's (ArcticDragon) car? Havent seen his Z32 around here in a while. I've always liked that car...
http://www.rimtuck.com/setup/view/233
CLICK HERE!!!
Old 04-14-2013, 09:06 AM   #2302
MrSanchez925
yeah its edgars..
It isn't white anymore either.
I'm pretty sure its currently down, getting a motor rebuild.
Old 04-14-2013, 09:11 AM   #2303
MrSanchez925
hold up I'm going to ask him real quick if he is running a 285, I may be wrong actually.
Old 04-14-2013, 09:33 AM   #2304
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
i finally got my set of rims my setup is going to consist of 18x9+30 in the front and 18x10.5+28 in the rear. mind you i bought these rims used i dont have 3k + for new rims and custom offset... there going on a s14.so can you guys please help me out with this setup tires camber adjustment etc.... thanks and my bad if i piss you off i tried rim tuck but no one has similar setup i hope its not gonna look retarted thanks.
jlmillionaire is offline   Reply With Quote
Old 04-14-2013, 10:31 AM   #2305
zooopreme
Trader Rating: (38)
I'll just cut to the chase, it's going to look sunk. The rears should clear w/o spacers but the fronts will rub for sure w/o spacers.
You don't have $3,000+ to spend on wheels? You could have found a nice pair of used real TE's and gotten new decent tires for less than $3,000. In other words, you made a bad choice.
And lastly, please do your own research on how alignment corresponds to wheel fitment. It's really not that hard to understand how it all ties in. I don't know how much camber you're willing to run. I don't know what tire sizes you want to run. Your choices are almost unlimited. This thread is for those that have an idea of what they want to do and see if it fits. You simply put specs and expect us to list choices for you. You're 30 years old, this shouldn't be your first rodeo.
Old 04-14-2013, 11:49 AM   #2306
MrSanchez925
Will a 18x9.5 +20 with a 235/40 series tire clear the front coils on my s14?
Old 04-14-2013, 12:13 PM   #2307
jlmillionaire
it is my first rodeo with rims your rite ill figure it out my self thanks for the input.
Old 04-15-2013, 02:37 PM   #2308
San Diego Kouki
San Diego Kouki's Avatar
San Diego Kouki is an unknown quantity at this point
Anybody have experience with Work meister m1r or SSR professor ms1's? I have an s14 kouki and want to run 18x 9.5's all around. I have all 4 fenders rolled and know what tires to run but I want the maximum lip size without needing to pull any metal or worry about clearing my z32 brakes up front.
San Diego Kouki is offline   Reply With Quote
Old 04-15-2013, 05:21 PM   #2309
fliprayzin240sx
You'll probably need spacers in the front to clear suspension, atleast 5mm depending on your suspension/coilover setup. Its not all bad, beauty of running higher offset wheels is that you can run wide ass tires. Since you have all the space in the world, you can run it with no camber. Dont really need the camber if its a DD, get it within OEM spec.
CLICK HERE!!!
Old 04-15-2013, 05:23 PM   #2310
fliprayzin240sx
Well, if you have Z32 brakes up front, you'd need the big brake faces for the front. Rear, you can go for max lip, should clear even Z32/R32 rear brakes on the the flat face version of the wheels.
CLICK HERE!!!
