#2282 |
maybe its just me and the fact i daily my car and such. but seeing a rail choped and patched like that just makes me cringe.. i realize its for a reason yes. but if he get hit hes fucked.. i unno. thats just me i guess. and when im welding, im still learning, but im always covered. helmet, gloves, jacket. the whole thing man. not worth not having it in my opinion
WTB: 1/24 scale chuki s13 model. |
#2283 |
#2284 | |
![]() Join Date: May 2006
1) Grant's car won't see street use? and 2) That frame modification makes the car less safe? How is he "fucked" if he gets hit? The frame is now fully boxed, instead of having two creases pinched and spot-welded, it's much more resistant to deflection/deformation on all axis from what I can see, especially laterally from "getting hit". Just saying, just because the welding job wasn't pretty doesn't mean it's not a structural improvement overall.
#2285 | |
by changing the factory way the rail was created may, quote May, interfear with certain things like crush zones and other parts of the structure of the car possibly makeing it not do its job in an accident. the rail was made that way for a reason. be it simplicity and the fact that it was easy to do, or that it effects the way the structure will act during a collision. its not smart doing stuff like that to rails simply because it changes how the car will react in an accident. so if its weaker, wich i doubt it is in his car, it will crush easier meaning it will probably effect the passenge area of the car. and if its stronger then it should be, it may not bend, kink, or crush at all. makeing the passenger area more vaulnerable to getting smashed together. either way itl effect the way the car performs in a hard hit. its just not as safe is basicly what im saying. i dident mean to sound like i was telling him he did a shity job or anything. as far as the weld itself, looks a hell of alot better then my overhead welds right now. i unno, i guess its just not something id consider doing to my car. sorry for the bad spelling, hope all that made sense.
#2286 | |
Different strokes, I guess. BTW Grant was using a picture he got from someone else, he hasn't actually done the mod yet.
#2287 | |
however, the rail idea does seem very useful... haha
#2288 |
LAID OUT
![]() Join Date: Mar 2004
Made a quick heatshield for my RB HKS manifold:
![]() ![]() ![]() Not my best welds ever but I'm sure it will hold, hopefully it helps a little with the heat. Comment/suggestions from the fab gurus? |
#2289 |
#2290 |
im not sure if this is were i should ask, but has anybody ever had issues with miller welders? i think the one i was useing was the little 110v. not entirely sure tho. it just dident seem to want to coperate with me today. it kept popin and shit. it was dialed in right any everything. even the instructer said he dident know what was up
#2291 | |
Make sure you are welding on something clean. Dirt and other contaminates will make it do that. Something new we finished the heat shield sorry for the nasty tig welding my partner welded it. We just have to powder coat it now. ![]() ![]() My bandsaw ![]() ![]() and the srt new water line/pipe just needs a good polish now. ![]() ![]() |
#2292 |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
How much tubing do you guys think I need to make a 6 point cage with door bars?
it will be going in a coupe. I would also like to add a cross bar and x-bar in the rear.
1994 FD3S Drift // 945garage // |
#2293 |
#2296 |
Who do you go thru for your SS bends? Local / any recommendations to an online dealer.
#2297 |
![]() Join Date: Feb 2009
some savage work there s14 kouki.
"Racing is life. Everything else that happens before or after is just waiting." ~Steve McQueen [Le Mans -1970] |
#2299 | |
#2300 | |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
i think he means this one http://zilvia.net/f/tech-talk/128515...ld-thread.html
#2301 | |
#2302 |
LAID OUT
Started putting my "catback" exhaust together for the 13. Nothing special, 3" mild steel to some blast pipes, tucked as high up as possible.
I had a question though, what can I do to reduce splatter? Basic setup: Gas shield MIG, 30 wire E07S6 on 16ga mild 3" and a 3/8" mild flange. To prep I use wire wheel and/or hand files... Honestly I cut corners on cleaning with brake cleaner, rarely if ever do that... MIG gas is 86/14 ar/co2 mix at ~20cfm. ![]() ![]() ![]() That is a two-pass weld, but it seems like more splatter than usual. Exhaust so far... ![]() ![]() Last question regarding penetration... Obviously this is "just" an exhaust and super deep penetration isn't really needed. But how does this look? To me it seems like I could have laid into it a little more and/or used a little more heat, but I'm not sure. ![]() Always looking to improve my skills, comments/suggestions always welcome! How are all the other badass projects in here coming along?!! |
#2303 |
exhaust is looking good
plenty of penetration for an exhaust you should be fine maybe turn the feed speed down a tiny bit to get rid of the slag splatter
Need automotive work done in the antelope valley? Ask me how i can help. |
#2304 |
LAID OUT
Thanks for the input I'll give that a shot next time. I honestly didn't tune the machine very well, kind of re-used whatever random settings I had on it before.
#2305 | |
![]() The anti splatter is not 100% but it works and just make sure your pieces are clean. As said before you can play with the wire feed also. |
#2306 |
LAID OUT
I haven't tried the gel, but I do use the spray regularly. I only use it on the nozzle/cup to prevent slag build up. It works great in there, but how would I apply the aersol to the weld without getting it into the bevel/joint prior to welding? Or is that not an issue? I'd think if it gets into the joint it would cause major problems with the weld.
LOL regarding the welds, I only have the MIG at my house now and the first pass had a few holes due to starts/stops. Threw another bead around it since I didn't want to deal with any leaks. Honestly I've had poor luck with other exhausts cracking so I don't mind if it's a little 'industrial' hahaha. Rest of the exhaust I'll try my best on the TIG. Thanks guys for the tips, I'm just some guy who's teaching himself to weld out of curiosity and desire for self-sufficiency! ![]() |
#2307 | |
#2308 |
MELLO*SOS I'm going to pretty much echo what S14 Kouki said. Regarding spatter, at work we use spatter spray regularly on anything thats being MIG welded. We do a lot of projects for the Gov't including Dept. of Defense and Dept of Energy. They were fine with anti-spatter being used on the pieces prior to welding when they certified the project and us.
Penetration looks good, but inconsistent. This is likely due to inconsistent speed which you'll get better at with practice. Keep up the good work. |
#2309 |
LAID OUT
TIG and S14 Kouki you guys are great, thanks for the tips. Regarding the spray, you just spray down the piece around the joint and it doesn't matter so much if it gets in the joint? I'm assuming the arc is hot enough to burn that stuff away. Wasn't sure if it would cause any issues with the weld later on. pen. is probably not consistent due to doing several start/stops on the first weld. I am still learning how to walk around the piece for fewer stops
![]() Am I the only one working in the garage? When I log into this thread on Monday I wanna see updates from the other baller projects taking place! haha Have a good weekend zilvia fabricators!! |
#2310 | |
My awesome matco table and dynasty 200 ![]() Table very messy with projects. ![]() My bandsaw (when it was still new) ![]() |
