Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Misc & Accessories
Old 12-01-2008, 12:32 PM   #2341
BigwaveSC
BigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really niceBigwaveSC is just really nice
Originally Posted by dirtdiggler666 View Post
2 sets of 15mm bolt on spacers shipped to ca 93551
4 lug or 5 lug?
http://i611.photobucket.com/albums/tt198/bigwave92107/dave3.jpg
BigwaveSC is offline
Old 12-01-2008, 04:49 PM   #2342
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
my bad 5 lug
dirtdiggler666 is offline
Old 12-01-2008, 04:57 PM   #2343
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
pm sent about those drifty spin knoby things... well its more of a shipping question lol! haha
bejota180sx is offline
Old 12-01-2008, 06:00 PM   #2344
BigwaveSC
my bad 5 lug
$150 shipped.
and that is the last of our 15mm 5lugs
Old 12-04-2008, 12:22 PM   #2345
aa87
aa87's Avatar
aa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant future
Send a message via AIM to aa87
6k springs, tension rod nut/bolt to 71115?
Also, anyway to get the click adjuster things or how to fix one, both of my front ones seized up, rear ones work fine for some reason.
Hookers and blow.
aa87 is offline
Old 12-04-2008, 01:51 PM   #2346
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
$76
I've never had one of the adjusters seize, but if you force it against the end of the adjustment full soft or full hard, then it requires the same force to turn it back. I imagine that the damper shaft shaft being steel, if there was water down the adjustment hole it could cause some rust. Obviously this would never happen in the rear because the adjusters are in the interior, but it is possible in the front. If this theory is correct, I would blow some compressed air back and forth across the adjustments hole to get any standing water out and then hit it with some spray lube, get it free with a hex wrench, then make sure you get out the excess lube.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline
Old 12-04-2008, 01:59 PM   #2347
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Number one!!!!
finally installed my piro tension rods.
http://bhworld.wordpress.com/
Brian is offline
Old 12-05-2008, 01:26 PM   #2348
DC Dan MAX USA
Trader Rating: (79)
Thats hot. I missed you on sunday man
Old 12-05-2008, 01:38 PM   #2349
Brian
Brian's Avatar
Trader Rating: (54)
Yeah me too.... stayed home to try and finish my car.
Brian is offline
Old 12-06-2008, 08:59 PM   #2350
suprafreak1000
suprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfectionsuprafreak1000 is close to perfection
hey could i get a magnetic oil drain plug?
how much shipped to 91320 please?
suprafreak1000 is offline
Old 12-08-2008, 12:59 PM   #2351
wicked91de
wicked91de is an unknown quantity at this point
payment sent for coilovers
wicked91de is offline
Old 12-08-2008, 03:50 PM   #2352
DC Dan MAX USA
Trader Rating: (79)
$17
Tracking emailed, thanks!.
Old 12-10-2008, 04:12 PM   #2353
DC Dan MAX USA
Trader Rating: (79)
A couple of Hybrobrake updates:
My video focusing on the Hybrobrake use at Horse thief mile....
http://www.youtube.com/v/GkaNrnwAyzM&hl=en&fs=1
Heres the install on Dave Blunt's Drift Spec BMW
I love this car!
FYI the rear brake line splice point on this vehicle is after the porportioning valve near the frame rail in the engine compartment.
MAX Hydro Brake Version 2.0 In stock in the USA NOW!
Standard Hydraulic side brake version two features include:
~More brake line pressure
~Willwood master cylinder
~Adjustable bump stop
~Steel tranny housing reinforcement plate
~Extra long handle
~Heim joint linkage
~Delrin Bushings
~Bomb proof steel case
~Foam rubber grip
$220 + Shipping + $80 for Earl's Stainless steel lines and fittings
Tension Rod Handle option is $100 extra.
Old 12-10-2008, 07:44 PM   #2354
danman04x
danman04x is an unknown quantity at this point
Rear toe rod for an s13 shipped to 20855. Also do you really think it is necessary to get the 2 gen toe rods? I mean how low can i go before im gunna need that bend in the toe rod? Thanks
danman04x is offline
Old 12-11-2008, 06:25 PM   #2355
DC Dan MAX USA
Trader Rating: (79)
$195 shipped for G1 toe. You need to spend $20 more and get the G2 Toe if you want to get gangster like this:
Old 12-11-2008, 09:56 PM   #2356
Z33dori
Z33dori's Avatar
just wondering with the the hydro brake... do you still have to press the clutch to actually lock the brakes, or does it create enough pressure to actually stop them...
idk may seem like a dumb question, but i'm just curious.
Z33dori is offline
Old 12-11-2008, 10:05 PM   #2357
Rogue240sx
Rogue240sx's Avatar
Rogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud of
Send a message via AIM to Rogue240sx
well if you don't push the clutch you'll stall the engine.....
There's not enough hours in the day.
Rogue240sx is offline
Old 12-12-2008, 04:02 PM   #2358
DC Dan MAX USA
Trader Rating: (79)
To bring the wheels to a full stop, yes do have to clutch in to lock the rear up hard, but thats not always necessary and if you did that too much you'll just give your tires gnarly flat spots
There is all types of situations in which you would use the brake, but typically
if you would want to lock the rear wheels coming into a corner you would
A) aproach the corner overspeeding
B) Initiate drift early
C) push in the clutch
D) hold the lever
E) steer towards the apex
F) mash the gas
G) dump the clutch and release lever at the same time for the second half of the corner drift & corner exit
generally speaking yes ~ just like mashing on the (foot) brakes would stall the motor without pushing in the clutch however the hydrobrake is not an on/off switch. You can give it some finesse while the clutch is out to subtly modify the drift. Just like left foot braking its counterintuitive to touch the hydrobrake while you are on the gas but believe me it still works.
Taniguchi talks about this, he uses the side brake in a manner that does not lock the rear wheels so that the crowd/judges can not see the sudden change. The Drift flows better and appears more seamless & creates a look that is less abrupt or jerky.
Old 12-12-2008, 06:31 PM   #2359
Rogue240sx
Rogue240sx's Avatar
Cool
D) hold the lever
F) mash the gas
Well yes, but when the rear wheel are locked without pushing the clutch there's no way the engine would continue to run unless you have a really shitty clutch. I was just answering the question.
Completely locking up the wheels is the wrong way to go about initiating a drift anyway you lose momentum and the car's handling is greatly upset and will most likely send the car into an uncontrolled slide (possibly into a solid object) rather than a nice smooth controllable drift. Smooth driving techniques are paramount as Taniguchi states in his techniques. I wish they'd teach this sort of stuff in basic driving school I'm sick of dodging people who can't seem to properly control their vehicles.
But anyway back on topic. Buy from these guys they know what they're talking about and their shit is top notch.
Old 12-12-2008, 06:44 PM   #2360
AzNCmB
AzNCmB's Avatar
AzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond repute
Send a message via AIM to AzNCmB
pbm fender roller tool,
got anymore left?
how much shipped to zip code 70058?
thanks
duh mah! wheels and suspension!
AzNCmB is offline
Old 12-12-2008, 07:01 PM   #2361
drftwerks
how much for that hard wheel for the roller shipped to 95129
giantroboteyes.wordpress.com/
drftwerks is offline
Old 12-12-2008, 08:47 PM   #2362
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
fender roller shipped to 68526? as asked above, have any in stock? have any version one's that you want to get rid of for cheap?
irritatedmax is offline
Old 12-12-2008, 09:51 PM   #2363
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
New orange annodized MAX oil plug.
how much? shipped to 92704
hOngsterr is offline
Old 12-13-2008, 12:47 PM   #2364
jflor004
jflor004's Avatar
jflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud ofjflor004 has much to be proud of
Thanks DAN for the parts, got em super fast and they'll all great. Super fast, cheap, and great service. Everyone BUY!!!!!
jflor004 is offline
Old 12-13-2008, 03:55 PM   #2365
TylerHillis
TylerHillis is an unknown quantity at this point
price for new shock cartridges for the coilovers?
TylerHillis is offline
Old 12-13-2008, 04:11 PM   #2366
Z33dori
Z33dori's Avatar
thanks for the info dan...
Z33dori is offline
Old 12-15-2008, 01:25 PM   #2367
DC Dan MAX USA
Trader Rating: (79)
<3
got anymore left?
thanks
Yes we do! $237.16 shipped
$20 shipped
$243.76 in stock now, V1 is long gone.
$17 shipped
= ) thank you for your feedback
$100 ea for a 100% new damper
no problemo
Old 12-15-2008, 04:30 PM   #2368
brad_240sx
brad_240sx is making a name for him/her selfbrad_240sx is making a name for him/her self
orange drift knob shipped to 84720
brad_240sx is offline
Old 12-15-2008, 04:34 PM   #2369
irritatedmax
paypal has been sent for said amount. will i have this before christmas?
thanks!
Old 12-15-2008, 05:01 PM   #2370
DC Dan MAX USA
Trader Rating: (79)
$20
thanks!
Tracking emailed. It should be there this week.
