Old 08-25-2010, 10:56 AM   #211
PoorMans180SX
PoorMans180SX's Avatar
I hope you realize that exhaust manifold's collector flows like dog crap.
Old 08-25-2010, 07:31 PM   #212
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
Hahahaha man that was so blunt
Daily driven
jspaeth is offline   Reply With Quote
Old 08-26-2010, 11:09 AM   #213
Z28ricer
Z28ricer is an unknown quantity at this point
I'm betting you dont put down that impressive on the numbers either, the main reason being you started with the 2871, and then added the big compressor cover, however this still sticks you with the 53.8mm exhaust wheel used in the GT2860RS/GT2871, if you had started with an actual 3071R, then you'd have the 60mm turbine side, and the potential to make more power, and that external gated housing is avail for the 60mm wheel, which makes me really go "yeah shoulda done it this way"
For a good example of what I mean, take a look at the factory GTiR turbo vs the S14/15 T28, the gtir has a smaller T3 compressor housing, the same compressor wheel, yet its rated for 2 lbs/min more airflow due to the 79 trim exhaust vs the S14/15's 62 trim.
Z28ricer is offline   Reply With Quote
Old 08-26-2010, 08:34 PM   #214
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
I already had a 2871R to begin with so i decided to use it.... Also if i decided to go with a 30R it definately wouldnt be a 3071 it would be an HTA3076R or something better because these turbos are actually pretty outdated now so to say.
S13 curtis is offline   Reply With Quote
Old 08-27-2010, 02:07 PM   #215
Z28ricer
Yeah, I figured, i'm sure it will still perform well, I just dont see it doing anything spectacular due to the smaller exhaust wheel.
Old 09-01-2010, 02:33 PM   #216
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
[quote=codyace;3603074]Whatever happened to the last 2871r you had? And the motor as well?
/quote]
motor is sitting in my garage. just need to put the oil pan on and cams in. should be going in the car this weekend.
idahotuner is offline   Reply With Quote
Old 09-01-2010, 04:33 PM   #217
Z33dori
Z33dori's Avatar
factual fact is factual
Old 09-02-2010, 10:37 PM   #218
S13 curtis
S13 curtis's Avatar
Im pretty sure the manifold will flow better than an unported stock manifold, and yea the collectors on these t2 manifolds suck.
Old 09-08-2010, 05:49 AM   #219
S13 curtis
S13 curtis's Avatar
Well im back in the states now and I actually got a chance to check my car out for the first time and man it is huge and i mean huge compared to the regular 2871, pics dont say much but in person its a big difference and by the way the exhaust housing is T3 .72 a/r with a T2 flange bolt pattern on it if nobody gets this i will explain. The last piece comes in today which is a silicone coupler i was missing. I should have the car started probly tomorrow and i will try to get a startup and walk around video for you guys.
Old 09-09-2010, 04:00 PM   #220
S13 curtis
S13 curtis's Avatar
Pics of the finishing touches and by the way im back in orlando to get this done! Pics i snapped:
Fittings under intake manifold:
Compare Old vs. New
Old:
New:
On with the pics:
My Evo & S13
Royal Purple added:
So everything is pretty much looked over and done now.
jus need another tire before the dyno.
Old 09-09-2010, 08:36 PM   #221
idahotuner
looking good man. ready for some detailed dyno numbers
Old 09-13-2010, 01:38 PM   #222
coolxmas
coolxmas is an unknown quantity at this point
I'm planning doing the same kind of setup but I will start from a T2 gt3071r that has 56.5mm exhaust wheel and 4" comp inlet also...I will wait for your numbers to see if it worth the extra work of going this turbine housing vs regular one
coolxmas is offline   Reply With Quote
Old 09-13-2010, 01:40 PM   #223
coolxmas
By regular one I mean the standard 0.64-WG
My S14 stock T28 is just sold now so there is no way back and winter is coming here...my car is parked till next spring
Old 09-14-2010, 09:19 PM   #224
S13 curtis
S13 curtis's Avatar
Should have dyno numbers up tomorrow evening. The was car is at the shop today to get tuned but ran into wiring problems so tomorrow should be a graph for you guys.
Old 09-16-2010, 10:15 PM   #225
S13 curtis
S13 curtis's Avatar
Well long story short, It had to be re-wired 2 day proces then finally getting it started Put it on the dyno not even 1 complete pull and a Cam Gear comes off and there goes my motor. FML im fuckin pissed and i paid for all the wireing and partial tuning $600 bucks and motor went to shit... I jus have bad luck. Journey is over, im going to part this car out someone else can finish this off.
Old 09-16-2010, 10:30 PM   #226
Weedm
Weedm's Avatar
Weedm is an unknown quantity at this point
this sucks. really bad. ._.; sorry to hear man. If I were in your shoes id be eating a donkey right now.
make a thread for your items and I may buy a few things. want those kouki tails definitely.
Weedm is offline   Reply With Quote
Old 09-17-2010, 01:18 AM   #227
efrain240sx
efrain240sx's Avatar
efrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enough
dang that really sucks man
efrain240sx is offline   Reply With Quote
Old 09-17-2010, 02:14 AM   #228
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
Sorry to hear about the tuning day.
PM me about engine building? Very reasonable prices, short turn around and reliable.
~mario
GR Performance
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 09-17-2010, 06:17 AM   #229
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Wow that blows... LMK if u wanna part the block only and possibly the turbo kit
BiG MiKE86 is offline   Reply With Quote
Old 09-17-2010, 02:28 PM   #230
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
did the cam gear actually fall off, or did it fall out of adjustment and mess up the timing, thus destroying the motor?
Slidin' Sam is offline   Reply With Quote
Old 09-17-2010, 03:43 PM   #231
RurouniMidnight
RurouniMidnight's Avatar
RurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to all
Damn this sucks i was hoping to see what kinda numbers it would put down, really intrested in using the external exhaust housing later on when i upgrade my turbo. Sorry to hear motors breaking is never a cool thing.
http://nightparade.wordpress.com/
Join in on instagram @nightparade
RurouniMidnight is offline   Reply With Quote
Old 09-17-2010, 04:30 PM   #232
Om1kron
Om1kron's Avatar
haha damn what a slap in the fucking face.
Wayne Edwards
https://om1kron.blogspot.com
Old 09-17-2010, 10:03 PM   #233
S13 curtis
S13 curtis's Avatar
Cam Bolt came all the way loose and Timing all fucked up and Valve connecting with piston isnt good.
Old 09-18-2010, 03:09 AM   #234
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
Decided not to torque it or what?
sounds wack that the bolt just backed the fuck out.........................
sorry to hear though bro
nieko is offline   Reply With Quote
Old 09-18-2010, 04:00 AM   #235
fishboi
fishboi is an unknown quantity at this point
Should have used red loctite on those bolts. How much did you spend on this build? I can't believe this happened.
fishboi is offline   Reply With Quote
Old 09-18-2010, 05:03 AM   #236
dj12
dj12 is an unknown quantity at this point
damn i was really hoping to see some numbers. sorry to hear mang.
dj12 is offline   Reply With Quote
Old 09-18-2010, 07:20 AM   #237
S13 curtis
S13 curtis's Avatar
I guess my "Friend" was really careless when he put it togeather, keep in mind I was in Korea and he put it togeather for me, swore up and down it was done right, he messed up the wiring which caused it to be at the shop for 2 days with map sensor short with 12v instead of 5v and all fucked up wiring, costed $300 in wiring and a 2 day delay in dyno time. Then he didnt double check the cam gears when he put it togeather and torqued it down if it even was. The motor blew due to carelessness and not having parts properly installed. Never again will I trust someone other then myself or a professional shop to work on any of my cars.
Like the tuner straight up told me, "you can pop the hood of my car and tell just by looking that there was alot of money put into it, but that means nothing if parts wern't installed correctly,I don't want to have anything to do with this car because it wasnt put togeather right, A Real friend woundnt half ass it, You can tell he didnt give a fuck because it wasnt his car."
I 100% agree with him on that.
The pics dont do it justice you have to see it in person.
I jus belive they were never torqued down to spec.
Alot of money, i tried to make the most elite 2871 setup while still staying bottom mounted. The build def has over $3k in parts.
Old 09-18-2010, 07:39 AM   #238
Geno750
Geno750 is an unknown quantity at this point
Send a message via AIM to Geno750 Send a message via Yahoo to Geno750
You didn't hear it rattling? I had one start to back out on me and it was louder than hell.
Geno750 is offline   Reply With Quote
Old 09-18-2010, 08:02 AM   #239
S13 curtis
S13 curtis's Avatar
Car had the cutout open and it was way too loud to hear anything until something broke,and car was breaking up.
Old 09-18-2010, 08:08 AM   #240
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
What a fuckin bummer brother! Man that was the last thing I could imagine ever happening to a car that was freshly done...hell I felt sick to my stomach when I recently mis stabbed the CAS off a tooth and the car didn't run for shit...I could only imagine if I was 'your friend' that bombed the engine....damn
I wouldn't EVER use loctite on the main bolts that hold the cam gears to the cams...hell they are darn near 100ft lbs of torque as it is...
unless you're talking about on those stupid slider things, which I wouldn't ever ever ever use....they always come loose and fuck up IMO.
