#212 | |
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
Answers below:
#213 |
![]() Join Date: Apr 2009
Trader Rating: (46)
![]() Feedback Score: 46 reviews
so, in terms of keeping the interior parts like the dash and panels soft, what would you recommend to keep these from getting brittle? heard through the grapevine that armorall isn't any good.
#214 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
I'm not really sure if there is a good solution for plastic. I have always used Snap-On Protect One on mine with good results. But that doesn't really mean anything in the end as it may still become brittle in the future. |
#216 |
![]() Join Date: Sep 2011
1.Do you sell any alarms that alert with the horn of the car? 2. Is there one with Remote Start that also uses the horn 3. With Remote start do you still have to use the key to drive, as in get in after its started and still have to use the ignition cylinder?
#218 |
Trader Rating: (55)
So this is embarrassing. I tapped into the wrong red/white wire for the door trigger. I had only seen one so I had not bothered checking it with the multimeter. I got it hooked up correctly and am now able to get into the menu! I set Menu 3 Feature 8 to Accessory 2, however, the remote start still does not work. I did not integrate the clutch switch into the alarm yet so I'm trying to remote start it while holding the clutch down, however, the remote start is not working. Are there any other features that have to be set for the remote start to work? In the mean time I'll work on getting the proximity sensor wired in.
#219 |
![]() Join Date: Nov 2006
![]() ![]() Feedback Score: 9 reviews
Price quote on a 90 degree -4an and a 90 degree -8an fitting both in either silver/red or red/blue shipped to ny 11432.
www.tm-spl.com Kouki's & some apple juice. |
#220 | |||
2) All Viper remote start/alarm combos have a dedicated horn output. 3) Absolutely! Because when you get in the car after remote starting, as soon as you depress the foot brake the remote start will shut down... thus shutting the car off. If you have the key in the ignition and turned to the ignition/run position then the vehicle will stay running when you depress the brake. You then simply drive away. Quote:
You need to give me part #'s man. I don't know if you want non-swivel, double swivel or double swivel forged? |
#221 | |
Trader Rating: (55)
Manual transmission remote start If the vehicle has manual transmission the proper steps must be followed before leaving the parked vehicle or the remote start feature is disabled. 1. Make sure the doors on the vehicle are closed. 2. Put the transmission in neutral. 3. Press on the brake in the vehicle. 4. Apply the emergency brake. 5. Release the brake. 6. Within 15 seconds activate the remote start from the remote. 7. The parking lights will flash confirming that the remote start is active. 8. Turn off the ignition (the car should stay running when key is turned off). 9. Exit the vehicle. 10. Arm the alarm (the vehicle should shut off when arming the system). I'm assuming you have to start the car before you begin this sequence? The manual doesnt specify. When I try this and I turn the ignition to off the car turns off. I don't think I have my parking lights wired in correctly as i did not turn the fuse to "+" as I am not quite sure how to do that. Will that prevent this from working? |
#222 | |
First off, did you wire the tachometer wire? It is the violet/white on the Viper. You then need to learn the tach signal to the Viper. Did you do all of this? If so, proceed to the proper activation below:
Note: if the alarm goes off, a door is opened etc. then remote start mode will automatically be canceled. |
#225 | |
#226 |
![]() Join Date: Jul 2011
Ok so attatched is a picture of my beeper for my car alarm. I am not familiar with this alarm at all and when I googled the brand to figure more about the alarm system, my beeper wasn't found anywhere on the site. It might be an older model, I don't know.
So to my question. My car alarm has a few warnings and it constantly goes off. There is nobody anywhere near my car and it still manages to go off. It has a 3 beep warning system but that constantly goes off as well. I was wondering if you knew more about this alarm and if you can give me maybe a model name or something. I would also like to know how to turn down the sensitivity. I bought the car with this alarm and this is the only way to lock my doors since the previous owner was stupid and removed the key locks... I was wondering if there is a way to just use the beeper to lock the doors without engaging the alarm. Would I have to disconnect the horn? (This unit came with a horn so I'm not using my OEM horn.) If needed, I'll try to find the main unit somewhere in the car, I have an idea of where its at but I can't really confirm since I don't know what I'm looking for... EDIT: I dont even know how to change the time on the damn thing... EDIT 2: Buying a new alarm is currently out of the question because I can't afford one at the moment but I do plan on buying a Viper alarm from you eventually... |
#227 | |
Trader Rating: (55)
#228 |
Trader Rating: (55)
So now I'm stumped. Remote start will only work once after do i this sequence. I have to do the sequence every time for it to remote start. Is this expected behavior?
#230 |
![]() Join Date: May 2010
![]() Feedback Score: 17 reviews
First of all, just installed the 2 way alarm i bought from you, works like a charm, thanks!
Now i have a question, i am completely and i mean completely clueless when it comes to sound systems. I am looking to replace my speakers on my s13 and add some in the rear. I am looking for some good quality speakers with decent bass of course. What would you recommend for a good set, I dont need the top notch speakers that will make the windows on the car next to me shake but i want something definitely worth the price. Like someone else stated in the thread, I will be drifting the car so I am not looking to buy a sub I MAY consider a amp, but i rather not. Would just like a good speaker set up that will not sound like garbage. I also saw that you refer to Hybrid Audio as a good brand. Do you recommend any other brands? And also, what line of speakers do you sell.(if any? although i think you do sell speakers as well, could be wrong.) thanks!
http://upsidedownsideway.tumblr.com/ |
#231 | |||||
![]() So to answer your question: Hybrid Audio. There isn't a better speaker at any price point. I would recommend either the Mirius or Imagine... although I'm going to assume the Mirius are more within your price range. An amplifier will really make them come alive though! So I always try to push the customer to consider a decent amplifier... which I recommend one of the ARC Audio XDi series. Please send me a PM or email if you want to discuss pricing and options on anything. |
#232 |
![]() Join Date: Nov 2009
Yo Mr. Broadfield.
In this picture, on your SR20DET setup, you have fancy looking rocker cover bolts. ![]() May I ask where you got them from (if you remember, and are you using the OEM rubber seal/steel washer combo underneath them, or am I seeing things? Thanks mate! |
#233 | |
Note: For my valve cover I had to make my own "setup". The S14/15 valve covers use shoulder bolts to attach them. Whereas the S13's use shoulder studs and nuts. If you have an S13 valve cover then you can simply order the nuts from Gallery Fresh and then maybe reuse the rubber/steel OEM washers like I did. I have never had an S13 SR though, so I can't 100% confirm what the fastener setup is. So back to my setup, I had to order custom shoulder bolts from McMaster Carr and then order the washers from Gallery Fresh. However, even with all of my super Broadfield powers, Gallery Fresh would not let me order just the washers. Gallery only sells the stuff in groups of 2 or 4 and only as a bolt/washer combo, nut/washer combo, screw/washer combo etc. So I wasted money on their bolts just to get the washers... only to turn around and not use the bolts at all. So I spent a pretty penny to make that valve cover setup. |
#234 |
so if i splice in the HUD wires to the factory harness going to an oem analog cluster it will project onto the windshield?
#235 |
If you are using the Defi HUD, then you simply tap into VSS and Tach(RPM) signal. It will then display those items. If you are wanting to display it on your windshield then you would need the Defi-Link VSD Concept. If you want a standalone unit that displays on it's own reflective glass, which is what I use when I mold it into the steering shroud, then you want to buy the Defi-Link VSD-X. Both of which are discontinued. But you can find them new and used from time-to-time on Ebay etc.
#236 |
i was talking about the oem 240 hud with the oem analog cluster, ive searched it alot of times and no one has figured it out, an electronic guru like you i figured you would know better than anyone, i want to try to get both to work but from my understanding the oem hud only works off the digital cluster cuz it just mirrors the cluster image, but if i was to find the diagram for the hud and the wiring diagram for the analog cluster can i just splice in the the wires into the analog cluster and have the hud throw up a display?
#237 | |
I have zero experience with any of the OEM stuff. I just gut them and install cool stuff in it's place. So I have no idea if what you want to do will work. I could figure out if it would work, but someone would have to pay me to do so. If you want to try and figure it out you can simply look in the FSM. It has both the analog and digital cluster wiring schematics. |
#239 | |
Also, did you run your CAS wiring down the turbo side of your engine? I can't see it crossing the front, so I can only assume you did? Did you heat sleeve it or anything? No problems to run it like that? |
#240 |
Yes, I ran it along side all of the AN breather lines. I ran it in some black -4 Thermo-Tec heat sleeve.
broadfield, toby |
