Old 02-12-2014, 12:30 PM   #211
Shopety2012
Shopety2012's Avatar
Shopety2012 is an unknown quantity at this point
Not sure to make a thread following my build because I'm sure I will be asking questions frequently, but I'm building an sr20det, check. I have a s13 red top head and s14 black top block. Now from my RESEARCH I see that it's best if I weld over the vvt oil port in the block, get it decked, then the head should work fine with the block. Can anyone confirm the conclusion I have drawn?
Shopety2012 is offline   Reply With Quote
Old 03-01-2014, 12:30 AM   #212
schoja
schoja is an unknown quantity at this point
What would be the best turbo to upgrade the stock t25 turbo on an s13 redtop? Should I just go with a t28? If so what else should I look into for maximum reliability? I'm not going to lie, I don't know nearly as much as I would like to. If someone could shoot me in the right direction, it would be greatly appreciated!
schoja is offline   Reply With Quote
Old 03-01-2014, 12:19 PM   #213
soundboy
soundboy is an unknown quantity at this point
first do a general service (oils, thermo, plugs), make sure you engine running properly and then upgrade.
a t28 from a s15 is a really nice upgrade.550CC injectors, z32 maf, a walbro fuel pump and some sort of aftermarket tuning is a nice base to start modding and then you can upgrade each parts to suit.
soundboy is offline   Reply With Quote
Old 03-04-2014, 09:22 PM   #214
starboarder2004
starboarder2004 is an unknown quantity at this point
Sent from my SCH-I545 using Tapatalk
starboarder2004 is offline   Reply With Quote
Old 03-10-2014, 02:06 PM   #215
ShowBoobs
ShowBoobs's Avatar
ShowBoobs is an unknown quantity at this point
what is the torque spec for putting the valve cover back on? and is there a certain pattern of torqueing the bolts to properly seat the gasket?
ShowBoobs is offline   Reply With Quote
Old 03-10-2014, 03:19 PM   #216
ultimateirving
ultimateirving's Avatar
Valve cover shouldn't take much thought you can torque if you want but mine has never leaked and I've never torqued it
Z32 with lq4 swap
Old 03-10-2014, 04:34 PM   #217
TheRealSy90
TheRealSy90's Avatar
90 INCH pounds. After all the washers and nuts are hand tight do the center bolts and make up a criss cross pattern, if you have the oem washers they will align the cover.
Such a good signature.
Old 03-11-2014, 09:49 AM   #218
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
Sr20det FAQ
Bought a 91 s13 with s13 blacktop swap. No A/C. I want to put in A/C and I've never done anything with A/C.. HELP!
Originally Posted by xoxide View Post
Gun it towards the nearest mailbox, rip the ebrake, countersteer.
vJilly is offline   Reply With Quote
Old 03-14-2014, 09:24 PM   #219
smoove
smoove is an unknown quantity at this point
Is there a workshop or service manual for redtop? I have seen nothing but the s14 sr which show to be the notch top. Would these torque specs and valve specs be the same? Any help would be greatly appreciated. Thanks for time.
smoove is offline   Reply With Quote
Old 03-20-2014, 12:36 AM   #220
starboarder2004
GO to the attached link and download the conversion info.*https://www.dropbox.com/s/fdntze8utk...R20DET24_1.doc
~Pyng Thai
Tech Support
24-1 trigger wheel ems v1
Old 03-20-2014, 07:43 AM   #221
ultimateirving
Search! I put my a/c together and it's not hard. Cody ace can make you a bracket
Z32 with lq4 swap
Old 03-26-2014, 12:39 PM   #222
SoCalDrifter
SoCalDrifter's Avatar
SoCalDrifter is an unknown quantity at this point
Does anyone know if you can run Tomei solid lifters with tomei lash type 260 cams?
SoCalDrifter is offline   Reply With Quote
Old 03-26-2014, 01:38 PM   #223
Future240
Future Moderator
Future240's Avatar
http://www.sr20acbrackets.com/
Originally Posted by ThatGuy
Old 03-31-2014, 02:26 PM   #224
240kaspar
240kaspar is an unknown quantity at this point
Stock bottom end sr20
I am looking at buying an sr20 240. I was curious what the stock bottom ends are good for power wise. I've read 400whp just wanted to see what members here thought. I'm new to the a chasis world coming from ls cars and an evo.
240kaspar is offline   Reply With Quote
Old 05-16-2014, 12:24 AM   #225
shawn1331
shawn1331 is an unknown quantity at this point
just wondering what the max i can expec out of my red top. running basically 100% stock meaning:
T25
SMIC
OEM shrouds etc.
I have a tubular manifold and elbow to throw on and looking into a downpie. planning on boosting to 12psi, what whp can i expect?
Should i go with a mines tuned ecu/jwt?
shawn1331 is offline   Reply With Quote
Old 05-28-2014, 08:40 AM   #226
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Some gee-wiz info about the S14 SR20DET:
Gear ratios are different than what I've seen posted -
1 - 3.321
2 - 1.902
3 - 1.308
4 - 1.000
5 - 0.838
R - 3.382
FD - 3.692 (US 240s are 4.083)
All S14s came with a boost sensor, but apparently only the Zenki has this connected to the ECU. The boost sensor on the Kouki SR is there only for the optional DIN boost gauge, at least that's what I can figure from studying wiring diagrams for the past two days.
As of mid-2014, most of the images and install guides in this thread are dead links.
Since I have a Kouki S14 SR20DET, finding a wiring guide is problematic. The ECU connector for the Kouki S14 is physically the same as S13 and S15 ECUs. The pinout is not the same as the S15 as many posts seem to suggest (it's close though). Pins 1 thru 48 of Kouki S14 and S15 are about the same, pins 101-116 are different though. I'm attaching an S14a pinout that I found. It says "not JDM" but the only difference is JDM doesn't come with NATS or EGR.
Wiring pinouts: http://www.240sxforums.com/forums/sr...u-pinouts.html
Old 05-30-2014, 09:15 AM   #227
LoSt180
LoSt180's Avatar
Trader Rating: (18)
S14a (Kouki) FSM supplement: http://media.sxoc.com/contributors/v...a-manual_2.pdf
Complete S14 FSM that incorporates S14a changes, and is simply easier to navigate than the Zenki FSM available in nicoclub: http://www.sxoc.com/vbb/showthread.p...op-Manual-v1-1
For the archives: PM me if these links break and I will rehost both documents.
Edit: Both manuals are now being hosted over at NICOclub. http://www.nicoclub.com/archives/nis...e-manuals.html
Old 06-07-2014, 09:59 PM   #228
vJilly
vJilly's Avatar
bought a coupe with an s14 sr20det swap. car has the HUD Dash but I have a dual cam cluster. what would I need to make the HUD display work? car used to be an automatic car with working HUD if that helps in any way.
Old 06-09-2014, 11:35 AM   #229
.db.
.db. is an unknown quantity at this point
I recently decided to reseal and paint my valve cover while the car was down waiting for a front mount. Only to find out afterwards the valve cover grommets dont come as a set. A few of the sites I came across list the grommets at $3-4 a piece. Needing 13 of them, that puts you at 40-50 bucks plus the gaskets. I found a part number from Beck Arnley that is a 4 pack.
Valve Cover Grommet Set (SR20DET) 4 Pieces Included (4 packs required with 3 grommets extra)
Beck Arnley
039-6430
Oreilly Auto Parts - $3.69 EA usually takes a day or two to order
http://www.oreillyauto.com/site/c/de...grommet+gasket
.db. is offline   Reply With Quote
Old 08-03-2014, 02:15 PM   #230
240Kid415
240Kid415's Avatar
240Kid415 is an unknown quantity at this point
Need help bad Bay Area just swapped my sr into a new shell ran fine drove it to the alignment shop oil started spilling bolt came off did complete oil change drove it 1 mile to another shop heater core line snapped off the little shit allllll the way in the back bitch to do now car starts idles rough motor shakes car acts like it wants to die I hardly have any throttle response. Any ideas any people the are close that can help me out have cash just need this thing back on the road since this is my only transportation to work .
240Kid415 is offline   Reply With Quote
Old 08-18-2014, 06:18 PM   #231
jkrlox
jkrlox is an unknown quantity at this point
connecting rod bushings sr20 vs sr20det
I am rebuilding my JDM SR20DET (s14) from 1997 and my repair shop has told me to buy the connecting rod bushings.
The part number for my engine is 12030-79E01
but I can't find it anywhere to buy it
My question is, the bushings from the USDM SR20 are compatible?
The part number for the USDM SR20 is 12030-60J02
jkrlox is offline   Reply With Quote
Old 08-18-2014, 07:23 PM   #232
Lucas_r3is
Lucas_r3is is an unknown quantity at this point
Send a message via AIM to Lucas_r3is
Can anyone tell me where I can find a tune to download sr20det red top t3t4...
Lucas_r3is is offline   Reply With Quote
Old 08-18-2014, 08:11 PM   #233
ultimateirving
Thumbs up
Probably not because there is no such thing as a tune that you can just download.
What Ecu?
And what other mods have to be taken into consideration for a tune. You might be able to download a factory tune for a stock vehicle and then modify the tune to fit your add ons.
Z32 with lq4 swap
Old 09-20-2014, 08:10 PM   #234
sweetsilvia101
sweetsilvia101 is an unknown quantity at this point
oil filter
I am sorry for posting, it just burns me, well there are 2 filters Nissan uses in the us, on every car, don't ask me how I know this, but there are only two, maybe a 65foo and a 55yo,?
sweetsilvia101 is offline   Reply With Quote
Old 11-22-2014, 09:46 PM   #235
casual man mann
casual man mann is an unknown quantity at this point
Any idea where I can get the part number for the two front head bolts? Buddy's builder neglected to include them
casual man mann is offline   Reply With Quote
Old 11-22-2014, 10:14 PM   #236
caglej
caglej is an unknown quantity at this point
Does anybody have any info on this?
caglej is offline   Reply With Quote
Old 11-23-2014, 08:56 AM   #237
jbjslambert
jbjslambert's Avatar
jbjslambert is an unknown quantity at this point
Will work fine. Plug it dont weld it. When you deck the block, make sure you mill the front cover also(oil pump). If not you will have a ledge there when you go to put it all back together
jbjslambert is offline   Reply With Quote
Old 11-23-2014, 02:02 PM   #238
caglej
What are you plugging it with?
Old 01-06-2015, 03:22 PM   #239
Confuzedd
Confuzedd is an unknown quantity at this point
Does anyone know if an AC compressor from a 1992 SR20DE will fit a s15 sr20de ?
Confuzedd is offline   Reply With Quote
Old 01-12-2015, 07:37 PM   #240
S13_K3VIN
S13_K3VIN is an unknown quantity at this point
hello my name is kevin. i got a 1990 240sx hatch with a sr20det swap. would the engine start without the cam angle sensor cap?
S13_K3VIN is offline   Reply With Quote
