05-11-2013, 08:12 AM | #2371 |
Trader Rating: (26)
Feedback Score: 26 reviews
I have a set of 17x9+24 cobra 03 wheels with 245/40/17 tires I just picked up for my s14. The problem is I cant put them on since my 300zx calipers hit in the front. Should I pick up some spacers but then are my front wheels going to poke out a shit load from the front fenders ??
How did this guy do it?? with no spacers! RIMTUCK.com - Setup Here is the exact wheels that I have currently 17x9 Anthracite with Mirror Face 03 Cobra Style Wheels from Wheel Replicas (94-04) - Free Shippping |
05-11-2013, 10:56 PM | #2372 | |
Man w/ CTSV & a Car Seat
05-12-2013, 04:48 PM | #2373 |
I'm considering running this on an s13 with rolled/pulled fenders and low ride height
18x9 et 16 235/40 front 18x10 et20 265/35 rear 3-4 degree camber front zero-1 degree camber rear Does this sound about right? Tires will be g-force comp 2's |
05-12-2013, 05:28 PM | #2374 | |
front will work, rear you might have to go up to -2.5ish camber! i ran 17x9 et12 all around with about -4 camber in the front and -2.5 in the rear with rolled fenders, but in the end it comes down to tire size and thickness
fd3s fc3s mr2 s13 s13 s13 s14 s13vert aristo2jzgte bmw-e46 |
05-13-2013, 12:59 AM | #2375 |
so to get the camber im after in the rear , you think like 25-30 et?
also, do you think those tire widths will have similar minor stretch on those widths? |
05-13-2013, 02:07 PM | #2376 |
hey i have a question, just picked up some new rims for my s14:
F:17x8.5 +20 R:17x10 +20 what tire size should i go with for a nice & reliable poking stretch. thinking about going F:205/40/17 & R:215/45/17 that sound ok? thanks |
05-13-2013, 04:01 PM | #2377 | |||
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 205/55-16 4.4in 12.4in 24.9in 78.2in 811 0.0% 205/45-17 3.6in 12.1in 24.3in 76.2in 831 -2.5% 215/45-17 3.8in 12.3in 24.6in 77.3in 819 -1.0% 225/40-17 3.5in 12.0in 24.1in 75.7in 837 -3.2% 235/40-17 3.7in 12.2in 24.4in 76.7in 827 -1.9% |
05-13-2013, 05:57 PM | #2380 |
I have a 300zx and want to put 350z anniversary wheels 18x8 all around is there any modifications I need to do to put them on? Like pulling fenders and such? Alto what tire size would be best the OEM tires are too tall IMO. Thanks I've been a s chassis guy since the start and this is my first z lol
WTB: zenki hood, passenger headlight!! |
05-13-2013, 06:48 PM | #2382 |
Someone told me they had rubbing issues maybe they were wrong anyways gonna pick some up on Friday and see how it goes.
05-13-2013, 10:20 PM | #2384 | ||
Trader Rating: (31)
Feedback Score: 31 reviews
this is 18x9 +12 and 18x10.5 +18, although not in the tire sizes you are looking for but gives you an idea of how it sits on stock metal.
Slip Gypsies Blog Quote:
05-14-2013, 06:55 AM | #2386 | |
Trader Rating: (31)
the hood came on the car when i bought it, it has no markings on it, but looks like a chaser b-road kevlar, i am going to paint it once my s13 is done because it bothers me being all yellow and ugly
05-14-2013, 07:02 AM | #2387 |
[/QUOTE]
Too undersized for S14s sidewall/overall diameter wise. 205/45-17 and 235/40-17 is about the same diameter wise, but if you decide to stay with 215/45-17 in the rear, that would work too. Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 205/55-16 4.4in 12.4in 24.9in 78.2in 811 0.0% 205/45-17 3.6in 12.1in 24.3in 76.2in 831 -2.5% 215/45-17 3.8in 12.3in 24.6in 77.3in 819 -1.0% 225/40-17 3.5in 12.0in 24.1in 75.7in 837 -3.2% 235/40-17 3.7in 12.2in 24.4in 76.7in 827 -1.9%[/QUOTE] Hmmm interesting, you think i made a bad choice on the wheel size/specs? i have 25+15mm spacers to play with fitment one they come in. 40's will be too slammed and gappy, 45's chunky n prop rub. i also have 20mm front fenderes and 30mm rear overs, have a feeling its not gona be enough to get them flush. still undecided on sizes but which tires do u guys recomend with a good looking strong sidewall? thanks again |
05-14-2013, 08:16 PM | #2388 | |
05-15-2013, 08:14 AM | #2390 | |
Trader Rating: (38)
Feedback Score: 38 reviews
Whether your car is a S13 or 14, 8" +20 looks lame on stock body. And then you're going to add another 20mm fenders to make them sink further? What's with the huge width stagger? If your car can fit 17x10 +25 now, adding 40mm overs and wanting the same fitment in the rear will require a 40mm spacer. Surprising? I know. Also, wheel fitment depends on tire size and desired alignment specs. So if you've got more info on what you'd like to run, you can use this thread as a "will this work? and if not, what do I need to do?" Until then, research, read up, and see what set ups work. |
05-15-2013, 11:17 AM | #2392 |
ohh sorry i didn't see that you wrote pulled and rolled fender. with a pulled fender you could maybe make it even with et20 and the camber you wanted(depending on pull), but those tires are too wide they will have almost no stretch on a 9inch wheel i'd go with a 205/45 or 215/40 and on a 10 inch i'd go with a 235/40 or 245/40. plus if you run square looking tires(no stretch) you will run into rubbing problems if you are planning on going low, stretched tires help A LOT!!
05-15-2013, 07:45 PM | #2394 | |
Trader Rating: (38)
-current wheel specs -desired alignment Just gives an idea where to steer you. But to shout some numbers out, 245/40 but you'll need a decent sized pull. 20-40mm depending on how much camber you plan on using. It'll work but I'm not a fan of super pulls because with that much of a pull, you may as well just go with overs or not even try to get them to fit at all. 10" would be the largest I'd try to fit into S13 fenders. |
05-17-2013, 10:12 PM | #2397 | |
Well, like Zooopreme already said, not under stock fenders. You'd need over fenders. You can't pull S13 rear fenders to fit those, unless you don't mind getting an S13 fender dent. |
05-17-2013, 11:50 PM | #2398 |
Just ordered the wheels. 18x9.5 +12. I should be pretty good with 225/35 on an s13 hatch? (~-4 degrees front, ~-2 degrees rear)
05-18-2013, 11:11 AM | #2400 |
^^^11.5 all around or just the rear? If its just the rear, how much room do you have under the overfenders? No way in hell this would fit on stock fenders.
