04-08-2013, 08:00 PM | #2521 | |
You get the same advantage as a super grommet type gasket like cosworth and the new tomei ! Tomei Powered ยป NEW! Head Gasket Sizes and Design for the SR20DET My tuner ran this set-up on is sr eith a stock h/g , gt35r 35psi 550+whp for 2 year ! He now runs a sleeved block(o-ring) , cosworth h/g , ve cylinder head with a precision 6266 or something like that pushing 740whp http://youtu.be/A4NAQws4DOs
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
04-09-2013, 12:45 PM | #2522 | |
04-09-2013, 03:57 PM | #2524 |
that is the passenger side shock tower. i was told short strand reinforced body filler should be ok with my thinking of any flex.. then maybe a glaze if i cant get the filler to feather edge enough.
04-11-2013, 08:35 PM | #2527 | |
I tough of using the ve oil drive and just shaving my crank pulley to fit ! Less moving part that could fck !? Is there any other option out there to keep my crank pulley stock ?????
04-11-2013, 08:47 PM | #2528 |
04-20-2013, 12:35 PM | #2532 |
I finally got around to getting the engine back in, my VQ53DE-T setup, engine is fully built CP, Manely, Cosworth, BC, Ferrea, the works, should lay down about 600rwhp @ ~14-16psi is the goal anyway. Hoping to actually being up and running by end of may. Lots to do still ugh
04-21-2013, 10:03 AM | #2533 |
Here is the last two years of my life.
Built 13B Gtx3582R/4" straight through exhaust Injector dynamics 850's/2200's custom IC/Radiator/turbo manifold AEM Meth injection All powered by Adaptronic Fd3s Select ECU |
04-21-2013, 10:41 PM | #2534 |
sr22det
apexi rx6 turbo kit. hks cams / bc head q45 TB 700cc injectors / tomei rail yashio waterpump pully custom intake mani
DODOlogic.ca Last edited by ILoveJDM; 04-21-2013 at 11:22 PM.. |
04-22-2013, 07:10 AM | #2535 |
Almost ready to roll:
Motor fully rebuilt - Wiseco pistons/Eagle rods - Tomei 260* cams - BC springs - Tomei solid lifters - ARP main/head studs - Sard 850cc injectors - Tomei M8270 turbo kit and like the rest of ya- a whole bunch of other sheit
04-22-2013, 12:33 PM | #2538 |
Mike, looks good man, but I do not know what you are talking about, my setup is stock...
04-25-2013, 01:59 PM | #2542 |
04-27-2013, 07:21 PM | #2546 |
04-28-2013, 07:15 PM | #2549 |
^That's rad.
Got it back together.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
battery relocate |
