Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Misc & Accessories
Old 03-02-2009, 01:37 AM   #1
jlab
jlab is an unknown quantity at this point
shift knob and drift knob shipped to 79936. oh i ordered coilovers for s14, i know it wont be in til april, do i get free stickers with that? thanks
jlab is offline
Old 03-02-2009, 04:48 AM   #2
Bigt240
Bigt240 is an unknown quantity at this point
Can you tell me the bore size of the wilwood master on your hydraulic handbrake?
Bigt240 is offline
Old 03-02-2009, 05:36 AM   #3
TRU_DAH-V
TRU_DAH-V's Avatar
TRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfectionTRU_DAH-V is close to perfection
can i get a quote for s14 coilovers shipped to guam 96915
and i alo want to pre order the steering angle nuckle kit will it still be 250 shipped?
http://zilvia.net/f/avatars/tru_dah-v.gif?type=sigpic&dateline=1234268839
TRU_DAH-V is offline
Old 03-02-2009, 07:32 AM   #4
chavoush
chavoush is an unknown quantity at this point
can you please give me a quote for wheel spacers one 25mm set and one 30mm 5 lug 114.3 (12x1.25) AND magnet oil drain plug shipped to 78230 AND how much for local pickup?
thanks
chavoush is offline
Old 03-02-2009, 06:44 PM   #5
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Originally Posted by 1slowS13 View Post
money sent thru pay pal for those subframe spacers!!! thanks!
tracking sent via email
Originally Posted by harangatang View Post
money sent
tracking emailed
Originally Posted by titopr06 View Post
hows it going
s13 rucas shipped to 00745 puerto rico, thanks.
$237 allow 7 weeks for delivery.
Originally Posted by g2ic02 View Post
Fender roller, subframe spacers and spin knob shipped to 55021
$248 shipped
Originally Posted by ILoveMyRHS13 View Post
Hey, Dan, I ordered a magnetic drain plug and two MAX stickers on Feb. 14th and I still haven't gotten anything yet. Any way to track the progress? Thanks!
I sent an email to your RPS13.Guy account 2-16 saying "I cant see an address attached to your paypal account- please advise." and got no response.
Originally Posted by CAPoweredS14 View Post
How much for FMIC for S13 SR shipped to 77573? Please and thank you!
Out of stock - Sorry!
$81 shipped. Sure why not!
.625
$1118, yes $250 is correct.
thanks
I have the Oil plug & have 25mm in stock but not 30mm - they're 1.5 months away. Please let me know how you would like to proceed.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline
Old 03-02-2009, 08:11 PM   #6
White Comet
White Comet's Avatar
White Comet is making a name for him/her selfWhite Comet is making a name for him/her self
do you sell just the couplers for the ic?
White Comet is offline
Old 03-02-2009, 10:15 PM   #7
Z33dori
Z33dori's Avatar
dan if i give u payment now for the skid plat will it come in with the april shipment...
Z33dori is offline
Old 03-03-2009, 05:51 PM   #8
anotheraznguy
anotheraznguy is an unknown quantity at this point
Send a message via AIM to anotheraznguy
are you guys selling the subframe risers yet?
anotheraznguy is offline
Old 03-03-2009, 07:43 PM   #9
DC Dan MAX USA
Trader Rating: (79)
Here is the final production version of the MAX Solid Subframe Risers track tested and in production NOW.
Perfect for getting rid of the sloppy OEM rubber bushings. Risers help correct your suspension geometry on lowered cars as well as helping you avoid broken axles.
Alot of people think you need a press to do this but its near impossible because the thin metal on the subframe around the outside of each bushing will easily become distorted. You can do it with an air saw, you poke the sawblade in the cavity in the OEM bushing and cut a slit in the outer ring OF THE BUSHING being careful not to cut the subframe ring. It helps to saw a little from the top side and a little from the bottom side. Once the slit is cut shove a big flat head screw driver in there and once the tension of the bushing's outer ring is compromised, it just pops right out. To prepare for the epoxy you want to sand the surface.
Mix epoxy - When you buy some the thicker viscosity the better. The brand and type are not important as long as it is made to bond to metal.
The Risers slip right in by hand and are secured permanently with epoxy
You have to beat the unibody here... especially if you dont have MAX GII camber arms.
You also have to redo the e-brake cable routing bracket.
With this second version of the solid riser the bottom part is half as thick so you can slice off the extra threads that are no longer needed so you have more dirt drop ground clearance in case your wheel slips off the track.
The half thickness in the bottom part of the rizer also really helps if you are trying to use a straight toe rod on a really low car. Of course if you are on top of your game you already have the MAX GII bent toe rod = )
We should have these on or around march 25th you can pre order now if you wish to reserve a set
They are only $100 plus shipping for a set of 4.
Old 03-03-2009, 10:21 PM   #10
Z33dori
Z33dori's Avatar
looks like i won't be buying poly bushings now... sweet.
Z33dori is offline
Old 03-03-2009, 10:25 PM   #11
anotheraznguy
damn! and i just bought subframe spacers from you on the last order too...
dang!!!
Old 03-03-2009, 10:29 PM   #12
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
248 doesn't seem right for fender roller subframe spacers and spin knob shipped to 55021
g2ic02 is offline
Old 06-26-2009, 06:54 PM   #13
Def
Any chance of having the MAX Solid Subframe Risers made for putting an S14/S15 subframe in an S13? Just need the holes to be offset 5 mm inboard.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Def is offline
Old 03-03-2009, 11:05 PM   #14
ErocKs13
ErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of lightErocKs13 is a glorious beacon of light
damn i like those rotors. could you do a deal for the whole set shipped to 74075? and how much for some 15mm 5lug spacers shipped to the same zip?
ErocKs13 is offline
Old 03-04-2009, 10:28 AM   #15
DC Dan MAX USA
Trader Rating: (79)
dang!!!
we announced this project in september
youre right, looks like i left out the subframe spacers so its 298
were out of 15mm 5 lug but I have 20mm.
$750 shipped for front and rear big brakes
Old 03-05-2009, 01:08 AM   #16
ErocKs13
when will you get more 15's in stock? and how much shipped to 74075 for the 15 or 20? thanks
ErocKs13 is offline
Old 03-05-2009, 05:35 PM   #17
DC Dan MAX USA
Trader Rating: (79)
Payment sent
tracking emailed
Originally Posted by theslows13 View Post
Put me down for a set of those subframe risers (with the rest of my order) shipped to 17562
keegan? I dont see an order pending for you right now, correct me if im wrong
Originally Posted by terrence View Post
put me down for a set of subframe risers shipped to 27360.
$115 shipped - you can reserve with paypal as per my signature
Originally Posted by Z33dori View Post
Matt does the ride get much stiffer ....
the ride is not stiffer but you hear & feel the diff / drivetrain more
Originally Posted by nieko View Post
wow my life is complete.. haha
thank you for making these!
now what about the front?
or actually, the super angle kit also makes the tie rod bolt up lower making it more level right?
gosh these are amazing...
exactly
yea my tie rods dip hella bad.... so gay... bump steer FTL
get those knuckles it will change your life
Late april. $81 for 15mm, $92 for 20mm shipped
Old 03-05-2009, 05:55 PM   #18
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
I believe he means his PSM knuckle, Toe rods and traction rods from the actual knuckle thread.
ILoveMyRHS13 is offline
Old 03-05-2009, 08:52 PM   #19
theslows13
theslows13 will become famous soon enoughtheslows13 will become famous soon enoughtheslows13 will become famous soon enough
silly goose, i just sent the monies.
theslows13 is offline
Old 03-04-2009, 02:03 PM   #20
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
ok so these (risers) are super awesome!
my car felt really good at top drift this weekend.
2 events ago i broke my drivers side axle (twice), so two of em in one event
this event i didnt even break a boot because the max subframe risers help with the axle angle as you can see in the photo. they also help with suspension geometry as you can see in the photo as well if you look at my LCA and stuff.
Some other cool things that you wouldnt think of till they are on- they allow you to make your exhaust higher by the diff if you want to which if youre low is a very weak point on the exhaust since it is like an inch off the ground there. Also, since it physically makes your subframe higher in your car, it helps for bottoming out your subframe. ive cracked my subframe twice before so this is a major issue and a good thing to help.
One thing that wasnt expected is that it changed my wheel fitment, since the LCA is so angled up, naturally when you lessen that angle it pushed the wheel out, about 5mm on my setup.
Overall these are super awesome, install is pretty easy just takes a few hours even if you dont have crazy tools/shop.
Did some of this with them-
Do it!
driftparty.com
hitman is offline
Old 03-04-2009, 08:58 PM   #21
g2ic02
Payment sent
g2ic02 is offline
Old 03-04-2009, 10:08 PM   #22
theslows13
Old 03-04-2009, 10:21 PM   #23
terrence
terrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymoreterrence is not welcome here anymore
terrence is offline
Old 03-05-2009, 12:16 AM   #24
Z33dori
Z33dori's Avatar
Z33dori is offline
Old 03-05-2009, 12:33 AM   #25
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
nieko is offline
Old 03-05-2009, 01:04 AM   #26
Z33dori
Z33dori's Avatar
Z33dori is offline
Old 03-05-2009, 08:56 PM   #27
DC Dan MAX USA
Trader Rating: (79)
rec'd and added to the reserved parts list - THANKS
Old 03-06-2009, 01:27 AM   #28
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
Traction rods, Ruca's, and Toe links (angled), shipped to 98664.
Marc240 is offline
Old 03-06-2009, 03:48 AM   #29
nieko
i need a better job... so i can get the angle kit.. and the risers.
shit would be amaaaazing
nieko is offline
Old 03-06-2009, 04:30 AM   #30
TheXFlames
TheXFlames's Avatar
TheXFlames is an unknown quantity at this point
Send a message via AIM to TheXFlames Send a message via Yahoo to TheXFlames
im diggin the coil overs..
buttt the s13 are out.....
awwwwww
TheXFlames is offline
