#2551 |
![]() Join Date: Apr 2012
G35 19s -3.5 camber in the rear -1.5 front no rub at all super flush no rolled fenders. 255/30/19 and 225/35/19 fronts
Sent from my iPad using Tapatalk HD |
#2552 |
![]() Join Date: Jan 2008
On my s13 I'm running s14 lca's in the front and an s14 rear subframe. Basically I just need to know the difference in length on each side front and rear. I've read the fronts are either 10mm or 15mm longer (searching didn't really help with that). Is the difference the same out back?
86 300zx/90 240sx/97 240sx/96 LS400/03 350z -Shake N' Break Racing- |
#2554 |
Man w/ CTSV & a Car Seat
![]() You're trying to run 19x10 +19 all around? Honestly, 19s on don't belong on these cars, they just look too big even on S14s. Also what size tires are planning on running? Do you already have an idea on which wheels? Here's a set of 19x9 +19 and 19x10 +20...IIRC tires were 235/35-19 all around. ![]() ![]() ![]() ![]() Since you want 19x10 up front, imagine these sticking out an extra 12mm closer to the fenders. Since my front fenders are pulled, they should be nearly the same as 20mm wider fenders. As far as coilovers, Fortune Autos are pretty skinny since they use 60mm ID springs vs the 65mm standard (my Aragosta's are 65mm). Just shoot me a message directly if you got a specific question. |
#2555 |
Thanks. I'm running some 17x9 +25 bee*r b5s on the rear right now. Need to get my fenders rolled so I can go lower but it'll be damn near flush when I do. Iirc I'm running 215/45's on them right now.
#2556 | |
![]() Join Date: Jul 2006
DODOlogic.ca |
#2557 |
Hey i was searching around and i found what i was looking for but not on the car i was looking for. Im looking for a s14 with a 18x11 -22 up front running about a 235/40 tire all on stock metal fenders, has anyone see anything like this on a 14? please show me =) thanks guys.
#2558 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
#2559 | |
#2560 |
does anybody know the specs for the wheels on this car
https://fbcdn-sphotos-b-a.akamaihd.n...22669900_n.jpg
#2562 |
oh ok, cool. thanks
#2563 |
Couldnt really find the answer I am looking for so Im wondering if anyone knows how much camber I will need out back on my s13 coupe to fit 17x9.5 +12 wheels with 245/40s on them? My fenders are rolled but not pulled. If its going to be too much camber I just wont run them, i hate pulled fenders
#2564 | |
#2566 |
Retired General
I'd go with 215s. My wheels are the same size as yours and i have 225/40s in the front and I'm switching. I'm pretty low and it rubs at full lock.
#2567 | |
![]() ![]() ![]() ![]() Didnt rubbed at full lock since I wasnt super low up front. Would probably have rubbed if I went down a few more inches, but nothing a big ass hammer wouldnt have fixed. ![]() |
#2568 |
![]() Join Date: May 2012
I've been looking at wheels and I am lost.
I've got 2 choices that I THINK might work. 16x10 -0 (all around) OR 17x9 -12 (all around) Which ones would fit better on an s14? I know negative offest is going to poke them out... But I'm having hell trying to find what either offset look like (since one is 9" wide and the other is 10". Depending on poke, I plan on running over fenders (probably the origin 50mm rear, 20mm fronts) Will they fit without trouble? anyone have experience with either offset? |
#2569 |
Retired General
1. Go with the 17s. You'll get tired of the 16s REAL quick.
2. You don't need 50mm rear overs with those sizes. Completely overkill. Depending on tire size and ride height, just dial in some negative camber and you're good. Rule of thumb: Get the wheels and tires first. If they don't fit with your desired camber settings, THEN get over fenders. Don't just go hacking up your car for no reason. |
#2570 | |
I'm fairly low, nothing crazy because our roads suck. Currently with CV meshies. Which I like them, but I'm going to need wider wheels after my swap is complete. ![]() |
#2571 |
^^^Easiest way to figure for your situation. Google search wheel offset calculators. Punch in the wheels you have now then punch in either one of those wheels. It'll tell you how many mm itll be sticking out further than what you have now. Then go to your car and measure it out to get an idea first hard.
#2572 | |
#2573 |
This what i use...
1010TIRES.COM - Wheel Offset Calculator As far as the 2 wheels you're thinking off (9j -12 and 10j +0), they're gonna poke about the same with 1mm difference between the 2. Basically itll come down to your preference. What's your current wheel spec and I can tell you via above to see the difference. Personally, I wouldn't go with either one cuz they poke out too much. |
#2574 | |
From the calculator it said: 16x10 +0 will be 32mm less clearance inner and poke out 44mm 17x9 -12 7mm less clearance inner and poke out 43mm more than current set up. I don't mind cambering the front, but I want traction in the rear for daily (235's or 245's with little camber). I can throw my 16x7's on when I drift. Thanks for helping me figure this out. |
#2575 |
![]() Join Date: Aug 2007
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
Question: Who has front wheel fitment where the tire comes right out to the fender and is totally flush?
It seems like generally on front wheel setups, the front tire is a little more sunk than the rear. For those who are flush at the front as well, how does it drive? Does it ever rub when you're turning and going over a dip?
★ ★ GRANDMIGHTY.COM ★ ★ |
#2576 |
Going to be running chargespeed 50mm overfenders in rear and 30mm over fenders in the front on my s14. looking for minimal camber not more than -2/3 degrees in the rear. thinking of 18x9 0 in front and 18x10.5 -25 in the rear...too agressive for the camber spec i want? not very good with fitment...i rely on my wheel guru friend who's out of town.
#2577 | ||
Retired General
#2578 | |
#2579 | |
![]() Join Date: Sep 2010
Trader Rating: (31)
![]() ![]() ![]() ![]() Feedback Score: 31 reviews
#2580 |
![]() Join Date: Jun 2009
I've been looking for a couple hours now and haven't been able to come up with much.
I haven't really looked too much into wheel offsets so please don't hate too much, but there is a guy local selling a set of 17x9 +17 offset and I'm running the maverick dual rear caliper setup which acts as a 8mm spacer. I have 225/45/17 tires for them as well. Would I need to roll and/or pull my rear quarters? I'm okay with rolling, but I don't want to pull them. I'm debating just ordering new wheels with a higher offset, but if these would work I'll go with them. Sorry for the paragraph and I'd appreciate the help! |
