01-13-2012, 05:24 AM | #243 | |
Be sure to include the sizing you need. |
01-13-2012, 12:12 PM | #246 |
Question on 2 piece Starform wheels.
Picked a set up recently. Going to get the faces refinished and was also looking to get them re-lipped as well. I have an email into Wheelflip for a quote. Curious to see if anyone knows if the VR wheel lips would work on these if I had someone local split them? They are 36 hole face/lip, just not sure if everything would line up porperly. If the bolt diameter would be the same, etc. If the lips would work, would they be safe to reassemble as a 3 piece and seal the inner barrel and lip with silicone? Basically convert them from 2 to 3. |
01-13-2012, 06:34 PM | #248 | |
Unless if the face is same piece as barrel and lip goes on top (like RMs) which doesn't look like it either. |
01-13-2012, 08:45 PM | #249 |
The Lip and the barrel are welded, the face will unbolt. However, I took one of the valve stems out and you can see the 2 sections (barrel and lip flange) sandwiched together. So it goes face, lip, barrel.
I want to just have someone cut the weld on a lathe or something, get new lips and reassemble as a 3 piece. Is this a plausible scenario? |
01-13-2012, 10:24 PM | #250 | |
01-14-2012, 12:32 AM | #251 | |
01-17-2012, 05:39 PM | #253 |
Local dude in my town is selling some work emits for dirt cheap and they are 3 piece. 17" 36 hole lips. Who would be a good company to go through to get custom lips made? Or already have them made.
01-19-2012, 06:50 AM | #257 |
Working on these. Faces were sent off to powdercoating the other day. OEM specs were 18x7.5 +45 and 18x8.5 +26. Going to be 18x10 +/-0 (4.5" lip), 18x11 +7 (5" lip) Work VS-XX. |
01-19-2012, 07:05 AM | #258 |
^ sick, im planing to run similar spec on my re-barreled vs-mx (18x10 +6/ 18x11 +12) are you running that on a stock body s13/14?
s14 kouki ka-t |
01-19-2012, 07:07 AM | #259 | |
That's with a 4.5" front and rear lip, so imagine 1/2" more poke rear with the 5s. |
01-19-2012, 07:22 AM | #260 |
nice im glad to see this works ill be using 3"/4" lips stock body 14 as well i was worried with the amount i had to pull it.. looking good man!
s14 kouki ka-t |
01-19-2012, 07:43 AM | #261 | |
Cool, thanks for that info. Do you guys feel that the work 36 hole lips would work on these? I may just suck it up and buy one soon and have one split. Trial and error I guess. Worst case I get the one rewelded. C4lvin, I'd be more than happy to borrow one of those for a little while! lol jk, they're 18's. |
01-20-2012, 02:25 AM | #262 |
I have a set of BBS LM's that need new bolts and a good cleaning.
After deflating the tire is it safe to remove the center with the tire still on the barrel? I'm a little affraid the barrel might get oval. |
01-20-2012, 06:13 AM | #265 |
wow this thread is awesome ! . . . . I have been looking at WheelFlip's work alot lately seems to be great service and have great customer feed back.
+1 for them does anyone know of a company either in Ontario Canada or in New York/Jersey that does a great job doing this? thanks.. |
01-20-2012, 06:22 AM | #266 | |
I'm twiddling my thumbs waiting for my faces to be powdercoated. That's all I need back and I can start re-assembling them. |
01-24-2012, 04:19 PM | #268 |
^ Those will look good. Question though, on the backside of the faces, did your powdercoater mask off where the bolt holes are? I was always curious if that would affect re-assembly.
01-24-2012, 04:22 PM | #269 |
Not that I know of. I trust him enough to spray them evenly. Since it's not a sandwich mount wheel and no silicone will be sealing that area, there's really no need to mask it off.
01-24-2012, 05:53 PM | #270 |
Help Calculate Wheel Offset
I hope this is the right place to post this.
I have a pair of 18x8 +42 inch Racing Harts C2s that i would like to get new outter lips for. the lips are 40 hole lip. Effectivly i want a 9.5 or 10 wide wheel. Here is a Picture to try and illustrate what size lips i have Im pretty sure the lips i have now are only 1 inch lips given you are supposed to measure the width of a rim from bead to bead, so the curved edge seen in the pic above shouldnt be measured (please correct me if im wrong) Again my Wheels are 18x8 +42 as of current Here are my Calculations (provided i do have a 1 inch lip) If i add a 3 inch lip to my existing face and barrels i will be adding (-24) offset to the wheel which would make my wheels 18x10 +18. (please correct me if i am wrong) and 10 wide may be too wide so i was thinking just adding a Lip that is just 1.5 wider or a total of 2.5 wide which would give me 18x9.5 +25. Any help will be much appreiciated Thanks! BTW heres the reason im getting a pair widened, i <3 Cali Freways
WTF IS JUICE?? I WANT THAT PURPLE DRANK!!! |
