04-02-2012, 07:14 PM | #241 |
photobucket.com make a name if you don't already have one. upload the pictures from your computer then once its uploaded use the [IMG] tag to post on the forums.
04-02-2012, 11:40 PM | #242 | |
04-03-2012, 12:27 PM | #243 | |
Trader Rating: (22)
Feedback Score: 22 reviews
Damn that long?! Mounts/shifter extension/driveshaft were ordered at the beginning of feb and the mounts and the shifter extension got here at the end of march. I'm still waiting on the driveshaft though, who knows how long it'll take. Try using the 240atlanta forums to get ahold of him, make a review thread about him and complain and I'm sure you'll be able to get in touch with him. |
04-03-2012, 12:41 PM | #244 |
Trader Rating: (33)
Feedback Score: 33 reviews
Anybody have more pix of that Flat Red 240 on Pg 8? I agree that a kid should not be driving something with that much power. That thing was built to the ballz
I had the pictures from the guys for sale thread but once I switched jobs I lost them all. That was one of the cleanest and sickest 2j swaps I have seen done to date. That was actually the car that got me motivated to begin my project. Just hope it turns out 1/2 as clean and complete as that swap. |
04-04-2012, 08:21 PM | #245 |
I don't know if you all care, but i'd just like to mention that Ben from Freed Engineering has found me a 1jz vvti harness for $450 and he'll do the conversion for $500. I really thought I was stuck or have to pay a huge amount of money for someome to make me one from scratch. Thanks to florante rea for mentioning Freed Engineering!
04-04-2012, 10:46 PM | #246 | |
Pm me your number and ill have him send you them |
04-04-2012, 10:54 PM | #247 | |
so far every time i talked to him hes been a really straight up guy and his prices beats everyone out there from what i have talked to him about so far. i haven't seen his work but the feeling i get from just talking to him im sure i wont be disappointed at all!!! ill fill u all in once i get my harness back from him |
04-06-2012, 06:57 AM | #249 |
Trader Rating: (43)
Feedback Score: 43 reviews
Yeah Ben is good. I'm actually getting all my 2j swap kit from him.
Can anyone confirm what to look for on actual r154 transmission? I just received mine and just wanted to make sure i bought one, hope its not w58.
fdrea |
04-06-2012, 07:48 AM | #250 | |
W58 vs R154 Gearbox Specification or post pic of your transmission. |
04-10-2012, 02:00 PM | #255 |
need help guys.
ok so im getting ready to drop the motor in. only 2 things i dont no yet
1.) i need to know the fittings i need to run the fuel lines from the tank tot he front of the car. i know the line it self is 5/16s but what fittings do i need that comes from the tank and what fittings do i need to connect it to the 1jz? 2.) ok i hear the stock clutch line i have will be the same pitch as the 1jz. i have a sr20 clutch line. but im hearing ill need to bend the claster master cyc lines? is everyone just runnin the stock master cyc with the chase bay clutch line is there any fab needed to the master cyc.. for it to work? thanks guys. |
04-10-2012, 02:44 PM | #256 |
Quick question whats the exact length to extend the shifter for a 1jz/R154 in to s13 i found a guy that can do it i just want the length. thanks
04-11-2012, 12:41 AM | #260 | |
the thread pitch for the 240 clutch master cylinder and the 1jz slave cylinder are the same on both sides the only difference is how the line is routed. The slave cylinder on the r154/w58 is on the drivers side of the trans. The 240sx slave cylinder is on the passenger side of the trans. the chase bays stainless steel line will bolt up with no modifications. but for much cheaper you can bend your own hard lines and flare the fittings on to the lines. |
04-11-2012, 08:57 PM | #261 | |
well were going to use the 1jz slave cylinder and a sr20 clutch line. i think i wont need to bend any lines this way. only diffrence i see right now is that the sr20 clutch line is longer. i used the 1jz slave cylinder so i wouldnt have to bend any hard lines once the motor is in ill see what needs to be done better. |
04-11-2012, 09:00 PM | #262 |
for my fuel lines i just bought some advanced auto fuel lines and got some fittings from home depo that worked out rather well. i just ran the lines from the tank where the hard lines begin and then used a fitting to connect them to the lines i bought. from there i just put them over the diff and then run them along side of the sub frame.
my question is the diff shouldn't get hot enough to hurt that hose right? i was thinking of getting a foot or 2 of heat wrap and laying it on top of the diff were the fuel lines are laying on the diff or i don't even need that?? |
04-11-2012, 10:26 PM | #263 |
Run the lines over to the driver side and clamp them to the frame, that's what I did. I'd avoid just laying them on anything or allowing them to have much movement.
As far as master cylinders you should be able to use the stock 240 master as long as you have a conversion hose(I used tech2's, bought this probably 4+ years ago when they first came out).
04-14-2012, 12:45 AM | #264 |
have another question what down pipe can i use with a s14 and stock twins?
i see on page 1 theres 2 kinda down pipes the first one looks to be for a signle turbo setup. will the 2nd picture down pipe work for my car? |
04-16-2012, 10:22 PM | #265 |
im trying to see if anyone has any more detailed information about hooking up the dakota digital box for the speedo. I have the later generation r154 with the oem tripod trans if it makes a difference. I know what wires need to go where my question is more of how your jumpers are set.
ive been having a hard time finding out the the pulse rate is compared to what it should be
NO HANDS IN PANTS!! |
04-17-2012, 04:47 PM | #267 |
Trader Rating: (43)
The front cover plate for the r154 are available right now from marlin crawler. The thrust washer and shifter fork should be available this summer. I know many ppl are waiting for these. Im pretty much waiting for the other parts so i can rebuild my trans.
fdrea |
04-17-2012, 08:01 PM | #268 |
^ ck with driftmotion see if aarons has the parts in stock that is where i got mine.
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
04-17-2012, 08:55 PM | #269 |
Trader Rating: (43)
^^^i did, but i already ordered some available parts directly from mc. Right now im waiting for the washer and shifter fork. Im def going to get the rebuild kit from Driftmotion.
fdrea |
04-18-2012, 08:47 PM | #270 |
You have an online manual you're using to rebuild your 154? I might try the crawler setup if(when) my trans goes again. It's currently holding 600hp completely stock lol.
