06-12-2011, 03:25 PM | #2821 |
I found out some interesting stuff this week.
Since I modified my knuckles, I stopped using MAX rack spacers, since my outer tie rod hit the control arm before the rack bottomed out. But, in the quest for a flatter contact patch, I was reducing caster via tension rod adjustment. As the wheel moved back in the well, it gained angle as a trailing wheel. I liked that a lot, less ackerman without losing leading wheel angle. My 17x9 +9 was hitting the tension rod/sway bar hard. But, as the leading wheel, the rack started bottoming out before the tie rod hit the control arm. I installed the MAX rack spacers again, and goofed around with it for a few hours to find a happy medium. That's with the front of the wheel about 1/4" away from the sway bar. |
06-12-2011, 05:00 PM | #2823 | |
06-12-2011, 05:16 PM | #2824 |
Mikerbike, your angle looks great... still have a little Ackerman, but definitely increased the angle of the trailing wheel (the only one that matters in drifting).
What's your camber/caster like? I'd imagine you're not running much caster at all, so you've got to dial in massive camber to get decent grip on the trailing wheel.
06-12-2011, 07:29 PM | #2825 | |
Thanks for the info! |
06-12-2011, 09:00 PM | #2826 | |
A few weeks ago, I posted in this thread that I was going to turn my camber plates so that max camber would reduce caster. I still might do that because my wheel is still far from flat at lock. Camber.. I have a bunch of marks on the camber plates, as I assume most do. I used to run max negative but Now I have the dot on the pillow ball on the 3rd mark away from max negative camber. I feel like both my cars push more at max negative camber. I'd like to pull more caster to get more angle out of the trailing wheel. I will either need to get a skinnier front wheel or space out the one I have. I'm in no hurry. |
06-13-2011, 06:06 AM | #2827 | |
Mikerbike; adjusting caster with the camber plates should give some good results. It doesn't change the effective length of the tie rods like using the tension rod does. Also, you can get your same results with tie rod offset spacers and not have to move the wheel around in the well so much.
06-13-2011, 12:12 PM | #2828 |
We're saying the same thing, just calling leading and trailing backwards lol. Turn the wheel left, drift left, the left wheel is 'leading' and can basically disappear.
06-13-2011, 12:17 PM | #2829 |
Haha, good deal.
06-13-2011, 11:41 PM | #2831 |
Kay, so.. Queso, I did the same to my other car today. But, I couldn't push the wheel as far back in the well because I run a taller tire and it hit the rear pinch weld too soon. And I don't have rack spacers to install on this car. And I tried road racing and enjoyed it, so this car doesn't need any more angle mods. But I took a picture anyway.
Also, I did sumpin bad. I made adjustments based of points of the unibody. So one side probably has about 2* more caster than the other. Oh well. I flipped the camber plate (as can be seen in the above photo) and adjusted the tension rod until there was about 1/4" clearance from the corner of the tread to the pinch weld as the wheel swings past. Sooooo scientific. I think I ended up with a little more static camber than when the camber plates were normal and set to the middle. I'm not worried about what I did to the black car. I already tested that (on a closed course, BRO), but I kinda wonder if I should have left more caster for grip driving on the white car. But, I did all this stuff with the tools I carry in my car, so I can change it at the track between sessions. |
06-14-2011, 01:58 PM | #2834 |
06-14-2011, 02:06 PM | #2835 |
Someone is socal should hold like a seminar about alignments. That would be dope. It's.really hard for me to full understand what you guys are doing to.your cars. I guess it would just be nice to see it first hand and in person.
06-14-2011, 04:49 PM | #2836 | |
The Ultimate Guide to Suspension & Handling
06-14-2011, 05:19 PM | #2839 |
I'm not one to blindly link a thread rather than writing something out. It's a little simplified at parts, but all the good engineering tech is there.
Mike Kojima is the single best source of knowledge for S-chassis suspension tech. Time Attack, road racing, and Formula D cred, plus he's got this idea that he should share his knowledge with everyone. Pretty cool if you ask me.
06-14-2011, 06:18 PM | #2840 | |
06-14-2011, 09:02 PM | #2841 | |
Trader Rating: (58)
Feedback Score: 58 reviews
06-15-2011, 04:21 AM | #2842 |
Well I raised my car a little. From my understanding, it seems that being so low is one of the main causes steering issues. Car felt great, I was just wondering what would be the next steps to increase my handling performance? or any alignment advise?
Before: Toe:-.01 Caster: 9.2 Camber: -2.5 After Toe: 0 Caster: 7.3 Camber: 3.1
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
06-15-2011, 01:38 PM | #2843 |
Why do you care about the inside wheel when you're drifting? All that caster is to get the outside wheel (the one carrying all the weight) to have the correct geometry.
Are any of you guys checking inner/center/outer tire temps after a run? That and overall wear characteristics will tell you a lot about whether you're running too much camber/caster.
06-15-2011, 01:40 PM | #2844 | |
06-15-2011, 02:03 PM | #2845 |
Buy a damn book instead! Ya damn illiterate crowd! Like a jillion pages and no one has any data on how how low you want your roll axis angle, how much static camber you want based on your camber gain during x.x amount of g forces etc? Dayam. Get cracking!
With that said someone buy my knuckles 'n arms.
.25 till 3 |
06-15-2011, 02:08 PM | #2846 | |
.25 till 3 |
06-15-2011, 02:51 PM | #2847 |
Trader Rating: (58)
I guess to that degree true, being that I'm not into drifting I don't follow much besides some MotoIQ stuff. I guess i'm to much of a FWD MK fanboy to admit otherwise Dog-Cars for life!
06-15-2011, 02:56 PM | #2848 | |
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
06-15-2011, 04:49 PM | #2849 | |
06-15-2011, 10:13 PM | #2850 |
I already raised the car a ton, not sure if I would want to go much higher. Might just to redo the suspension.
