01-10-2014, 04:42 PM | #2851 |
I'd go with 15mm spacers instead, because then you could just use bolt-ons instead of worrying about extended studs, but that's just me.
ACE マジック HEART |
01-11-2014, 01:00 PM | #2852 | |
Man w/ CTSV & a Car Seat
Love, Needle Dick |
01-11-2014, 01:20 PM | #2853 | |
01-11-2014, 04:59 PM | #2855 |
I saw a real pic of you and I was right, you really are a Needle Dick. My balls probably have more hair on it than your face. You're kind of small to have attitude like you do Needle Dick. That can be detrimental to your health. You probably shave your legs as well, don't you ND..... Oh and your mama is one ugly crier. Jeez.
01-12-2014, 02:46 AM | #2857 | |
Aww you checked me out? We playing A/S/L? |
01-15-2014, 08:35 AM | #2859 |
S14 with 18x10.5 in rear. Want to kno the widest tire I can fit and be low no 4x4 all I can find is 240 and that is no much stretch will a 265 fit? They r rolled flat and will pull if need be
01-15-2014, 10:55 AM | #2861 |
I have! I can only find guys running rear overs with meats or I find a 235 tire. I want to kno if a 265 would clear a rolled fender and if I can make a 285/295 fit with a good pull? And not be 4x4 hight thanks for any help
01-15-2014, 11:00 AM | #2862 | |
S14's have more room in the rear than an s13 so I'm guessing you can run a 235/40 and be fine. If you want a 265 I'm sure you'll be fine depending on your camber settings and how pulled your rear fenders are. To fit a 285/95 you will need a big pull and/or lots of camber! |
01-15-2014, 11:02 AM | #2863 |
Trader Rating: (38)
Feedback Score: 38 reviews
EDIT: spoon feeder...smh.^
You sure you did? Type in "10.5 on S14" using google. You'll be directed to more than a few Zilvia threads. Use reverse image searches. Use your brain. If somebody with a 10.5 in the rear is running x-degrees for camber and toe and has x/x/18 for tires with + or - x-offset, use a tire/wheel calculator to calculate just how much wider a 235/240/265 width would be with the offset taken into account. And lastly, a 10.5 is way too wide for a S-Chassis. My advice? Run a 10 and run the widest tire possible. |
01-15-2014, 11:39 AM | #2864 |
I guess i should have posted here, im sure the question have been asked before but 96 pages is a lot to go through lol
Ordered some wheels yesterday for my S14 18x9.5+10 Front 18x11+8 Rear For all the guys running these crazy specs what did you do to make it fit, i know i have to roll my fenders, will i need a slight pull? Im planning to run 235 40 front and 265 35 rear tires.
***FortuneMinds*** 95 240SX S14 / 14 Lexus IS250/ IG / Twitter: juvi22003 |
01-15-2014, 12:53 PM | #2865 | ||
All depends on the offset. This is 265/35-18 on 18x11 +28 Quote:
01-15-2014, 01:44 PM | #2866 |
^^^^^ damn +28 poke that much imagine my +10. i ran that same spec before but on my IS
front is 18x9.5 with +8 offset rear will be 18x11 with +10 offset My car is in the body shop right now doing a color change and wanted to see what other work i would need to do other than camber arms and roll fenders.
01-15-2014, 02:31 PM | #2867 |
Honestly, you have 2 option. Do a full metal work, not just a pull, you'd need to cut the inner fender, pull the outter as much as you could, then reweld the inner as high up as possible. That would take money and time. Cheaper option is go overs.
01-15-2014, 04:11 PM | #2868 |
I'll test fit them as soon as they get here to see how much they stick out and take it from there. would you suggest some fender flares?
01-15-2014, 06:08 PM | #2869 |
Trader Rating: (25)
Feedback Score: 25 reviews
18x11 +8 with a 255/35 federal
thats with just a roll and very small pull camber is at -4 i'm going 30mm overs which should be enough not a big fan of flares on an s14 but def gonna need some work to fit wider tire in there |
01-15-2014, 06:49 PM | #2870 |
This one helped me alot, thank you.
01-16-2014, 07:21 AM | #2872 |
What size tires should I run on 18x9(+30 I think), idk if I shouldsstretch or not, got the same question for 18x8 and 18x8.5 (my oem 350z wheels) also rememberiI'm wanting to tuck all theirtire
It's the places they take you,and the people you meet |
01-17-2014, 05:39 PM | #2873 |
I'm rolling with z32 wheels on my s13 and noticed that it's hitting my struts. I bought some crappy ass 5mm spacers for the time being they seem to work "okay" but I think its time for me to actually get a better fitment. Would you guys recommend going 10mm spacers or 15mm? Tire size is 195/50r16 if you needed to know. Thanks.
01-18-2014, 07:51 AM | #2876 |
wow, haven't visited this thread for a while. What do I see when I get here but some chicken farmin enema nozzle tryin to start shit with flip. Nothing more than enema nozzle speech and overcompensating verbiage that shows his huge envy of penile size
Now for my question on OE vs slightly different from OE fitment: OE = 6.5 x 16 +40 ICW G-Games clones = 7.5 x 17 +42 The initial fitment on a parts car(rear half, yes, it is for sale) shows the wheel/tire combo fits and actually sit outward slightly more than OE and does not rub. I am thinking maybe only a 10mm rear and 5mm front spacer would be enough going on the way way cheap to work with these until funds permit a better fitment solution
01-19-2014, 02:26 PM | #2877 | |||||
01-19-2014, 03:00 PM | #2878 |
Varrestoen Wheel Help + Uneven Wheel Poke on Passenger side than Driver Side
Alright guys question
I was running G6 Square Wheels 17x9+15 offset With 215/40 Tires sitting on Megan Coilovers Why would my Passenger Side wheels Poke more than my driver side Also I'm about to pick up a set of Varrstoen wheels 17x9+ 12 offset Will be running the same tire setup 215/40 Will the wheel poke be even greater or should I pick up the same wheels but in +22 offset and my problem there would +22 hit my Coilovers |
01-19-2014, 04:30 PM | #2879 | |
Go read here for the rest. http://zilvia.net/f/tech-talk/166626...1-dummies.html
01-20-2014, 02:32 AM | #2880 | |
