Old 02-01-2014, 11:32 AM   #2911
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
^^^oh yea looks good is that with the 17 or 18
Old 02-01-2014, 07:59 PM   #2912
TheRealSy90
TheRealSy90's Avatar
Originally Posted by ILoveJDM View Post
not going to be 30's. you're going to have to run 50's and a slip on.
Cool thanks, well I was planning on doing Origin Type II 50's so that works out perfectly.
Such a good signature.
Old 02-01-2014, 08:14 PM   #2913
ss 240sx
ss 240sx is an unknown quantity at this point
\first post hope im doing this right.
i recently lowered my car on some megan racing street series coilovers and now am looking to purchase a new set of wheels. i know what people say about xxr's but they are affordable, especially for a 22 year old with other things to pay for.
my choice is the XXR 527's probably in chromium black, would these clear my coilovers and cause any problems? is this a good set up for a car that i daily drive?
Front: 18x8.75 +20 tire: 225 (40 or 45) r18
Rear: 18x9.75 +20 tire: 245 (40 or 45) r18
thanks in advance
ss 240sx is offline   Reply With Quote
Old 02-02-2014, 05:41 PM   #2914
Soilsack
Soilsack's Avatar
Soilsack is an unknown quantity at this point
I know I am probably going to get flamed for this but after getting through 10 pages I got really sick of reading. I attempted to search the thread but the search timed out (too many results?)
Anyway, I am just looking for good information on wheel size and tire size just to fill out the wheel well a bit. I don't know all that much about offset/camber/toe in-out/pretty much anything discussed in this thread.
Here is the goal, seems pretty simple compared to others.
Car - 1998 Nissan 240SX SE
Ride Height - Stock or close to stock, maybe eventually 1-2" drop.
Camber - No observable camber desired. Nice flat contact on the road and clean flush look.
Size - 16 or 17" rims staggered (I think that means larger in the back?)
Fender Modification - None
Other modification - I am going to have Z32 brake setup on all 4 corners.
Tire stretch - Hopefully none, I think it looks pretty silly.
All I want to do is make the car look more complete. Less fender gap. I also have a concern clearing the struts as well as the stock wheel well trim (splash guard?)
Any advice on what I would need for suspension upgrades, if any, wheel suggestions, and tire suggestions are greatly appreciated. I hope I am asking with all the right questions.
If you couldn't tell I want to retain an OEM look. I actually really like the S14 SE wheels so if you know of a similar wheel that would be great. As little modification as possible is key.
Soilsack is offline   Reply With Quote
Old 02-03-2014, 02:45 AM   #2915
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
17x9 +25 ish is what you want. Depending on the width of the tires, you probably want to atleast roll the fenders. Should be able to run atleast 245/45-17s all around on that, maybe even 255/40-17s.
CLICK HERE!!!
Old 02-03-2014, 07:03 AM   #2916
Soilsack
Soilsack's Avatar
Awesome, thanks a lot. What are some of the better budget brands I can look at? Can I even go to 17's without rolling the fenders? I would like to avoid it if possible.
Also, let me see if I understand this. The stock offset is +40 if I am not mistaken, so if I get a wheel with an offset of +25 it will bring the wheel out 15mm? This means the inside of the wheel will be deep and allow clearance for the big z 32 brakes, right? I might actually learn something out of this.
Old 02-03-2014, 10:39 AM   #2917
fliprayzin240sx
No, you have to put in the width difference between stock and your new wheels into the equation.
Offset is how far off the mount pad of the wheels are in reference to the center of the wheel. Best way to figure out fitment on your own is by playing with a wheel offset calculator and taking measurements of your wheel to fender space.
CLICK HERE!!!
Old 02-03-2014, 10:58 AM   #2918
Soilsack
Soilsack's Avatar
Do you have a link to a good calculator that actually explains where and what I need to measure? I also don't think I want to go the coilover route, is there a way to make a spring/shock combo adjustable?
Old 02-03-2014, 12:18 PM   #2919
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Adjustable how? Damping? or ride height?
Damping, sure: Koni, KYB AGX, etc.
Ride height? You'll need to get coilover sleeves. Don't go the Ground Control route unless you find a nice used set for cheap. It's honestly a rip off if you purchase them new from GC. Also, it'll give you a more limited range of ride height adjustability. Expect no more than a 2" drop.
For Sale #1 | For Sale #2
Old 02-03-2014, 01:44 PM   #2920
Soilsack
Soilsack's Avatar
Then that is perfect. I am not looking for more than 1 to 2 inches. I was actually referring to camber, would it be done through camber plate or just the control arms?
Old 02-03-2014, 06:21 PM   #2921
fatduece
fatduece is an unknown quantity at this point
Hey guys I got a quick one! S14 with tubs. 30mm front fenders and 50mm rear over fenders. Im also runing a dual z32 rear brake caliper set up in the rear, which adds an 8mm spacer built into the kit.
Could you guys recommend 18s in width and offset for the widebody? I want to run -3.5 front and -3 in the rear. Im trying to pick up a dope set of work equips and I want the maximum lips.
Thanks!
fatduece is offline   Reply With Quote
Old 02-04-2014, 09:35 PM   #2922
I_bang_u
I_bang_u's Avatar
I_bang_u is an unknown quantity at this point
Originally Posted by I_bang_u
Need some advice i try to decide what tires to put on my rear 18x11" +5 wheel on rolled only S14. im looking at 245-40 , 255-35 or 255-40. I have google search all and got pictures for 245-40 and 255-35 on 11" only never see 255-40 yet. Dose anyone have picture of 255-40 on 18x11" ? Im try to see how it look. im new with this Thank you.
I_bang_u is offline   Reply With Quote
Old 02-05-2014, 12:32 AM   #2923
Soilsack
Soilsack's Avatar
Alright, not sure why I didn't remember them earlier.
New question more specs.
Suspension: Nismo S Tune coilover (Lowered 1.0" Front 0.6" Rear)
Wheels 17x8 35mm Offset, 215x45x17 tires
Z32 brakes all 4 corners.
No fender modification
Is it possible?
Edit: I think it would flush out more if I can find a wheel with 25mm offset. If any other suspension mods would be needed I would like to know. the Nismo S tunes are non adjustable and can't mount camber plates so it would all be up to arms I guess(?)
Old 02-06-2014, 10:30 PM   #2924
tiggertsi
tiggertsi is an unknown quantity at this point
i have the almost same goals in mind as Soilsack for wheel fitment, except at most i will only drop the car 1.5". but i am really looking for a staggered setup 17x8 front 17x9 rear. i know that what you said about 17x9 +25 from previous searching is close to what i want. but what about the 17x8 front? i would rather not use spacers.
66 Plymouth Satellite, 96 Nissan 240sx, 03 Harley Sportster. Toys!
tiggertsi is offline   Reply With Quote
Old 02-07-2014, 09:24 AM   #2925
fliprayzin240sx
You dont want to run spacers but you want to run narrower wheels that will probably be more sunken in?
CLICK HERE!!!
Old 02-09-2014, 09:35 AM   #2926
tiggertsi
i am not 100% opposed to running spacers. but i would like to know more what offset on 17x8 will get them close to 17x9 with +25 offset? or in your opinion is it just not worth it to go staggered at those widths? any help is appreciated.
Old 02-09-2014, 10:22 AM   #2927
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Anything narrower that 9 inches wide on an S-chassis is a complete waste, IMO. Do the 17x9+25 all around. That should clear most coilovers, but if not, a 7mm slip-on spacer should do the job.
Although, personally, I feel that S14 wheel arches are too big for 17's and make them look dinky unless you do an assload of fender work like 95KA-Turbo... 18's are perfect on S14's.
simmode1 is offline   Reply With Quote
Old 02-10-2014, 02:23 AM   #2928
fliprayzin240sx
^^^This...only reason you'd want to run 17s on an S14 is because you want to run 17x9.5 or 10 +18 all around and run 255/40s all around for max grip.
CLICK HERE!!!
Old 02-10-2014, 04:26 AM   #2929
tiggertsi
thanks for the advice guys.
Old 02-10-2014, 07:52 AM   #2930
JDMfreak07
JDMfreak07 is an unknown quantity at this point
Hey guys,
I tried to find the perfect thread for my question here on zilvia but i did not find one, i just bought a set of wheels, all 4 are 17x9 +25, i was wondering what set of tires should i get for them? 225/45? 215/40 or 215/45? And don't want my car to be very low because of our broken roads.
Any help would be appreciated.
JDMfreak07 is offline   Reply With Quote
Old 02-10-2014, 08:32 AM   #2931
zooopreme
Trader Rating: (38)
^Use rimtuck to answer your tire question. Insert your wheel specs, play around with offset if you can't find what you're looking for, take notes and apply to your car.
Last statement is true but for those that want meat on their wheels, do stick with 17's.
For example:
You don't need to stick with this size in terms of tires, but it'll leave you room for meaty tires.
Old 02-10-2014, 10:17 AM   #2932
k954triniz
k954triniz is an unknown quantity at this point
hello every one
i have a 1998 silver moss 240sx
my buddy sold me a set of xxr 521 .. 18x10 +25 all four
fitted the wheels on my car
the rear fit like a dream ( even fills the quarter panel pull from the previous owner.. he had ccw I WANT )
but the problem is in the front
i tried to fit but i jus hit shock .. i then tried a 1/2 in spacer ... still hitting the shock
so my dad who also has a s14 decided to used two and i use two
but now i need the fronts
i will be installing 300z z32 aluminum brakes in the front ( i think thats what they call them)
so what ever i use has to clear
i was considering 18x8.5 +25 in the same xxr 521
will this work considering the brakes and i dont mind a slight fender pull but nothing to much the rear is enough for me
k954triniz is offline   Reply With Quote
Old 02-10-2014, 11:14 AM   #2933
fliprayzin240sx
^^^Do people ever read anything in this thread anymore? We must have been talking about the same damn 18x10 +25 XXR wheels front fitment atleast every other page.
CLICK HERE!!!
Old 02-10-2014, 11:32 AM   #2934
simmode1
simmode1's Avatar
Originally Posted by k954triniz View Post
hello every one
All that work for 521's?!? lol... Dude, your buddy screwed you. XXR makes the 521's in 18x10 with a +12 offset. Sell that bad fitting set and get these for all four corners.
XXR Wheels: 521 18x10 Hyper Silver Rims
For example:
Correctomundo. My bad for being too vague. I don't know how you guys have the patience for all this shit... geez... noobs need to go research...
Old 02-10-2014, 12:04 PM   #2935
k954triniz
im sry that i dont have time to read 100s of pg because i have to work to buy what i need and want
by the way i did read about 30 pgs of this and i did not see any post of 18x10 +25 . or never the less what i really asked 18x 8.5 +25
.. saw many negative offset
seriously if you know the answer or know where it is .. dammit it even say this sh*t in the first post .. how hard is it to post it
if im staying something wrong im sry . report me
Old 02-10-2014, 12:10 PM   #2936
k954triniz
thank you for the advice people come to these things for ...
and i got my buddy to let me try his on so i will do that later today
i paid 150 for the set so idc what has to be done lol
noobs .. i know jet engines and building engines not stance or fitment ..
Old 02-10-2014, 07:23 PM   #2937
wurley
wurley's Avatar
wurley is an unknown quantity at this point
I'm going to get smaller lips. I'm wondering if i should go with 1" or 1/2" smaller.
current specs: 18x11.5 -6 245/40/18
-1/2": 18x11 +0 (would like to keep the same tires if possible)
-1": 18x10.5 +6 (again, would like to keep the same tires)
I'm not considering overfenders, just not my thing. I can add camber and possibly pull my fenders more. What do you guys think? could i get away with only 1/2" smaller lips?
car is a s14 with roll and mild pull.
wurley is offline   Reply With Quote
Old 02-10-2014, 07:45 PM   #2938
200mph240sx
200mph240sx is an unknown quantity at this point
what's the widest wheel and tire can I fit for most traction on the rear of a S13 Hatch?
I'm not looking to camber them. I want my tires not to spin. Right now I spin 1st and 2nd till I shift to 3rd. And it makes me slow out of the hole or when I take off from a dead stop anywhere. Also, if I'm cruising at 5omph and hit boost it just starts spinning like crazy.
200mph240sx is offline   Reply With Quote
Old 02-10-2014, 07:51 PM   #2939
Fuego
Fuego is an unknown quantity at this point
You should take 2" out and keep the same tire. Those fit like ass.
You're looking for the maximum tire thread.
Fuego is offline   Reply With Quote
Old 02-10-2014, 10:09 PM   #2940
wurley
wurley's Avatar
that would make 18x9.5 +19. the same specs as in this pic.. i was bored of it after 2 weeks...
