10-30-2013, 12:59 PM | #2942 | ||
What kind of fuel management are you planning on running? Hopefully something that controls timing also, considering the size of injectors. |
10-30-2013, 01:00 PM | #2943 | |
10-30-2013, 01:07 PM | #2944 | |
Thought it was you Thats pretty wild that it worked
10-30-2013, 02:16 PM | #2945 |
Just my but an SAFC II or NEO will not be enough to control 770cc injectors.
SAFC from what I have read are only reliable enough up to 40% bigger injectors than stock. You are going to need something that controls timing as well. If your looking for a true piggyback to hold you over until you get a standalone I would look into something like the MAP ecu's. |
10-30-2013, 02:52 PM | #2947 | |
can anyone confirm if this works with a 1jzgte stock twins as well? the flange looks to be right |
10-30-2013, 07:48 PM | #2948 | |
That actually makes sense: e85 has a lower energy output compared to pump gas, that's why you have to run ~30% bigger injectors for the same power. So 1000cc injectors on e85 push the equivalent power of 660cc injectors on pump gas. That's only roughly less than 50% larger than stock - if you have a Jdm ecu and 20% bigger than a usdm ecu pushes. I don't know the exact figures, but the ecu can compensate a bit on its own anyway - figure 10%. Either way, you were better off than someone running 770cc injectors on pump gas. Big Mike, you could probably get away with running those 770's on e85 with a usdm ecu and it'd be pretty decent . But your timing would be overly conservative compared to what e85 can handle.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
10-31-2013, 06:47 AM | #2949 | |
10-31-2013, 09:18 AM | #2950 | |
10-31-2013, 10:31 AM | #2951 |
Anyone running AEM EMS with the Aristo Non-VVTI Motor? do you get the Supra Version and switch a few wires around? haven't been able to find any useful information online about doing this.
10-31-2013, 11:19 AM | #2953 |
i have a V2 AEM EMS, plug and play, had to wire in the AEM IAT and the MAP sensor, other then that it's good to go.
10-31-2013, 11:48 AM | #2954 |
Ok so im beggining to think its going to be much better to just go to single before install. A few reasons i want to do this now is:
1) I hate how the stock vav lines look and want to eliminate them ASAP! 2) It looks like i dont have to get a EMS right away (which is whats slowing me down currently) 3) Looks like its not TOO terribly expensive to do so. Someone on here said they are doing the T61 (and saw a GT3082r too), which honestly i dont care that (and not necessarily that specific size of turbo) it cant be ran more than say 550-600, or even less. I just want a small single in there for now so i can drive it. Heres my goals with the car for the first year maybe 2. Just drive a few times a week like maybe 2-5 times. I dont have any big Horsepower goals in mind for awhile so 350-450 or so would be cool with me for awhile. I also might take it to an import faceoff here and drag it once, im spending a lot on the r154 and dont want to badly abuse it or break it, i have a great setup for it just dont want to risk it. My s14 has HKS suspension, 300zx discs all around, 5 lug conversion, and KAAZ 2-way diff. So heres my question. To the guys that singled right away, what stuff did you go with to do so? Ive seen some links and heard that the USDM injectors are a good way to go (with the resistor pack) and after that im confused. Thanks for help guys!!! |
10-31-2013, 11:59 AM | #2955 |
OHHH and i almost forgot, (i want to try and contribute SOME because i feel like this thread has helped me so much its ridiculous haha) for anyone doing the swap still or in the future:
I am going with wiringspecialties, not only do they have great customer service, knowledgeable staff, but they are in the late development stages in creating a brand new wiring harness that is in fact new not used but also can accommodate stock twins, MAS/MAF sensors, upgraded EMS, and so much more you can throw at it. I guess it can remove certain wires and change the ways it runs just by taking certain stuff off, cant describe it fully haha but it seems really useful. And all for the low price of 600!!! Theyre not due to be on the market until late december (2013) early Jan of 2014 they said but you can call them and pre order some and could even get a discount! I was too geeked to hear this because i didnt want to use old modded wires and than change the harness when i went to a EMS. Hope this helps some one out there. If you have any questions i would call them and talk to Chris, nice guy and knows a good bit on the harness. |
10-31-2013, 12:04 PM | #2956 |
For what it's worth, i was stock us twins for a season, then did a single conversion. If i had to do it over again i would go straight single. So much unneeded wiring can be removed once single, looks better, more room, easier to maintain. honestly most likely weighs less (Anyone weight there stock twins?)
Not to mention, you'll need to change some intercooler piping,Intake,and downpipe if you run twins then convert to single turbo, which is all money and time you wasted buying parts.
10-31-2013, 12:27 PM | #2958 | |
http://zilvia.net/f/builds-builds-on...tle-build.html
10-31-2013, 01:51 PM | #2960 |
AEM 30-6100. For the TT Supra (i'm an AEM vendor btw) It just plugged right in, like i said the map and IAT sensors needed to be wired, other then that it's fine. been that way for 1000+ miles no issues thus far.
10-31-2013, 02:53 PM | #2961 | |
I agree with the above ^. I stayed stock twins and ran them in true twin mode. They were fun, but not a lot of top end. And they died by pouring out oil (Jdm aristo swap). I actually had purchased a gt37 before I even had the swap done, but wasn't well versed on everything I'd need, and I wanted to see what the stock twins would do. I didn't have heat on my s13 with the twins because they were so close to the firewall. After they died, I bought an eBay manifold for $140 and threw the gt37 on. I had to get a bigger bov and wastegate, and redo the intercooler piping + downpipe, but it's so worth it. If I had it to do over again, and could afford it, going single right away makes the most sense. I've see SP make 550whp on a log manifold with a qsv, and it's so simple and reliable and fun looking.
10-31-2013, 11:01 PM | #2962 | |
1) I seen mikes build and dam does it look good, clean as hell too. Im going with the ebay turbo exhaust mani, tial wastegate, i need a BOV correct? which would you recommend? 2) I like both the GT3082r and the T61, which would be a better buy since my HP goals are 350-450 (500 if i can squeeze it)? 3) Im actually having trouble finding 550cc USDM injectors If i go with bigger ones i will need a new fuel rail correct? Aggg i had most of this swap figured out until i decided to go single right from the getgo haha. As always thanks for the help! |
11-01-2013, 05:30 AM | #2963 |
I'd just spring for some aftermarket high impedance injectors rather than go to the trouble of wiring in a resistor. And go with 750cc or something for expandability. What ecu are you running?
11-01-2013, 06:24 AM | #2964 | |
Look into Treadstone manifolds or similar log type manifolds.. they are cheap and have some impressive results
11-01-2013, 06:25 AM | #2965 |
Some info on the CX Racing radiator Upper Hard Pipe kit
Got the CXRacing upper radiator hard pipe kit and installed it. I'm fairly impressed with the kit minus 2 minor issues. The supplied hose clamps are way too big but work and the 90 DEG coupler fits pretty loose on my KOYO radiator Super loose Installed - I like the look Gets a bit close by the power steering pulley but clears just fine Here is the loose hose clamped down... It may work... Guess we'll see if it leaks
11-01-2013, 12:30 PM | #2966 |
@ Ivan yeah i have the stock jdm aristo ecu that came with the engine. I also just got back from zerolift auto labs and meet with Robert. Nice guy and pretty knowledgable too, we discussed some options and things I will need. Very clean shop and the place looks legit so im seriously considering going with them on a lot of my parts. Also Ivan yeah I think I just may go with 750s or bigger
11-01-2013, 12:42 PM | #2967 |
My only complaint with Zerolift is their customer service sucks ass... Every time I emailed them I either never heard back from them, or it took them a week and a half to respond. If I called them I got put on hold, and sometimes they picked back up, sometimes they didnt.
Their mounts and driveshaft are nice though. |
11-01-2013, 04:35 PM | #2968 |
Ahh thats shitty man. Well I hope its not like that anymore! He said multiple times that if I have questions on anything to email him so theres that I guess lol I mean im sure he means well but I wont know until I dig deeper into this build. Also I think I will do a build thread to try and contribute more and also to hear peoples suggestions. Because at this point any help is greatly appreciated and helping the old wallet out haha
11-01-2013, 06:28 PM | #2969 |
Got some goodies in today for my new fuel setup!
Aeromotive stealth 340, tomei fuel pressure regulator and gauge, and a regulator rail adapter. Deleted all my stock hardlines today. Planning on running -6AN feed/return lines all the way to the tank. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
11-01-2013, 06:44 PM | #2970 |
Been a while since I've posted, figured I'd share the new setup. This is what my kitchen table looks like haha.
Upgrading to a DBB GT42, 290's, full ferrea head, built block, etc etc, and a little bit of nitrous. Car has been running low 10's on the 6766, but it's time to go fast now!
