07-21-2009, 03:06 PM | #1 |
Transmission issue
I am having a issue with my s13 with sr swap. When i release the clutch pedal it squels right before it engages. Also when I got a 4th or 5th gear pull smoke will come from my shifter. If I stay in a gear at 4k or above it will do the same thing. I checked the fuilds and they are good. Any info will be great. Thanks
Slide Happy |
07-21-2009, 03:09 PM | #2 |
your throw bearing is out. you should of changed that before you even put anything in. if you even change the throw bearing you might as well change your rear main seal as well. check and make sure there's any tranny fluid in your tranny
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
